Old 10-12-2020, 04:57 PM #1
pixjohn pixjohn is offline
pixjohn is on a distinguished road
redarc1225D Dual battery
I posted this to a similar topic, but recived no responces so I am posting to a new thread.
I am installing the redarc1225D and removing my Nantional Luna dual battery system, that never worked right with the 4runner system. I need to run a wire to power the unit, I need to run the blue wire to an ignition power source. Not sure if I should use a fuse tap and what to tap into? or splice into something like the daytime running lights that has power? I will also be installing solar to my system. I linked a great youtube video where he used an older solenoid system similar to the National Luna to use as a jump starter. I would love to have my system to have that option. I built a tray, but now relize the aluminan tray holds the heat. I need to either cutout holes to vent more or add washers to raise it off the tray.
Redarc BCDC 1225D and SBI12 solenoid install in Prado 150 - YouTube
start at 3:41
redarc1225D Dual battery-redarc-jpg  redarc1225D Dual battery-redarc2-jpg
pixjohn is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 05:48 PM #2
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Not trying to be a dick, but you may have bitten off a bit more than you can chew doing a diy battery system if you can't find an ignition switched power source.
I'm a master electrician, and work on lots of multi battery systems. Dual battery setups are no joke, and if you don't know what you're doing it's not hard to get yourself into a lot of trouble that could result in a fire.
Youtube can be a good source of info, but it absolutely does not replace hands-on experience. I'd suggest you find a shop that specializes in this sort of thing, if for no other reason than to give yourself some peace of mind that your install won't burn your truck down.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 05:42 PM #3
benhalleniii benhalleniii is offline
benhalleniii is on a distinguished road
I would echo Jono.ful’s response here. I have a similar setup using the Redarc but opted not to have a push button jump start option. It’s way cheaper and easier to just keep a set of cables in the truck and jump it if you need to. But, if you’re using the Redarc correctly the idea that you’d need to jump start your truck at some point is pretty remote.
I’d also say that I did all of my own install mainly because I wanted to learn how everything worked so that I could fix it myself in the field. This meant that my install took a long time and cost WAY more that it would had I’d paid someone to do it.
Bottoms line: if you want to learn it then plan on spending lots of time and money. If you just want it to work so you can enjoy
It then pay someone to do it.
And good luck!
2017 TRD Off Road
benhalleniii is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 06:24 PM #4
I already Installed a system before, and this system is 95% already up and ruining I think the setup will be fine. As per the jump, I am only considering it since I have the stuff and the cost is already paid for. Redarc sells its solenoid that can be used for this purpose already. I just wanted to see if the national Luna product could do the same thing. I plan to add a gauge for Amp level. The system itself was easy to install. I just need to connect the blue wire and not sure what method I should use.
Redarc - installed and running
Solar - installed and running
Mounting plate - needs to be changed, gets to hot.
Blue wire - needs to connect.
Old 10-15-2020, 10:04 PM #5
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
I agree with the posts above...but you asked.
On the fuse panel up under the dash, there is a fuse marked IGN.
put an ADD -A- Circuit in there and connect the blue wire. It carries very little in the way of AMPS. It is a trigger circuit.
An added note: I run a similar setup with the RedArc. DO NOT cut corners on fusing. DO NOT allow wires to just flop loose under the hood.
A nice clean, thoughtful and fused system is a safe system.
Good Luck
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 10:20 PM #6
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
Just buy an Add a circuit from your local automotive store and run it through the grommet and into the fuse block located under the steering wheel panel. If you do that, make sure you find a place to secure the fuse cover as it will not snap back into place. If you want to tap into an ignition circuit without going through into the cabin then perhaps you can find/test a circuit that turns on with the ignition and use that.
Good luck with your installation.
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
bring_it_on is offline   Reply With QuoteReply With Quote
luna , power , run , system , tray
Dual Battery Vs. Portable Battery nick_rabbo 4th Gen T4Rs 29 05-23-2022 12:39 PM
Help with Dual Battery setup Redarc1225D SnoRnR 5th gen T4Rs 35 06-24-2021 11:09 AM
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual Battery Planning, Dual Group 31s mikeySA 3rd gen T4Rs 10 11-04-2017 04:25 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
