Old 10-11-2020, 10:23 PM #1
PCMSF PCMSF is offline
PCMSF is on a distinguished road
275/70/17 Wildpeaks on stock suspension, will they rub?
Hi, I'm looking at new tires and wheels and leaning towards 275/70/17 Falken Wildpeaks. The specs show them to be a "big" 275 at 32.4in diameter, kind of in-between a 275 and 285 when compared to more standard sizing. So after a bunch of searching it seems like a lot of the advice on here about going bigger is tough to apply to these specific tires.
Anyone running 275 Wildpeaks with stock suspension and if so, any issues with rubbing?
For wheels, I'm eyeing the Relations Race Wheels RR5 17"x8.5" in 0 offset (if they come back in stock soon as promised). Motegi Trailites MR150 are looking like solid, cheaper backup option.
Fwiw, I've been running 18"x9" wheels with 32.13" Cooper ATs for a few years with no rubbing. Previous owner installed, and it's about time to replace tires so I'm taking the opportunity to do it all and go back to 17s.
PCMSF is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 10:31 PM #2
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
I have 265/70r17 and they are significantly larger than your standard 265's, so I'd say they probably will.
osideplayer is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 10:47 PM #3
Thanks, are your 265s rubbing at all?
Old 10-11-2020, 10:52 PM #4
AU TRD AU TRD is offline
Real Name: Hart
AU TRD is on a distinguished road
Real Name: Hart
I've run these tires on my stock '16 Trail for 15,000 miles. I rub on the driver's side fender liner at full lock in reverse. Occasionally I hit the mudflaps if I'm turning and hit a bump.
2016 MGM TE w/ KDSS | Eibach Pro-Truck w/ JBAs | 275/70/17 Wildpeaks
AU TRD is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 09:06 AM #5
Yea I had to do the fender mod for them
Old 10-12-2020, 10:39 AM #6
tantrum007 tantrum007 is offline
tantrum007 is on a distinguished road
Mine did =(
tantrum007 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 02:31 PM #7
For those that had rubbing on the 275s, what did you have to do to minimize rubbing? Fender-liner/mudflaps or did you need a lift?
I'm open to a small front lift but aiming to keep suspension as close to stock as possible.
Old 10-12-2020, 03:13 PM #8
z32-z33 z32-z33 is offline
z32-z33 is on a distinguished road
I have Falken wildpeak at3w in 275/70/17 on Trd Pro wheels 4mm offset. All I needed to do was move the liner forward and trim a small portion of the front bumper, doesn't rub on the mud flaps on road or off.
I do have a 2.5inch front lift and Jba UCA with close to 5 degrees of caster, so YMMV.
z32-z33 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 09:16 PM #9
Thanks y'all, really helpful!
Old 10-12-2020, 09:56 PM #10
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by tantrum007 View Post
Mine did =(
Add me to the list. I removed the mud flaps anyway but did not do the fender mod. There was slight rubbing, one tire only.
It is not that the P265s are tall--they are actually short--it is that they are extremely wide for a 265. They are as wide as many 285s. The LT 265 are taller than the P version.
My current 265 MT ATZ P3 are much taller than the P265 Wildpeaks (full 32") but they do not rub.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 02-13-2021, 05:16 PM #11
Installed today: confirmed that they rub! Mild rub on small section of mudflaps when slow turning.
I have a 1" lift on front AND I did the fender liner mod and bumper trim so no rubbing in front of the tires.
Getting an alignment on Monday with max caster and hoping that does the trick.
Was it worth it? Yep! These tires look and feel awesome.
Old 02-13-2021, 05:32 PM #12
knappster007 knappster007 is offline
knappster007 is on a distinguished road
I have these on a stock 2021 off road premium and they do not rub.
knappster007 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 05:56 PM #13
????? ????? is offline
????? will become famous soon enough
Mine only kissed the mudflap while in reverse and I mean BARELY touched them.
Get an alignment to adjust them accordingly if needed.
????? is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 06:08 PM #14
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Yes they will rub.
Messing with the alignment to the point of it handling squirrelly so they don’t rub is not the answer.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 07:59 PM #15
The alignment is for the lift I just installed.
Will try heating and pressing the mudflaps with the heat gun or just removing them if that doesn't work.
275/70/17 , stock , tires , wheels , wildpeaks
Got a deal on 285/70/17 wildpeaks, will they fit on stock 2012 sr5? GLOBparty 5th gen T4Rs 9 10-09-2020 12:36 PM
Falken Wildpeaks A/T3w 275/70/17 Chrispapp Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-09-2020 10:38 AM
No Falken Wildpeaks in 275/70-17? Or go with 285? 3s1kill 5th gen T4Rs 22 03-16-2018 08:27 PM
FS - 4th Gen Stock Suspension Parts (Stock and After Market) - San Diego, CA TheRockShow182 For Sale: T4R Items 1 02-15-2017 04:04 PM
Spidertrax 1.25" - Stock 2000 Suspension - 265/75/16 on stock 5 stars... SlickmisterN 3rd gen T4Rs 3 01-24-2015 05:38 PM
