Old 10-14-2020, 10:03 AM #1
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Portable Power Stations
What portable power stations are you using and your thoughts?
I have a Goal Zero Yeti 400. It is ok for my camping needs, but looking to upgrade to something that lasts longer before recharging. Prime Day has Jackery and BALDR brands on sale, anyone familiar?
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 10:22 AM #2
Hutch4r Hutch4r is offline
Hutch4r is on a distinguished road
Check out lionenergy.com I'm a dealer and if you see something that will work for you hit me up. I'll hook you up.
Hutch4r is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 11:04 AM #3
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
I bought a Jackery 240 a while back to add inline to my 12V fridge wiring. I am powering a Dometic CFX-28 and it works great. Now I use my OEM fridge switch to charge the Jackery while moving or let it charge off my deep cycle for a while when parked. It doesn't take long for the Jackery to come back to 100% once the fridge is cooled down and starts to cycle. I also have one of their 60w solar panels that I can throw on the dash and plug into the Jackery. Pass through charging is a nice feature, its really a lot of bang for your buck as in the past you would need a charger controller and inverter to have all the same functionality.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 11:40 AM #4
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
I've got a Jackery 500 and their Solar Saga 100w panel. Works great to run the fridge and whatever else needs powering while camped. The Jackery recharges off the 120v inverter in the truck while driving and the solar if we're parked long enough to deploy it. Fridge just runs off the Jackery and it works great.
At some point I'll backfeed my aux fuse box off the Jackery so it powers whatever other accessories are wired in the truck if needed but really the fridge is the most important.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 11:43 AM #5
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
I am not in the market for any power stations but consider the recharge lifecycle of most lithium ion batteries is approx 500 recharge cycles or about 2-3 years of average use before they degrade to the point where it barely holds a charge. If you want something with higher recharge cycles you should look into lithium iron phosphate (LiFePo4). For example the Dometic PLB40 is based on LiFePo4 batteries however it does not have a 110v port. These types of batteries should last approx 10 years of average use while maintaining near full capacity.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 12:35 PM #6
Mudhorn's Avatar
Mudhorn's Avatar
How many hours are you powering the fridge when only on the Jackery power (at camp) at night (no solar available)?
Old 10-14-2020, 12:36 PM #7
Mudhorn's Avatar
Mudhorn's Avatar
Thanks, I will look at the brand.
Old 10-14-2020, 12:47 PM #8
TRUSTYAXE's Avatar
TRUSTYAXE's Avatar
I have not stayed anywhere overnight yet, been a kinda stupid year and its been stupid hot down here. So I can't provide any real data there. But going from a warm fridge (109 deg out) to 34 degrees and maintaining it for around 4 hours pulled the little 240 down to around 80%.
Old 10-14-2020, 01:08 PM #9
Cajun_TRD's Avatar
Cajun_TRD Cajun_TRD is offline
Cajun_TRD is on a distinguished road
Cajun_TRD's Avatar
I'd steer clear of Goal Zero. I have a number of their products and they have turned out to not be very rugged or dependable. JMO. I use mine for family camping trips, not some hardcore offroad expedition stuff and it has not held up well.
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
Cajun_TRD is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 01:19 PM #10
With the Jackery 500, based on discharge rates I've measured, my 50 qt ARB should run for about 42-43 hours without any sort of charging input. That's with the fridge set at 33F and normal open/close activity to dig for stuff.
Gone
Old 10-14-2020, 01:20 PM #11
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
I have a Rockpals 330W. I chose not to get a bigger option so that it could charge by solar fully within one day, and it does. I ran my fridge for 3 weeks on a trip this September and never had an issue with it. It also recharges off a cigarette lighter just as quick as solar, so when I was driving between campsites, I'd get it back to full juice no worries.
And yeah, I don't expect it to last forever. My only problem will be making sure I use it every now and then at home when I'm not on a trip.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 01:55 PM #12
Chilow Chilow is offline
Chilow will become famous soon enough
I have similar results. I also have an ARB 50qt and use the Jackery 500 when I don't want to drain the battery in the 4runner. I got about 48 hours with the fridge temp set to 29F before the battery life on the Jackery showed 16%. I'm sure I could've squeezed another 1-2 hours, but didn't want to run the battery too low. Ambient temperature was about 70-80F so results vary.
Chilow is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 03:45 PM #13
Remember that the lithium cells in these can be discharged fully, unlike the 50% discharge you're not supposed to exceed with AGM or other lead/acid chemistries.
Ambient temperature has a lot to do with the discharge rate too; this weekend when I was out, had the hatch open for many hours in camp and it was 90-95 degrees in the little canyon we were in. That of course makes the fridge work harder.
In any case, the solar would have topped it off nicely if I was in the sun ;)
Gone
Old 10-14-2020, 11:54 PM #14
OffKamber OffKamber is offline
OffKamber will become famous soon enough OffKamber will become famous soon enough
1000% agree. I have about $1500 into goal zero system and it’s failing miserably.
OffKamber is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 12:43 AM #15
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
Thats good to hear. I just ordered Rockpals new 500 watt power station. Excited to get it and try it out. Looked good and a lot cheaper than other brands.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
portable , power , sale , stations , upgrade
DIY Portable Power Bumbo Off Topic 2 08-08-2018 06:40 PM
PORTABLE POWER GENERATOR plans for FEEDBACK theladyviola Off Topic 15 08-22-2017 01:34 PM
Portable Power Supply Options 949r6 5th gen T4Rs 12 07-24-2017 04:56 PM
Portable power, Jump starter, compressor Brookey_813 Accessories 4 04-27-2017 05:58 PM
