Old 10-10-2020, 10:42 AM #16
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
So far so good on my WildPeaks. They look so much better in person.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 11:36 AM #17
blschaefer1 blschaefer1 is offline
blschaefer1 is on a distinguished road
Had Wildpeak AT3W’s installed last week on my new ‘20 ORP. Changed stock wheels to TRD SEMA’s. Stock 265/70/17 size. Made in USA. Balanced great. No rubbing issues even at full lock reverse as others have mentioned.
Went off roading the next day, tires were great. Two days later, embarked on a three state road trip to Moab and Western Colorado. Still on that trip. Tires are great on pavement, quiet and comfortable. Averaging 20.8 mpg.
Running 34 psi cold. Might try bumping to 36 psi.
Very happy with these tires.
blschaefer1 is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 12:41 PM #18
Black-X Black-X is offline
Black-X is on a distinguished road
Almost clicked the order button on the Falkens but looks like General is running a $100 rebate so that tipped the decision over to the ATX’s. Sounds like it’d be hard to go wrong either way, thanks all!
Black-X is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 01:04 PM #19
rhadam's Avatar
rhadam rhadam is offline
rhadam has a spectacular aura about rhadam has a spectacular aura about
rhadam's Avatar
I have stock size Wildpeak AT3, and I love them. They look aggressive on the truck and fit the wheel well nicely with my lift. So far i've put almost 8k miles on them and they are wearing nicely. Road noise isn't too bad. Realistically i'd simply look at pictures and compare in person which "look" you like best. Can you get one cheaper and you like both? Go with the sale. When these wear out i'm sticking with Wildpeak and going up to 275 or 285 (depending if I do a bumper chop). I guess that says a lot if you go back to the brand for future purchases.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
rhadam is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 06:29 AM #20
El Gavilan El Gavilan is offline
El Gavilan is on a distinguished road
I put a p265/70/75 of the Grabber ATX about 3K ago. We drove down to Flordia from MD last week. Averaged 18.8 mpg cruising 70-75mph the whole way. No problems with the tires. Balanced well, tracked straight, weren't noticeably loud. On the way up we hit some intense rainstorms never felt uneasy in the wet.
I had run the same size Falkens on my Xterra and was equally impressed. I was going to go with Falkens again but General was doing a $100 rebate last month. Can't say much more about the Grabbers since they are still really new.
El Gavilan is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 11:05 AM #21
PNWMike PNWMike is offline
PNWMike is on a distinguished road
Originally Posted by Baystate4Runner View Post
Mine are Made in USA - no balancing problems or vibrations.
Ditto.
PNWMike is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 11:56 AM #22
theothereng's Avatar
theothereng theothereng is offline
theothereng is on a distinguished road
What PSI did you run on the Grabbers?
2017 TRD Off-Road | Magnetic Grey
Bilstein 5100s| OME 17mm Rear Spacers| OEM Running Boards| Hella Sharptones| Husky Liners
theothereng is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 05:37 PM #23
I think 36psi. I got them put on two days before we took off to visit my in-laws so whatever the shop installed them with.
Old 10-12-2020, 10:42 AM #24
tantrum007 tantrum007 is offline
tantrum007 is on a distinguished road
I have had both and I think the wildpeaks are the best tires ive ever ran in wet conditions but I think the Grabber looks better.
tantrum007 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 02:22 PM #25
RunTheJoules's Avatar
RunTheJoules RunTheJoules is offline
Real Name: Tyler
RunTheJoules is on a distinguished road
Real Name: Tyler
Originally Posted by Black-X View Post
Looking to get some new shoes for my 2020 Venture and can’t decide between these 2. I have a 2020 Venture with the TRD rims and was curious what you all would get and if there’s any pros/cons to either?
Going stock size and the truck is used mostly on the road with occasional off-road (just got back from 4x4 beach in NC a couple days ago) by the way.
I have a Venture as well, and went the Grabber ATXs in stock size. They're my first A/T, so I don't have anything to compare them to, but I have absolutely zero complaints. I think they look better than most other A/Ts personally, but that's subjective. Haven't had the chance to try them out in snow, but traction on everything else has been excellent. Also, they're only 3lbs heavier than the stock tire which is a huge plus if you're concerned about adding more rotating mass. Plus, they're about as quiet as the stock Duelers on the highway, and no issues with balancing.
The only "con" is that you will have to do the fender mod and a little bit of trimming to keep them from rubbing up front, when in reverse. It's the offset of the TRD wheels that cause this issue, so you can probably avoid the trimming by switching wheels. But trimming is quick and easy(and free), and also not noticeable by anyone unless you're specifically looking inside the wheel well towards the front.
22 TuRDPro
RunTheJoules is offline   Reply With QuoteReply With Quote
road , size , stock , truck , venture
General Grabber X3 tires ecr6cyl10 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 09-04-2017 06:17 AM
New Tires AT3 v General Grabber AT2 Frdmskr 3rd gen T4Rs 12 02-24-2015 07:52 PM
For sale general grabber at2 tires nistecmec For Sale: Suspension/Wheels/Tires 0 08-05-2011 08:10 PM
General Grabber AT 2 and other tires---> 2005 SPT V6 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 02-19-2007 02:02 AM
