Old 10-05-2020, 10:43 PM #16
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Originally Posted by ProfessorP View Post
I like the non ratcheting straps. Works for kayaks and lots of other stuff. Amazon.com : VAMO SUP Kayak Surfboard Surf Rack Tie Down Straps - Black Pair (15FT) : Sports & Outdoors
Thanks for the link! I am going to find something comparable to try out. I like having options. Appreciate it!
Originally Posted by maca1 View Post
Sorry for the thread drift
Thanks for making this thread about you. May your rack rub! lol jk. Good luck with it.
Originally Posted by jp.vegas View Post
Yes exactly those. They loop around the bar, you hook the end of the ratchet strap into one and then do the same thing on the other side. Takes the guesswork out of using the pro rack and is the proper way to tie the strap to a round member that the hook won't fit on.
Thanks for confirming! This seems like what will work best for me. What straps do you use, if I may ask?
Originally Posted by Jetboy View Post
As a general rule - I almost always use typical 2" heavy duty ratchet straps. Most 1" width straps are garbage. I'm sure there are some good ones, but most are crap. The ratchet mechanisms are usually just not very good and dont' last a long time.
Incredibly helpful post! Thanks for that. I admit, I was going to do the no-no and wrap around the object prior to around the rack. Thanks again for all the tips. 2" it is, with the proper ends. Awesome. Thank you!
pointman is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 01:28 AM #17
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
However - the standard hook end on a common 2" ratchet strap like this is too large to physically fit under the OEM cross bar.
So you need to find straps with ends that look like this if you want them to be easy to use on the OEM rack.
The biggest mistake people frequently make tying down stuff is to wrap the strap around the object in a loop. Don't do that. You go over the top and use the strap to hold the object down against the rack and friction between the object and the rack is what keeps it in place.
NO:
Yes:
Pretty safe bet that your "no-no" example is actually the best way to attach a bunch of bamboo sticks to a roof rack.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 12:09 PM #18
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
I've got a variety of 1" straps, and yes they work just fine, the ratchets hold up after many trips in the desert on multiple rigs etc.
No specific brand although they definitely vary in quality and there are some that I only use inside the vehicle to tie down pelican cases with camping gear and there are some that I use outside to tie down firewood, jerry cans, toolboxes etc. The outside use ones definitely have a higher quality fabric for the straps, it's thicker, nicer weave, higher working load rating. I believe I bought those at a local hardware store vs hazard freight.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 12:58 PM #19
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
It's wrong for a variety of reasons. Wrapping the strap around the bundle will result in any movement of the bundle leading to a lower strap tension and the potential for the sticks to fall out. It's also not centered - so as the roll moves to the middle of the rack - it will get looser. The safe way to tie something like that down would be to bundle the sticks with one set of straps and then attach the secured bundle to the roof rack correctly.
The other alternative would be something like this that would naturally compress the bundle in away that both secures it properly to the roof rack and compresses the bundle to its self so that individual sticks won't come out (not my drawing, but the strap routing shows how it should be done):
Old 10-06-2020, 01:14 PM #20
Jetboy's Avatar
Jetboy's Avatar
I'm sure there are some really good quality 1" straps. I've just never found them at a reasonable price. A typical all metal ratchet with a 30' 2" strap is around $15 and lasts for - basically forever. I've yet to find a decent 1" strap with a high quality ratchet mechanism that's similar in cost.
There's nothing you could ever haul on the roof given the 200lb weight limit that would justify a 2" strap for strength. It's mostly just the availability of quality ratchet mechanisms and strap materials on 1" size that is the deal breaker. I have half a dozen 1" ratchet straps around. They all end up not working very well after a few years.
Old 10-06-2020, 02:36 PM #21
The 30’ length is a little tough to work with on the roof too, let’s be honest.
I have my share of crappy 1” straps, they work inside just fine but yes, at some point if you use them a lot outdoors, they turn to shit. Not going to argue that point.
It’s just like other stuff though, I consider them consumables and I carry some spares if something breaks or someone else needs one temporarily. Like to strap up a lower control arm or what have you.
Gone
Old 10-06-2020, 04:58 PM #22
Jetboy's Avatar
Jetboy's Avatar
The length is a pain - unless you are putting something REALLY big on the roof I guess? lol. It's kinda frustrating that someone doesn't just make a smaller version of a 2" ratchet mechanism. Same general build quality and material thicknesses, but just narrower. I'd buy them.
Old 10-07-2020, 01:47 PM #23
pcstockton pcstockton is offline
pcstockton is on a distinguished road
Frontrunner Stratchits all day!
Get both sizes. Worth every penny. I don't personally think they are overpriced.
pcstockton is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 03:23 PM #24
mike5 mike5 is offline
mike5 is on a distinguished road
Why not cut the long straps down to the length you want and burn the ends? I’ve done that before and it works great.
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 07:00 PM #25
TrailScout TrailScout is offline
TrailScout is on a distinguished road
I'd suggest Niteze CamJam Straps
When I got my gobi rack, my old ratchet strap hooks wouldn't fit the rails. After looking around I came across the Niteze CamJam straps and have totally fallen in love with them. They're quick to set up, hold seriously tight, and best of all have no chance of scratching the powder coat off the rack because the only thing touching the rack is the nylon strap. Plus, they also roll up into almost nothing for storage.
I ended up getting 4 of the 12' ones and have used them for strapping down lumber, camping gear, bikes etc. No issues ever.
The only down side is that it does take a moment to figure them out. So you'll want to watch a youtube video and play with them at least once before you actually need to use them.
CamJam Tie Down Strap
TrailScout is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 12:01 AM #26
Banned
Banned
Thanks for the info! Those looks really good too! I think I will pick some of those up and see if they work for me. Thanks for the link.
Old 10-08-2020, 03:16 AM #27
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Want to put stuff on roof. ...Ratchets a good idea?
Depends on what you are tying down. Hard objects like spare tire or Jerry cans, ratchet is nice. However, it's hard to "feel" how tight the ratchet is and it could deform for soft objects like kayaks, especially when softened from heat.
For soft objects, I prefer non-ratcheting aka cam-lock straps like below. Personally I use 2 Beijing Freight straps (quality feels good) on my kayak, backed up with a third - a Thule one.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 05:30 PM #28
Banned
Banned
Awesome info. Thank you! I'd be using for both soft and harder objects so good stuff for sure. Appreciate the help!
good , idiot , nice , proof , roof
SOLD! FS: Powertye Ratchet Strap Kit, 10 Straps, $89 Shipped - Miami SURF RUNNER For Sale: Non-T4R Items 3 07-16-2020 12:41 PM
WTB Gobi rack tie down ratchet straps bbermann For Sale: T4R Items 3 06-15-2020 09:57 AM
**Group buy: ARB snatch strap + ARB tree strap - limited spots!** ramonortiz55 Group Buys 5 07-05-2016 09:26 PM
Wanna trade my roof rack for your roof rack covers? Qyota 3rd gen T4Rs 10 05-07-2013 10:23 PM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
