10-08-2020, 11:23 AM
#16
Real Name: Ryan
Real Name: Ryan
Originally Posted by trapshot68
PDF from a service manual.
Good share. Was thinking there was probably something from the service manual.
10-08-2020, 03:32 PM
#17
Originally Posted by llDemonll
Hand brake isn't the issue. It's just how it's adjusted. 4Runner parking brake is terrible. Mine barely holds on what I would consider a moderate slope driveway. Semi-steep, but not steep. I have to park the nose way up near the garage to get the parking brake to take the weight of the vehicle instead of the transmission.
I’m crying for a handbrake to use while driving. Two foot driving doesn’t work well when brake assist kicks in.
10-09-2020, 10:53 AM
#18
Not even sure what you're asking for here. You want to do skids?
10-09-2020, 03:56 PM
#19
IIRC, you don't even need to take the tire off to adjust the parking brake, this would be a stupid thing to pay the dealer to adjust. If you have a flat blade screw driver, you should be able to adjust it yourself.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
10-09-2020, 06:05 PM
#20
Mine start to roll back as well but turning it to face down it held but backwards facing didn’t hold weird
Probably a poor design
Mike
10-09-2020, 06:10 PM
#21
I managed to manually adjust the parking brake on my 2016 T4R about 1.5 years ago using the star wheel adjustment and a screwdriver on the back wheels.
The adjustment did make a huge difference, and although it has loosened up again somewhat, it is much better now than it was from the factory.
In general, you should not need to make an adjustment to the cable from the middle console on the inside. You should be doing the adjustment from the back wheels only, unless there is something seriously wrong with your truck.
You basically just need to get the back tires off the ground, take off the tire, and find the small hole where you can access the star wheel with a screwdriver. Then you’ll adjust the star wheel tighter until you can’t turn the wheel by hand any longer. And then you’ll back off a few turns.
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
10-09-2020, 06:22 PM
#22
Subscribing to this. Good I go as mine doesn’t do anything unless it’s basically touching the floor.
10-09-2020, 10:24 PM
#23
10-10-2020, 01:24 PM
#24
Sometimes dragging the rears in 2wd is helpful. But mostly because a handbrake is easier to use while your feet are busy.
10-11-2020, 03:12 AM
#25
Banned
Real Name: Mark
Banned
Real Name: Mark
When I drove a front wheel drive in snow, the handbrake could be employed for some great skids, turns, slaloms, and doughnuts. Great fun. Cannot get quite the same effect with RWD or 4WD. And certainly not with a foot brake.
10-11-2020, 08:12 AM
#26
Real Name: Mark
Real Name: Mark
On my '10 TE I used the old-school brake adjustment technique we used for all cars with rear drums and it seemed to help. I had a sloped driveway, so I would back down the hill quickly and step on the parking brake hard until the vehicle stopped. Repeated a few times and each time it seemed to improve and take up the slack. Haven't tried it on the '20 yet as I no longer have a steep driveway.
In older vehicles, this was a common rear drum brake/emergency brake adjustment technique.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
10-11-2020, 11:55 AM
#27
Subscribed
06-28-2021, 05:51 PM
#28
I finally got around to taking the truck to Toyota. They said they adjusted the parking brake shoes in a bit and it feels much better now. Hopefully it stays adjusted this way. It actually holds on my steep driveway now.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
06-29-2021, 01:17 PM
#29
Real Name: Ryan
Real Name: Ryan
Might try giving mine an adjustment later today or tomorrow. Definitely still soft. Interestingly, I drove my fathers 17 ORP, parking brake holds super strong. He says it always has.
06-30-2021, 09:34 AM
#30
I have a feeling the cables have too much slack from factory. instead of adjusting the cables the dealers just bring the pads in closer which works until the pads wear down from being too close.
The only way to get mine to mostly hold is having the pedal to the floor and that’s after the dealer adjusted it. One of these days I’ll pull the center consol you do a proper adjustment.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
