05-14-2019, 12:46 AM
What are some essential and/or needed tools to keep in the vehicle?
I recently bought a roll-out tool pouch to keep in the vehicle. What are some tools that would be handy to keep in the T4R at all times?
05-14-2019, 04:13 AM
ratcheting wrenches and metric socket set in M8, m10, m12, m13, m17, m19. plus extensions.
allen wrenches.
screw drivers,
punches,
pliers,
channel lock wrench.
wire cutters/splicer
cheap light tool thing to test connections.
non-marring plastic panel removal tools.
i double up on some wrenches m19 (for suspension work)
I also double up on some sockets (some deep/some short, thin wall), m17 and m19.
I buy cheap socket sets at harbor freight for the cheap sockets, and I use midtier home depot stuff for the wrenches, socket wrench etc.... so i don't feel bad if it gets lost or stolen, or if i have to pound on it with a hammer.
With this tool set, i can literally take apart 90 percent of my vehicle. Now putting it back is a different story.
05-14-2019, 12:29 PM
Real Name: BobH
Real Name: BobH
That's a really full kit.
In addition:
Yank strap and shackles
and
A road service contract and go with another vehicle. They can possibly tow you back to a road to use the road service.
05-14-2019, 12:35 PM
Some of the things I have that I can think of:
- spare magazine for my pistol
- gloves
- Tow straps
- tow hitch w/ball
- small air compressor
- bungee cords
- First Aid/trauma kit
- basic tools
- knife
- flashlight w/ extra battery
- paracord
- thick military blanket
- some water
- butt wipes/toilet paper (has come in handy more than I care to talk about LOL)
05-14-2019, 01:25 PM
Real Name: Chris
Real Name: Chris
You need like 5 x 10 mm sockets
05-14-2019, 01:29 PM
Real Name: Gus
Real Name: Gus
In addition to the wet-wipes and toilet paper, I would add, a 1/2" drive 21mm deep socket on a breaker bar for the lug nuts. And a wheel lock key or two (if needed).
2016 T4R SE Premium, 3" ToyTec Lift, SPC UPC, Baja Rack, Shrockworks Sliders, KO2's, Rigid SAE Fog Lights, Gobi Ladder, ArcLight Map & Hatch LED's, Blueridge Overland Attic, 2m Ham.
05-14-2019, 01:42 PM
I don't carry a full tool kit most of the time. When I'm going far from pavement - I have a tool bag that includes most of what was already said above
The regular wrenches, screw drivers, pliers, etc.
What I also keep along that might be useful is:
Lighter
rescue tape - yeah it's $10 for a little roll, but it is pretty handy if you need it.
Duct tape (small roll)
Spool of spare wire. I keep some ~10ga wire. About 20 feet. Plus a few crimp ends. And a wire pliers.
Spark plug socket
I usually take my 20v impact and 20v angle grinder with two full batteries. Impact for faster trail repairs. Angle grinder for cutting whatever needs cutting that I can't do otherwise - like a skid plate that's damaged, cutting off a damaged bolt head, a crushed exhaust tube, or ?? I have used it to cut off the teeth on a transfer case output shaft in the most in depth trail repair I've been around. Broken 4:1 output, only had a 2.3: output spare, so they used my grinder and cutoff disc to cut all the low range teeth off the 2.3 output shaft so it would work in 1:1 high range with the other shaft. - just an example of something you can do with an angle grinder that would be very very hard to do any other way.
roll of electrical tape
I think that mostly covers what I carry in my tool bag.
I also have a second bag of off road recovery and communications gear that I keep together and put in when I'm going to remote areas. In that bag is:
Tree strap
Snatch strap
D shackles
Hitch skid plate
CB radio
Ham Radio
Gloves
extra hitch pin
punch (for repairing damaged synthetic winch rope - I ended up pinch cutting my winch rope two weeks ago in moab on an approach to a steep rock face - pinched the rope between the fairlead and the rocks. Doing a brumel splice is super easy, but only if you have something like a punch to use to guide the rope through. I didn't have one. A sharpie marker was what I ended up using.)
