Old 10-08-2020, 11:23 AM #16
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Originally Posted by trapshot68 View Post
PDF from a service manual.
Good share. Was thinking there was probably something from the service manual.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 03:32 PM #17
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Originally Posted by llDemonll View Post
Hand brake isn't the issue. It's just how it's adjusted. 4Runner parking brake is terrible. Mine barely holds on what I would consider a moderate slope driveway. Semi-steep, but not steep. I have to park the nose way up near the garage to get the parking brake to take the weight of the vehicle instead of the transmission.
I’m crying for a handbrake to use while driving. Two foot driving doesn’t work well when brake assist kicks in.
1000MPH is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 10:53 AM #18
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Not even sure what you're asking for here. You want to do skids?
llDemonll is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 03:56 PM #19
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
IIRC, you don't even need to take the tire off to adjust the parking brake, this would be a stupid thing to pay the dealer to adjust. If you have a flat blade screw driver, you should be able to adjust it yourself.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 06:05 PM #20
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
Mine start to roll back as well but turning it to face down it held but backwards facing didn’t hold weird
Probably a poor design
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 06:10 PM #21
the_economist's Avatar
the_economist the_economist is offline
the_economist will become famous soon enough
I managed to manually adjust the parking brake on my 2016 T4R about 1.5 years ago using the star wheel adjustment and a screwdriver on the back wheels.
The adjustment did make a huge difference, and although it has loosened up again somewhat, it is much better now than it was from the factory.
In general, you should not need to make an adjustment to the cable from the middle console on the inside. You should be doing the adjustment from the back wheels only, unless there is something seriously wrong with your truck.
You basically just need to get the back tires off the ground, take off the tire, and find the small hole where you can access the star wheel with a screwdriver. Then you’ll adjust the star wheel tighter until you can’t turn the wheel by hand any longer. And then you’ll back off a few turns.
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 06:22 PM #22
SoCalTRD SoCalTRD is offline
SoCalTRD is on a distinguished road
Subscribing to this. Good I go as mine doesn’t do anything unless it’s basically touching the floor.
SoCalTRD is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 10:24 PM #23
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
5th gen Toyota 4Runner rear parking brake adjustment - YouTube
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 01:24 PM #24
1000MPH's Avatar
1000MPH's Avatar
Sometimes dragging the rears in 2wd is helpful. But mostly because a handbrake is easier to use while your feet are busy.
Old 10-11-2020, 03:12 AM #25
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
When I drove a front wheel drive in snow, the handbrake could be employed for some great skids, turns, slaloms, and doughnuts. Great fun. Cannot get quite the same effect with RWD or 4WD. And certainly not with a foot brake.
Old 10-11-2020, 08:12 AM #26
00Sebby's Avatar
00Sebby 00Sebby is offline
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
00Sebby's Avatar
Real Name: Mark
On my '10 TE I used the old-school brake adjustment technique we used for all cars with rear drums and it seemed to help. I had a sloped driveway, so I would back down the hill quickly and step on the parking brake hard until the vehicle stopped. Repeated a few times and each time it seemed to improve and take up the slack. Haven't tried it on the '20 yet as I no longer have a steep driveway.
In older vehicles, this was a common rear drum brake/emergency brake adjustment technique.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 11:55 AM #27
ctyslkr ctyslkr is offline
ctyslkr is on a distinguished road
Subscribed
ctyslkr is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 05:51 PM #28
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
I finally got around to taking the truck to Toyota. They said they adjusted the parking brake shoes in a bit and it feels much better now. Hopefully it stays adjusted this way. It actually holds on my steep driveway now.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 01:17 PM #29
Real Name: Ryan
Real Name: Ryan
Might try giving mine an adjustment later today or tomorrow. Definitely still soft. Interestingly, I drove my fathers 17 ORP, parking brake holds super strong. He says it always has.
2001 BMW M5
Old 06-30-2021, 09:34 AM #30
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
I have a feeling the cables have too much slack from factory. instead of adjusting the cables the dealers just bring the pads in closer which works until the pads wear down from being too close.
The only way to get mine to mostly hold is having the pedal to the floor and that’s after the dealer adjusted it. One of these days I’ll pull the center consol you do a proper adjustment.
Cndnmax is offline   Reply With QuoteReply With Quote
brake , parking , soft , star , tightening
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Parking brake not holding after rear brake job 4OYOTER 5th gen T4Rs 6 10-06-2017 11:04 PM
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Emergency Brake - tightening Up michael90630 4th Gen T4Rs 1 12-06-2007 12:42 AM
