Old 10-19-2020, 03:19 PM #16
TheHolyCannoli TheHolyCannoli is offline
TheHolyCannoli is on a distinguished road
Originally Posted by mo_mo View Post
The locker light does not display during the startup dash light check.
If, with the vehicle on, you are in any transfer case position and any transmission position (eg. two high park), and press the locker button then it should begin flashing until it engages (shift to four low and crawl a bit with slight turning or the locker button is depressed).
Thanks for the confirmation. Not really sure what's going on then. If the locker and overhead button are mechanically functioning correctly to engage/disengage the locker, what else would cause no indicator? I hate the thought of having to pull the gauge cluster just to check the bulb. Is there a fuse somewhere that could be blown and prevent the light from working but still allow the locker to function?
TheHolyCannoli is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 04:14 PM #17
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
No, the entire dash wouldn't work if a fuse is blown. Best bet is to pull the cluster and check the bulb at this point
llDemonll is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 05:24 PM #18
Looks like a weekend project. If I F something up, I don't think I can drive to work with without an instrument panel.
Coincidentally, as I'm looking at some threads showing how to take it apart, I think I may have other bulbs out. My tachometer and speedometer are very dim towards the top half, even with the dimmer switch at full power. Either that, or the thread pictures are making it look brighter than it really is.
Old 10-20-2020, 06:54 AM #19
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Side note / question.
Are there any tricks to get the rear locker to engage / disengage quickly?
I know forward movement is required but it seems like there is a lot of lag between hitting the button, engagement, and disengagement.
I guess I'm curious as to what the parameters are for engagement / disengagement of the rear locker.
4Low is a given.
Does it take so many wheel rotations?
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 09:21 AM #20
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
4Low is a given.
Not really, it just has to line up correctly for the locking mechanism to fall into place. Sometimes it clicks right in, sometimes you have to crawl forward and back for it to line up.
I have noticed, however, that the more you use 4wd and the rear locker, the easier and quicker they engage. I don't know if there's any real merit to that, but it seems to be like a "use it or lose it" deal.
Muff Muff is offline   Reply With QuoteReply With Quote
4lo , abs , light , locker , symbol
Issues engaging e-locker DK327 3rd gen T4Rs 24 02-18-2022 06:56 PM
E-Locker not engaging after axle bearing replacement Cmayer 3rd gen T4Rs 6 07-08-2020 12:40 PM
Engaging Rear Locker Langzaiguy 5th gen T4Rs 9 02-17-2015 09:45 PM
Center differential light flashing and not engaging please help mr.nugen 4th Gen T4Rs 20 08-28-2014 04:21 PM
locker not engaging northfwestg 3rd gen T4Rs 7 12-05-2011 11:42 PM
