Old 10-18-2020, 08:58 PM #1
RoamerOverland RoamerOverland is offline
RoamerOverland is on a distinguished road
Tire Pressure for 285x70x17 STT Pro
I am running 285x70x17 STT Pros and want to know what tire pressure you all are running? Can anyone please tell me what and why you are running what you are running?
Thanks!
2020 SR5, DX4 Terrain 17x8.5, STT PRO 285/70/17, Toytec Boss 2.5 front coilovers with 650 springs, Superflex heavy duty rear coils, Toytec 2.5 Aluma Series IFP Rear Shocks, swaybar relocate, diff drop, aluminum 2" bump stop, Ironman 4x4 Pro-Forge UCAs, Ceramic Tint, LFD Roof Rails with crossbars, Diode Dynamics SS3 LED Fog Light Kit, Demello Silders, Midland GMRS radio, Cali Raised low profile ditch light brackets, nilight pods, nilight 41 inch light bar, Auxbeam 8 gang panel, C4 Fab battery tray, C4 Fab accessory mount for my compressor, DIY wifey system for air up/down, two 10" lights behind grill, DIY drawer system and sleeping platform, Blue Sea Systems ML-ACR 12V DC 500A, ....
RoamerOverland is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 12:21 AM #2
1Louder 1Louder is offline
1Louder will become famous soon enough
Thanks!
Under what conditions? On pavement? I used to run mine between 38-40
Off Road anywhere from 16-25 depending on conditions. The sidewalls are pretty thick. I am sure you could go lower.
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
1Louder is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 12:48 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Because those tires are a bit wider than stock, you could run them a little bit below the specs on the drivers door jam --want to keep the contact patch on the road flat. But watch the tire wear pattern over time -- wear on the edges indicates too low a pressure and wear in the middle of the tire indicates too high a pressure. Other wear patterns would indicate an alignment problem or aggressive driving.
fkheath is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 01:26 PM #4
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Assuming they're E rated tires - you need to run higher pressure than P rated tires. Thicker sidewall = more heat buildup when flexing = less tire flex is required to keep heat down = you need to run higher pressure in an LT tire than you do in an P rated tire.
So as a general rule - for the same load carrying capacity of a P rated tire at 35psi - you need to run an LT tire at about 50psi.
Larger size translates to lower pressure necessary for similar load capacity.
Therefore - you should probably run your STT Pros at about 45psi or somewhere in that range is where I'd start.
Old 10-19-2020, 03:08 PM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Thanks!
Click on the “duratrac” link in my signature and it’ll point you to the tools to calculate a new pressure. I’m running about 38psi with 285/70r17 LTs. Yes, more rigid sidewalls are good for lateral stability when towing heavy loads, but at the same deflection in the sidewall they generate more stress, heat which turns into failure. Therefore LTs generally are run at higher pressure when on the road than a comparable P tire and give a harsher ride.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 02:08 AM #6
Thank you all for the information. I just did a trip from SoCal to Utah/AZ (St. George and the Bar 10 Ranch at the Grand Canyon).
I found that when I set the pressure at 35psi, that after a little driving, the TPMS would read 37 to 38 psi. The tires did great on the road and the mileage was great (for me). I am concerned about running them at 38 on the highway as that would seem to cause them to grow to 40psi or so with the heat build-up. But I will give it a try.
As for offroad, I set them at 19 psi and they did great. Lots of grip in the dirt and sand of the desert. I really like these tires.
Thanks again to all for the help.
285x70x17 , pressure , running , stt , tire
low tire pressure light ...for the spare tire?????? soimcrazy 4th Gen T4Rs 33 12-25-2018 04:23 PM
Tire Pressure Sensor - Spare tire Tdub 4th Gen T4Rs 3 09-01-2008 10:49 AM
WTB - 1 tire 285x70x17 Net4n6 Classifieds - buy & sell (no commercial ads please) 0 01-23-2008 10:15 AM
285x70x17 MTR's and what cutting I'll need to do Expat Engines / Suspension / Wheels / Tires / Audio / Accessories 25 10-18-2005 11:18 PM
Tire Pressure & Max Rated Tire Pressure Phil 4th Gen T4Rs 7 03-10-2004 10:49 PM
