Old 10-06-2020, 08:26 PM #1
GLOBparty GLOBparty is offline
GLOBparty is on a distinguished road
Got a deal on 285/70/17 wildpeaks, will they fit on stock 2012 sr5?
Title says it. Have a 2012 SR5 with the stock 17” alloy wheels. Got a deal on 285/70/17 fallen wildpeaks and I’ve read various accounts saying it will fit but will encounter rubbing when off-road. I don’t off-road too often but we do like to and it’s Covid approved so more is in the future and it’s easy enough trails that I was fine before I just removed the thick rocker trim. Do I need a lift? If so what’s the minimum I can get away with to avoid rubbing without costing an arm and a leg.. (was laid off - thanks covid) any help, suggestions, messages are very helpful. Thanks!
Oh I do have a third row, if that effects weight somehow...
GLOBparty is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 08:44 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I dont have the wildpeaks but I do have the Wildpeak M/Ts in 285 (E). They fit on stock trail wheels (same offset as SR5s) after I removed the mudflaps. They only rubbed on compression full lock. Here's how it looks without mudflaps. You might not need to remove the flaps on the AT3Ws as they are just a tad smaller than the M/Ts
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 11:52 PM #3
MoonGoon762 MoonGoon762 is offline
MoonGoon762 is on a distinguished road
I think you could get the components for a real suspension lift for a pretty good price. Look for Bilstein 5100 and Wheelers T1/T13. Check to make sure the 285s will work on the stock wheel. Width might be off?
MoonGoon762 is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 10:02 PM #4
Thanks! The 5100s and t1/t3 looks affordable enough, 500-600. Plus whatever I need to have a shop install them... stiiiiiill don’t have a job tho so might have to hold off on spending that much and just stay on the highway....
Old 10-07-2020, 10:22 PM #5
Just know that if the tires don't fit prior to a lift, then it will likely rub after a lift when compressed. Especially offroad!
Old 10-08-2020, 11:38 AM #6
sparkyy192 sparkyy192 is offline
sparkyy192 is on a distinguished road
Rubbing isnt the only thing you should be concerned about. The SR5 wheels and the Trail wheels are the same offset, but different width. The SR5 wheels are technically too narrow for 285 width tires, as suggested by the manufacturers. Tire shops routinely ignore this, and offroad guys will mount 285s on even narrower rims...but you will be out of spec. Whether or not that matters to you is...up to you.
sparkyy192 is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 07:30 PM #7
vt100 vt100 is offline
vt100 is on a distinguished road
I've got wildpeak AT (LT) and had to do body mount chop to fit them cause even at the maximum caster they were rubbing quite a lot. Then of course trimming the front splash guard and the bumper. After that everything was fine for a while until I hit a trail When flexing suspension on a trail it chewed up this black plastic cover on the bottom of the fender along with the splash guard on the back Heated it up with heat gun and bent it in. And so far so good, no more rubbing
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
vt100 is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 07:37 PM #8
what wheels are you running? Thankfully I didnt have to trim the front as it was all cut off already for my Lopro bumper haha. I would rub on the flaps even on the street. Thankfully I just had to remove the flaps. No more rubbing when compressed to bumpstops. May change out to a 34 though so going to have to cut the body mount eventually
Old 10-08-2020, 08:03 PM #9
Hehe.. lucky you! ;) The C4 Lopro bumper is on my list but only after I get Gobi rack and rear bumper.
I'm on stock TRD off-road wheels. The mud flaps were gone right when I've got wildpeaks
Forgot to mention, I had to put wheel spacers on the front too because tires were rubbing against the Kings remote reservoirs at full lock. Got different (vertical) reservoir mounts but still need to weld in a couple of nuts on each side of the frame. And since I'm lazy I keep driving it with spacers for now
Old 10-09-2020, 12:36 PM #10
Well. Nothing like a load of information to keep me wondering wtf I should do... pro and con of having a rich community of experience! I still have life left on the current tires so I have some time to figure it out. Maybe I can look for trd wheels (not the 17x7s) that I can get used but money is still tight. Or, as a buddy suggested, flip the tires and buy the 265/70... located in NoVa and I know there’s a few of you nearby...
covid , it’s , off-road , rubbing , stock
WTB 1 stock 2012 SR5 rim bittwiddler For Sale: Suspension/Wheels/Tires 0 02-15-2014 08:57 AM
2012 LE - leftover stock, what to pay? flynnstone 5th gen T4Rs 16 11-28-2012 02:24 AM
Looking at purchasing new 2012 Limited 4x4 deal or no deal Revnitup 5th gen T4Rs 4 10-27-2012 11:31 AM
Getting a deal on a 2012 Trail? jerseygeorge 5th gen T4Rs 18 02-15-2012 12:41 AM
