Old 10-20-2020, 06:21 PM #16
OffKamber OffKamber is offline
OffKamber will become famous soon enough OffKamber will become famous soon enough
Originally Posted by Jetboy View Post
Your temps seem unusually high. There seems to be a correlation between supercharger and transmission temp/heat soak problems. - you're not the first person on here to have transmission temp issues after adding a supercharger.
As an example I tow a small camper - but it has a fairly high wind profile. Two weeks ago I went into a 25-30mpg headwind headed to southern Utah. For periods of time I was literally pedal to the floor and only able to maintain ~70mph WOT. I do have a medium size transmission aux cooler, but I never really thought it was necessary - mostly an extra precaution. I've never been able to get the temps on the transmission or engine to climb out of the typical operating ranges.
I can take random guess about the supercharger tune and the transmission's torque converter that has a intermediate "partially locked" option and where it might generate a lot of heat with more input torque than it thinks it's getting, but that's just a guess on my part. This might be a case where regearing the diffs could help reduce the torque in the transmission and lower temps.
Never thought of that. Didn't want to regear only because I'm already getting 11 MPG. But kind of makes sense that it may be only fix that's not a band aid... guess I know my next mod and it seems like I'm getting a front locker sooner than I thought now...
OffKamber is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 06:33 PM #17
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Keep in mind that I'm just observing that a few members have had issues with trans temp overheating and they've also had superchargers. So I'm making a pretty big jump of logic here that may have no relationship other than random luck. My guess is with your heavier load the regear would keep the torque converter locked up more often and generate less heat.
I don't know why the superchargers seem to be correlated with trans temps being high at idle or trail speeds. That points to something going on with high-idle rpms or something odd there. You're also not the first to have that issue.
But I'm also just random guessing on something that could cause a problem. You could also have just gotten your transmission cooler lines reversed or received a radiator with a constricted passage and you're not getting enough fluid flow.
Old 10-20-2020, 07:57 PM #18
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
I have the URD Whipple sc on my 4R and only time my trans warning light (too high of temp) has ever come on was during heaving winching where the truck was on and not moving on crazy steep inclines. otherwise never ever had an issue with trans temps being high before or after the install of the supercharger. Now maybe this is an issue in higher elevations which we do not have on east coast.
following your theory Jetboy, I regeared before the sc, so can't speak to it's effect or not.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 11:27 PM #19
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
I’ve never any issues with Transmission temp light coming when going up steep hills. I drove to and from Las Vegas with outside temps on the high 90s with my foot to the floor. The 4Runner pulled like a freight train with the SC. I’ve been wanting to add an external transmission cooler just for peace of mind. I’m pretty heavy myself with steel front and rear bumpers, steel skids, and heavy 295/70R17 KM3’s.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 01:31 PM #20
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
You could go all in and do a offroad trans cooler.
Race Ready Products > Cbr Large Off Road Cooler
Bypass the oem radiator.
Can get trans fluid thermostats/switch.
Whats the engine temps?
Was thinking lower the engjne temp with the 160* stat to lower overall temps.
Is some talk about a transmission cooler water mister over in the 4th gen section.
Was also thinking, you can get water wetter for the engine cooling.
Maybe help overall cooling transfer?
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 02:24 PM #21
fbksurferjoe fbksurferjoe is offline
fbksurferjoe is on a distinguished road
If I didn't have a scangauge I wouldn't ever have noticed my temps. Maybe I should get rid of the scangauge. Haha.
When I drained the radiator of transmission fluid when I did the supercharger and new radiator, it didn't seem to be very much oil. I really am debating pulling the lines from the radiator and running it direct to the aux cooler. I live in California I dont have an issue with my transmission being too cold.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
fbksurferjoe is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 03:03 PM #22
Whippersnapper02's Avatar
Honestly I'd leave it in the system. Anything below normal operating temp is too cold. I've seen issues with people removing the OEM cooler circuit and there's no benefit to deleting it. Engine coolant is at lower temps than when you're working a tranny.
Old 10-21-2020, 04:05 PM #23
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Maybe just get that new Dodge TRX, somthing like 700hp in a pickup.
2021 Ram 1500 TRX | Off-Road Pickup Truck | Ram Trucks
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 10-21-2020, 07:26 PM #24
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
I would post any transmission question here Transmission- 5 Speed automatic write up with pics for second gen 4 liter trucks | Tacoma World as it is the same transmission as ours and the guy knows his stuff.
If you are hitting those temps, I would recommend a fluid exchange using the return line between the radiator and trans. Just remember to measure what you take out and put only that amount back
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
basically , hours , miles , temps , tranny
Pos Tranny temp gauge thegipper 3rd gen T4Rs 21 06-05-2018 11:57 PM
4w hi, D2 = 250 Tranny temp??!? thor999 3rd gen T4Rs 13 01-27-2013 10:12 PM
Where can I tap into to get tranny temp? NM_Shooter 3rd gen T4Rs 5 12-02-2012 01:42 PM
What tranny temp gauge for my 97 T4R? Surfcaster 3rd gen T4Rs 17 04-06-2011 11:18 AM
Tranny Temp Gauge Kurtis 3rd gen T4Rs 2 12-21-2010 01:01 PM
