Real Name: Kirk
Real Name: Kirk
Originally Posted by pixjohn
I already Installed a system before, and this system is 95% already up and ruining I think the setup will be fine. As per the jump, I am only considering it since I have the stuff and the cost is already paid for. Redarc sells its solenoid that can be used for this purpose already. I just wanted to see if the national Luna product could do the same thing. I plan to add a gauge for Amp level. The system itself was easy to install. I just need to connect the blue wire and not sure what method I should use.
Redarc - installed and running
Solar - installed and running
Mounting plate - needs to be changed, gets to hot.
Blue wire - needs to connect.
I agree with the posts above...but you asked.
On the fuse panel up under the dash, there is a fuse marked IGN.
put an ADD -A- Circuit in there and connect the blue wire. It carries very little in the way of AMPS. It is a trigger circuit.
An added note: I run a similar setup with the RedArc. DO NOT cut corners on fusing. DO NOT allow wires to just flop loose under the hood.
A nice clean, thoughtful and fused system is a safe system.
Good Luck
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
