Old 10-17-2020, 08:41 PM #16
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I am not sure why you said a lift does not gain in ground clearance. My limitation is my front skid and a lift did wonders to change from hitting everything to only hitting the front skid occasionally. Stock size tires are plenty big, plenty heavy and plenty hard to balance as they are. No need to go to larger tires. Get a modest lift and good off road LT tires. Thats my 2c
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 08:58 PM #17
Ehahn84's Avatar
Ehahn84 Ehahn84 is offline
Ehahn84 is on a distinguished road
Ehahn84's Avatar
I ran the factory size Wildpeaks for a long time before doing my life. Worked perfectly fine and got me everywhere I needed to go. Wife purchased me some Bilstein 5100 shocks and I put them in with the factory springs and only lifted the front on the first perch (.85”) and love it. It’s a little taller but the nose dive is gone when braking. Nothing gaudy.
Long story short, factory Wildpeaks will be great but lift it if you want to look cooler.
Originally Posted by kaitlyn2004 View Post
Reassuring to read - thanks! Yep, the overwhelming discussion of WANTING to just mod, or doing mods for things to look good, etc. etc... gets very confusing and noisy info for my discussion making.
Naturally the easiest solution is wildpeak in stock size. At stock size on stock wheels, there SHOULD be zero chance of any rubbing, no?
Is there a reason you swapped out the wheels? And just curious, given you made the switch, why did you stick to stock vs maybe a modest 275 or even a different profile?
And your usage seems similar to me - any offroading I might be doing is usually followed by hour(s) of pavement or casual gravel driving that ANY car can do.
And yes, I am looking at full skid protection (1/4" aluminium, not steel). What is your protection looking like? I THINK stock is only engine - looks like RCI's "full kit" is engine, transmission, transfer case. It seems others don't seem to do a transfer case skid? Then there are other skids for some different areas? So overwhelming and as a non-car person, I am also not positive on where some of these other things are even located haha
2017 TRD Off-Road Premium. Magnetic Grey. Dual Odyssey battery setup. Falken Wildpeak AT3W. Diode Dynamics SS3. Rigid Dually Spotties.
Ehahn84 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 09:07 PM #18
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Technically speaking, lifting an ifs and keeping the stock size tires only provides extra clearance if the suspension isnt compressed. Still useful for most cases though
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 09:49 PM #19
If you just intend to drive mainly on fireroads, I think Front (engine) and fuel will suffice. If you start getting technical with some boulders, it doesn't hurt to add the others like transmission and transfer case. If doing even more technical, consider lower link and rear diff skids. My rear diff skid saved me from a hard hit (took a chunk of steel off the skid lol).
Old 10-18-2020, 01:16 AM #20
thirteen thirteen is offline
thirteen will become famous soon enough
I only swapped out the wheels for looks. I just don't like shiny wheels, I got black ones. My wheels are offset and stick out a little, which made the 265 size tires rub. 275 would have been even worse. My skid plates are totally stock. I may add some more protection some day, but these have gotten me through some rough terrain.
This is mine.
thirteen is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 11:12 AM #21
uh0h50 uh0h50 is offline
uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about
Go stock 265s and be done with it. Don't forget to do the spare as well.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
lift , size , stock , thinking , tires
stock tire size? itsgt Classic T4Rs 3 06-10-2022 11:33 AM
stock tire size? SierraDan 4th Gen T4Rs 4 11-14-2013 01:03 AM
Actual mileage traveled after tire size upgrade ryankmasuda 3rd gen T4Rs 19 04-24-2012 08:40 AM
Max Stock Tire Size KeeneState83 4th Gen T4Rs 4 09-18-2011 08:05 AM
