Old 10-08-2020, 04:10 PM #1
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Have You Opened KDSS Shutter Valves While Performing Suspension Work?
I’m about to install a mild lift on my 2011 Trail with KDSS. My local performance lift shop does a lot of work for Toyota dealers, and I was hoping they would do the install, however they refuse to touch 4Runner KDSS accumulator shutter valves and they also refuse to do anything if the vehicle ever leans to one side after the install. They will adjust lean on a Land Cruiser, but not a 4Runner, saying the latter KDSS system cannot be balanced.
I’ve read a lot of forum posts and how-to’s by Toytec, Bilstein, Fox … it appears Dobinson is the only one to recommend opening KDSS shutter valves during any and all suspension work. Has anyone on this forum followed these instructions for front/rear suspension work?
File Type: pdf KDSS-Instructions-4Runner-Exit-Offroad.pdf (435.5 KB, 236 views)
DougR is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 04:51 PM #2
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
When I did my initial install (2.5" front / 2.0" rear) I did NOT open the shutter valves. What I did do is throw the truck in 4lo as I pulled into the garage, supposedly that opens the system. Before the rear coils settled I still had some significant lean. I used the Dobinsons KDSS coils to have built in offset for lean compensation.
Install was pretty easy, I did use ratchet straps up front to line everything up for assembly - see the Dobinsons thread for a bit more info.
After about 1,000 miles I had a minor amount of lean and decided to open the shutter valves. I follow the instructions to a T and it seemed to help just a little. I'm now perfectly level in the rear and approximately 3/16" difference up front (I've measured 1/8" and 1/4", depends on gas I think, so we'll split hairs lol).
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 05:23 PM #3
vt100 vt100 is offline
vt100 is on a distinguished road
I was following King's instructions to every letter when installing mine. They explicitly mentioned that there is no need to touch KDSS. I didn't even detach the front sway bar.
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
vt100 is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 05:52 PM #4
DougR's Avatar
DougR's Avatar
Originally Posted by Sundy View Post
... What I did do is throw the truck in 4lo as I pulled into the garage, supposedly that opens the system...
KDSS valve/accumulator assembly has electrical inputs, so I'm wondering what happened when you turned the engine off with the transfer case still in 4Lo. Perhaps KDSS reengaged when the valves returned to a default position with the ignition off?
Old 10-08-2020, 06:23 PM #5
I'm not sure - another member had posted it here that it seemed to be softer for him (he has taken things apart a few times) so I figured it can't hurt to try.
Old 10-08-2020, 06:29 PM #6
4hashiro 4hashiro is offline
Real Name: Rico
4hashiro is on a distinguished road
Real Name: Rico
I just did my 3" lift this past weekend. I did not touch the valves. You mentioned you're doing a mild lift, I changed out my UCA so it was quite simple. As long as you undo either of the control arms I dont think you will have a problem getting anything short of 3" in. The main KDSS lift thread writeup install does it by undoing the LCA, but a lot of posts in between found it easier to do the UCA.
18 MGM TRDOR: ARB classic rack, C4 ladder/ Front - Toytec 3" Non adjustable, JBA uca, Toytec diff drop/ Rear - Toytec Aluma 2.0 shocks, Superflex HD coils, KDSS drop brackets/ Toytec 1" BL, SCS SR8 et-10 17x8.5, Toyo RT 315/70r17, BMC/ Pedal Commander, TRD CAI, URD Y pipe, Borla Type-S
00 ltd elocker(sold): F tundra 5100's eibach 620 R lc 7.5 wraps tokico blacks, 1" toytec bl, pro comp 69's yoko MT's 285/75r16, jba offroad uca, toytec diff drop, 231mm tbu
4hashiro is offline   Reply With QuoteReply With Quote
kdss , shutter , suspension , valves , work
TRD Pro Fox suspension on KDSS? bigbadpoppa 5th gen T4Rs 2 09-14-2020 04:32 PM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
best performing Spark plug for 2008 4.7L V8?? swegen 4th Gen T4Rs 4 06-30-2016 11:09 AM
Budbuilt rock sliders work with KDSS? heron163 5th gen T4Rs 7 06-23-2014 12:44 AM
LSD not performing as hoped brw1994 Classic T4Rs 14 09-06-2012 08:16 PM
