Old 10-26-2020, 12:27 PM #61
4loko.4r 4loko.4r is offline
4loko.4r is on a distinguished road
Originally Posted by AcrylicSauce View Post
It’s just a blank key
I meant behind the plastic housing. Does it say meso customs or is it blank?
Picture is an example of my ajt housing.
Thanks in advanced!
4loko.4r is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 03:57 PM #62
AcrylicSauce's Avatar
AcrylicSauce AcrylicSauce is offline
AcrylicSauce is on a distinguished road
Nice! Just came back from the locksmith and he didn’t charge me anything to get my 2 keys cut! We just chopped it up about guns the whole time and he said no charge. I’ll take it lol
AcrylicSauce is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 03:58 PM #63
Thanks in advanced!
Got it, it says meso customs on the bottom of the back side but not huge like the AJT ones
Old 10-26-2020, 04:46 PM #64
jmeds jmeds is offline
jmeds is on a distinguished road
Any specifics we should know about for cutting the meso key......should it be removed from the fob? Anything else?
jmeds is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 05:40 PM #65
HGAdv HGAdv is offline
HGAdv will become famous soon enough
Ordered mine up too , appreciate all the info in this thread.
HGAdv is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 05:45 PM #66
Nope, nothing special but from my experience Home Depot and ace hardware couldn’t cut it because their machines were detecting the transponder. Ace said it’s doable but the one guy that could do it wasn’t in at the time.
The locksmith I went to cut it no problem, and just like the other places I went to, he asked if it needed to be programmed. I told him no since I would be transferring the chip to the new fob case.
I didn’t try getting the key cut while attached to the flip mechanism but it looks like the pin that you pull out once installed would get in the way and it’s only a set screw holding it in place so I would just recommend removing the blank for cutting.
I will have everything back together tomorrow, I asked meso but they haven’t replied on replacing the battery and how it’s done in the future if you need to take it apart so I just went ahead and ordered brand new CR2016 batteries from Amazon (less than $5 for 2).
Old 10-26-2020, 09:30 PM #67
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough
Well this is a bummer.
Meso FlipFobs Are Finally Available-abae0d28-d6d4-4a5d-9645-aae9f9b1ae62-jpg
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 10:18 AM #68
Oh that would burn me up! I ordered mine last week from 4runner lifestyle, have heard nothing about shipping? Also, sent Stew at Meso question about red panic buttons, also have heard nothing
Old 10-27-2020, 11:27 AM #69
FattyHunter FattyHunter is offline
FattyHunter is on a distinguished road
I ordered mine when the email goes out, got it yesterday. I got black because I didn't have a special color 4Runner. Cutting the transponder is not that bad, took me about 10 minutes to get it out with a box cutter. It does come with a blank and TRD cap for the spot below the flip button, I used the blank one.
Transfering the internals over is easy. It works as intended for me because I keep my key in my pocket and got tired of getting poked by the key. It's not perfect, however, there are movements back and forth where the key sits in the fob, makes it feel flimsy to me. Also, there are gaps after the screws are tightened. Red panic button would be nice. Just some thoughts.
Potentially you could make the old key work by grinding down the other end if you don't want to get one cut, just loosen the set screw on the new fob. I like it though, might not be for everyone.
|2015 Magnetic Grey SR5 Premium|
|Bilstein 6112 Front, 5100 rear Icon 2 inch Springs|
|FN Overlander Wheels| |Duratrac RT 285/75R17||RCI sliders|
|Proline Front Bumper| |Rigid Fog lights|
FattyHunter is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 06:30 PM #70
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
Here is their video on how to put back together. My key wasn't flipping open so had to take apart and do over so I found this video.
MESO Flip Fob re-assembly - YouTube
Took me about 30 mins to get the chip out. Managed to slice my finger in the process.
I like it overall but it is bigger than I was expecting.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 06:35 PM #71
ElJefe's Avatar
Real Name: Jeff
ElJefe's Avatar
Real Name: Jeff
So did you take your original key and grind down or get the blank cut?
Debating which I want to do. The local key cut place wants $25 to cut. Ace Hardware is $5 but I'm worried about quality like other guys mentioned.
Old 10-27-2020, 08:17 PM #72
Glad this came out, we’ll all have to take apart sooner or later to replace battery
Old 10-27-2020, 08:42 PM #73
gx4702 gx4702 is offline
gx4702 is on a distinguished road
I would check a few more locksmiths. My local shop charged me $2.50 for it cut. It was totally fine - even cut without taking the key out of the fob
gx4702 is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 08:52 PM #74
blackopspinster blackopspinster is offline
blackopspinster is on a distinguished road
Was able to get my key cut today, shout out to the other member who took their blank to Havens Security to cut. Cost me $5 flat.
Mini-review: The tolerances are a little off, one half is slightly warped leaving minimal gaps on the ends, I guess this is expected from a 3d printed case. Due to the misalignment, the key sometimes catches on the edge when folding in. Flipping mechanism works well and the fob feels solid when cranking. With the issue regarding QC, I wouldn't say it's worth the $70 unless you're wanting to pay a premium to avoid jabbing yourself with the non-flip key.
PXL-20201027-203744615
PXL-20201027-203747979
PXL-20201027-203750793
PXL-20201027-203918937
PXL-20201027-204120673
blackopspinster is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 09:23 PM #75
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
You’re at least the second person seeing quality problems with the flip fob. You should contact MESO and send photos and descriptions. I’m sure he would be concerned and do something about it.
finally , flipfobs , gettin , good , meso
Meso Customs steering wheel Toyota overlay "review" Scowling Tuna 5th gen T4Rs 30 09-13-2020 01:28 AM
**SOLD** FS: Meso Customs Fuse Cover and Scan Gauge II Blazephantom For Sale: T4R Items 2 08-19-2020 11:34 AM
Meso Customs Extened Fuse Cover - In Stock jrandom 5th gen T4Rs 62 07-08-2020 08:41 PM
FS: Meso Customs Extended Fuse Cover $25 shipped, Socal blksubykid For Sale: T4R Items 1 05-23-2020 05:27 PM
Mesojdm / meso customs ultimate dome light emmantik 5th gen T4Rs 7 03-31-2019 04:53 PM