I always carry a survival bag with a few items:
mini camping stove set (jetboil style - cheap $20 amazon version) - this is just handy for hot chocolate at the trail head or coffee or whatever.
about 4 MREs
Rolled up blanket.
Trail repair canvas tarp (for laying on in the dirt - thanks to slee offroad! for the swag)
First Aid Kit - I have an Outer Limits Supply kit. It's big, but very complete.
A gallon of water
Extra sun screen
Jumper battery kit
Air Compressor and hand tools - valve stem remover, spare valve stem complete, and gauge- I also have some easy air down things - but I never use them. It's easier/faster to just pop the valve cores and let the air out manually.
Handheld Ham Radio - I keep a handheld Baofang HAM in my vehicle and my wifes all the time pre-set to a specific channel so we can communicate in the event of a natural disaster/emergency if cell service is out.
fire extinguisher.
I think that covers what I carry in my tool kits. Most of which I leave at home 99% of the time.
05-14-2019, 01:45 PM
Real Name: Dave
Real Name: Dave
Tools to keep n the car
Once you've done some work on your car you get a sense of the essential tools you'll need. Some of it depends on your skill level and ability to take on difficult mechanical tasks.
I have a small canvas tool bag full of sockets and a 1/2" socket wrench. Six (6) point sockets work better than 12 point. Those are usually the hardened steel, impact wrench variety. Everything on mrblah's list above is good to have. I take a better tire lug nut wrench, a cross-pattern X shape that can spin the lug nuts off. I carry a full set of open end hand wrenches in a roll up canvas pack.
A good set of recovery gear is required for off-roading. Here are a lot of good ideas from lots of people here:
Recovery Gear Options
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
05-14-2019, 01:58 PM
Real Name: Dave
Real Name: Dave
Essential car gear
@ Jetboy
I like your whole list, especially the survival gear, the third part of your list. Most of that gear is always in my car.
Here in dry, arid So Cal I carry a couple of gallons of drinking water all the time. One gallon+ is in a cheap, well-rinsed liquid laundry detergent bottle with a push button spout (reuse, reduce, recycle) for washing up after a hike or dirty job. I carry at least a gallon of good, filtered drinking water in several reusable quart containers (REI). Most of the door pockets are full of sports water bottles for drinking while driving. I'm a heavy drinker and prefer water over anything else.
05-14-2019, 03:09 PM
Real Name: Chris
Real Name: Chris
In addition to the very helpful lists from above the most useful extra thing I carry in my vehicle has been extra fuses. You can order an assorted set from Amazon for pretty cheap. 10A, 15A and 30A are the most common to replace.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
05-14-2019, 03:44 PM
Originally Posted by BCMUSA
- tow hitch w/ball
You aren't putting snatch/tow straps on this, right?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
05-14-2019, 03:50 PM
What's your commute like?
I have my cell phone, a small assortment of fuses, a compressor with gauges, a noico jumpstarter, a modular screwdriver set, and a rain jacket.
My commute is quiet short.
If I'm driving long distances, over short terrain, a cheap briefcase sized Walmart socket and wrench set, plus some recovery straps and shackles, and a first-aid kit.
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
05-14-2019, 04:04 PM
I bought this to put my recovery gear and tools in and it is a good product with plenty of space. I found them as they are a sponsor on this site. Will fit behind the drivers seat with the rear seat removed if you don't stuff the outer pocket with too much stuff. Fills the space so when sleeping in the rear you don't have to stuff it full of other stuff so that it is level. Now I don't have to carry a separate bag for my VIAIR 400P Automatic. I just got the standard black so that it is the same color as the interior and will less likely be as visible to criminals.
Overland Recovery Gear Bag
Unless I am on a road trip, I don't take this for day to day driving.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-14-2019, 04:07 PM
No I haven't. Are you thinking about the strap slipping out and sling-shotting back or something?
05-14-2019, 04:15 PM
This is an interesting thread. I have not done any off roading yet, as my 4runner is not ready. I had no idea of all the equipment needed to carry. That's like 400 lbs of recovery and repair gear.
A prius is looking better all the time.
