10-19-2020, 05:24 PM
#16
Real Name: Chris
Real Name: Chris
Originally Posted by gringo8251
I saw a post on the 4th gen forum about NTK FabWorks body mount relocate kit while I was researching BMCs. I looked up the IG account and followed to get an idea of the work. Nick's metal work is great and he was just down the road in NC a couple of hours. Seeing the very good work he does online gave me confidence to buy from NTK and discuss install. Nick recommended another fab guy in VA to do the install to save me the drive but that guy had relocated. In the end, I'm very happy I took it to him. Quality work and there were certainly details he was aware of as a professional welder that I would have missed if trying to do this DIY.
Best way to go.
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
10-19-2020, 07:43 PM
#17
Originally Posted by SpeedyKevin
One guy (Svein?) I think runs 37s with it.
Post #20
37s
10-19-2020, 10:15 PM
#18
Real Name: Zach
Real Name: Zach
Originally Posted by GripT4R
Thats just a BMC with extra steps.
To each their own man. There's quite a bit more clearance than a BMC. That said, BMCs obviously work...hence so many being done.
2017 ORP, 3" lift, Icon UCA, 34s, NTK Fab body mount, angle grinder bumper cuts, RSG sliders, 4.56 gears, Front & Rear E-lockers
1985 CJ-7, 4" lift, 35s, fully locked, fun to drive offroad
10-19-2020, 10:25 PM
#19
Real Name: Zach
Real Name: Zach
Originally Posted by JSparky
Nice work. It yields more clearance, I’ll be doing this in the near future.. with 35’s you need all the clearance you can get. For 33’s it’s really unnecessary.
My thoughts exactly. I was rubbing in a few places on 33s when on trails in Washington & Jefferson Nat'l Parks recently. I know there will be plenty more trimming and adjustments needed on 35s. At least this is one thing I know I won't need to readdress.
10-20-2020, 01:55 AM
#20
Banned
Banned
Im not wrong though. Thats literally a BMC with extra steps.
10-20-2020, 10:42 AM
#21
i have a bmc on 34s pretty sure i have space for 35's.
i think i need a relocate if i went up to 37s.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
10-20-2020, 10:46 AM
#22
I've got 37's and just a somewhat aggressive standard body mount chop. Haven't even plated it back together. Got me through the Rubicon trail so I guess it works.
10-20-2020, 11:01 AM
#23
Says a non-5th Gen.
10-20-2020, 02:46 PM
#24
Originally Posted by WeedKillrr
Says a non-5th Gen.
The 5th gen must have a different design than the 4th gen's body mount.
The 4th gen's body mount is made from steel and we trim them to make clearance for bigger tires.
10-20-2020, 04:25 PM
#25
The 5th gen must have different wheel well dimensions and orientation of components within them or they'd be called a 4th gen.
It must be nice to only have to trim your body mount and not need to add +2 LT.
10-20-2020, 05:04 PM
#26
You don't think they share the same frame dimensions?
J120/J150 Platform: A Better Body Mount Chop?
With 37's it helps to have the +2", but I've seen it done without. That truck also made it through the Rubicon.
With you guys talking 34's or 35's it should be easy to fit without needing to relocate the body mount. If you want to relocate for aesthetics you can sure go for it, but it's not necessary.
10-20-2020, 08:57 PM
#27
blah blah blah aggressive BMC = able to fit 37's blah blah
You heard it here first!
However, there are plenty of guys running around with 5th gens on 35's with little more than a lift, BMC, and proper offset wheels
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
10-20-2020, 11:07 PM
#28
I've been stalking your build for a while! I think this is a great mod for those going bigger. BMC definitely works but this opens up so much clearance.
Wow! Thanks!
I really considering this. Bet I can knock it out in my driveway!
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
10-23-2020, 08:50 PM
#29
Real Name: Zach
Real Name: Zach
I like how dudes jump on this thread and start making claims about things that were never said. Never said anyone was wrong about doing a BMC. Never said you had to do BMC on a 5th gen to go up in tire size. I did say there are many different ways to attack clearance issues. I also did a body mount chop without any welded plates for a while, guess what...it works. There are many different ways to attack pretty much every problem on the 4Runner. This how I decided to do mine and wanted to share a small businessman's work.
Troll elsewhere.
