Old 10-05-2020, 12:36 PM #1
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Replaced LCA bushings (was "front end clank")
I hear a clank, sounds like from the front end, when I drive through a dip near my house at speeds over 20 mph.
Removed skids, and complete sway bar, still there.
Checked LCA and body mount torque.
I see nothing loose or making contact.
I have an Eibach pro lift and JBA UCAs.
Anybody have similar issues?
ETA: Replaced my factory front LCA bushings. I had an annoying noise I could not find. Used my phone to watch the LCA bushings when turning my wheels side-to-side, they looked like they moved too much. On closer inspection, I could see how they could have been making noise by hitting the mounts fore-and-aft.
I used the Whiteline kit for a 2014 FJ, as the listed kit for a 2015 4Runner does not fit according to others' experiences.
Took 4 hours, including making dinner for the kid.
Only one bushing shell had to be peeled out, the other three came out in one piece. Used a torch and an 8-ton bottle jack. The factory spare jack would have worked just as well, if not better.
So far, so much better. Noise is gone.
delloro is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 12:54 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Could be a number of things. Check in order: struts, ball joints, suspension bushings, other bushings (sway bar), or just bolts that attach any of those.
fkheath is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 01:13 PM #3
delloro's Avatar
delloro's Avatar
15,000 miles on new Eibach suspension.
Sway bar assembly removed.
All torqued to spec.
Old 10-05-2020, 01:26 PM #4
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Is it a "harsh" feel when you hear the clank? Maybe something to do with the bump stops?
I have a 2.5" Dobinsons lift on - wasn't pleased with hitting a pot hole at high speeds (wasn't bad, but firmer than I thought it should be).
I swapped in the Energy Suspension bump stops - sound is different (much quieter), the big hits at speed (potholes, uneven pavement) seems to ride MUCH BETTER. Might be worth trying at less than $40, $30 if you can find them for a deal.
Only other thought is are the coils correctly rotated? Toyota wants the bottom pigtail in the back, as a 180 rotation has caused issues with hitting the UCAs. Should be easy to see marking on the coils if this is the case.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 01:26 PM #5
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
have someone turn your wheel lock to lock while you watch the LCA bushings--look for excess play
tm965 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 01:28 PM #6
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
Could be a cracked CV cage.
Seattle206 is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 02:18 PM #7
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
Front-end clunks can be a major PITA. My method is to get under the vehicle while it is on the ground and try to duplicate the sound by checking for any loose components. A rubber dead blow hammer works wonders.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 04:23 PM #8
delloro's Avatar
delloro's Avatar
New Durobumps, hope that's not it.
Please explain this a bit . The end of the bottom coil pigtails at 6 o'clock, if viewing from top, with front of car at 12 and rear at 6?
NVM I found it
Replaced LCA bushings (was "front end clank")-screenshot_20201005-134459_drive-jpg
Old 10-05-2020, 04:59 PM #9
NVM I found it
I doubt the clank is from durobumps - those are supposed to be quite nice. The image you found dictates the pigtail stuff I was trying to describe perfectly. The tail will face the rear of the car on both sides, just one thing to check.
Look on the bottom of the JBA arms to see if any contact has been made - this is a great thread with a similar issue. JBA upper control arms hitting Spring
Old 10-06-2020, 10:10 AM #10
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Lower control arms - both sides.
Take it to an alignment shop with a lift. They can tell you in 10 minutes what all to replace.
Just noticed this is a relatively new 4runner. Might take it back to the dealer. Not sure offroad maintenance is covered
Amazon.com: Detroit Axle - Brand New Front, Lower, Right Complete Control Arm & Ball Joint Assembly 10-Year Warranty [Does Not Fit Kinetic Dynamic Suspension]: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 10:40 AM #11
damn those are cheap!
Old 10-06-2020, 01:48 PM #12
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
Those are.... alarmingly inexpensive
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 01:51 PM #13
slide531's Avatar
slide531 slide531 is offline
slide531 is on a distinguished road
slide531's Avatar
Yes! I just installed jba UCA's a couple weeks ago and have had a clunk ever since. Had alignment done and checked torque on the lca's but clunking is still there.
Sent from my Pixel 2 using Tapatalk
slide531 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 02:15 PM #14
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
I've had a clunk in the front and the back ever since putting in 5100's in place of the stock shocks.
To me it sounds like the same noise I heard on my Honda when the sway bar bushings were going bad. I'm considering replacing those anyway, since they look a bit crusty and the truck is now 6 years old.
If I had to guess, I'd say that undoing the bushing connections when I put the lift in probably disturbed them enough to exacerbate their already worn-out state.
In my personal experience, any dull, muffled clunking noises in my suspension have always been rubber components of some form.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 02:24 PM #15
MicrowaveOven MicrowaveOven is offline
MicrowaveOven is on a distinguished road
After I installed 6112 and JBA’s, had clunk every time front would load/unload. Replaced tie rods, inner and outer and clunk is now gone. Was surprised, but not
Sent from my iPhone using Tapatalk Pro
MicrowaveOven is offline   Reply With QuoteReply With Quote
clank , end , front , loose , similar
Loud front suspension clank after fox lift - video Sand dollar Problems & Warranty Issues 0 08-01-2020 11:43 PM
Clank clank clank while backing 64nkb Problems & Warranty Issues 1 07-22-2013 10:15 PM
4Th Gen Front End Clank Gone! CAN-03runner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-19-2011 12:10 PM
Clank in front end area? ARK_SWAMP_RIDER 4th Gen T4Rs 7 10-17-2011 11:13 PM
CLANK when Reversing from front wheels MICA4R 4th Gen T4Rs 6 02-24-2011 11:44 PM
