Old 10-06-2020, 05:47 PM #16
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
Originally Posted by MicrowaveOven View Post
After I installed 6112 and JBA’s, had clunk every time front would load/unload. Replaced tie rods, inner and outer and clunk is now gone. Was surprised, but not
Load/unload as any weight transfer front/rear? Mine has been doing that for about 15k miles, but only in the rain. I've replaced springs, UCAs, LCAs, sway bar bushings, sway bar endlinks, etc, etc to no avail
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 11:36 PM #17
MoonGoon762 MoonGoon762 is offline
MoonGoon762 is on a distinguished road
Originally Posted by axel1 View Post
I've had a clunk in the front and the back ever since putting in 5100's in place of the stock shocks.
To me it sounds like the same noise I heard on my Honda when the sway bar bushings were going bad. I'm considering replacing those anyway, since they look a bit crusty and the truck is now 6 years old.
If I had to guess, I'd say that undoing the bushing connections when I put the lift in probably disturbed them enough to exacerbate their already worn-out state.
In my personal experience, any dull, muffled clunking noises in my suspension have always been rubber components of some form.
Are the sway bar links tight?
MoonGoon762 is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 10:22 AM #18
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
My sway bar and links are removed.
delloro is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 01:54 PM #19
rc10mike rc10mike is offline
rc10mike is on a distinguished road
Exclamation
I have a similar front end clunk. Be sure the rubber bushing directly below the top center strut nut and washer is installed...because whoever installed mine didn't..
rc10mike is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 03:52 PM #20
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Speaking of bushings, did you install the lift yourself? If so, did you have the truck on the ground before torqueing the lower shock bolt to the LCA? If not, there could be bound tension in the bushing, possibly creating the clank, or the bushing could be shot. Just another idea for you.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 04:27 PM #21
4r3_yvr 4r3_yvr is offline
4r3_yvr is on a distinguished road
I developed a clunk after installing Bilstein 5100s with 881/906 springs. The clunking would happen when driving over a series of bumps in the road. There would be no clunks when driving over smooth dips or slowly I jacked up the front end and discovered the driver side tire has 1/2" of left/right play. I've tracked it down to the driver side inner tie-rod. Planning to replace the ITRE this weekend.
4r3_yvr is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 04:34 PM #22
numbay numbay is offline
numbay will become famous soon enough
My 2020 ORP, no modification, and I have heard clunk 3-4 times. I have to monitor closely. I heard it when turning left at an intersection around 25MPH. I even made a u-turn and tried again to see if it was the vehicle, or manhole cover there making the clunk sound. I have <6K miles so far.
numbay is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 09:45 PM #23
slide531's Avatar
slide531 slide531 is offline
slide531 is on a distinguished road
slide531's Avatar
Finally tracked down my clunk today.
My clunk was a dull thunking clunk that was most pronounced when going through uneven bumps and left turns on pavement and was constant when off road. It sounded like it was the sway bar coming from the middle of the front end.
I believe that when I installed my UCAs I forgot to torque the sway bar end link on the passenger side. It was really loose. Tightening it to spec and clunk was gone. Fixed my skid plate creak while I was at it. It was so quiet today that I could now hear my squeaking rear hatch Replaced LCA bushings (was &quot;front end clank&quot;)Replaced LCA bushings (was &quot;front end clank&quot;)
Sent from my Pixel 2 using Tapatalk
slide531 is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 07:29 PM #24
delloro's Avatar
delloro's Avatar
Update - I bought the Whiteline front bushings kit. Prior to replacing the bushings, I have sprayed them with penetrating oil twice.
The noise became much quieter.
Looking forward to getting the job done this weekend.
clank , end , front , loose , similar
Loud front suspension clank after fox lift - video Sand dollar Problems & Warranty Issues 0 08-01-2020 11:43 PM
Clank clank clank while backing 64nkb Problems & Warranty Issues 1 07-22-2013 10:15 PM
4Th Gen Front End Clank Gone! CAN-03runner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-19-2011 12:10 PM
Clank in front end area? ARK_SWAMP_RIDER 4th Gen T4Rs 7 10-17-2011 11:13 PM
CLANK when Reversing from front wheels MICA4R 4th Gen T4Rs 6 02-24-2011 11:44 PM
