10-26-2021, 06:06 PM
#61
Originally Posted by WhiteMudhorn
I've been highly tempted to go this route as well. Since the kit is adjustable, I'd want to keep it at 2" lift so I don't have to get UCA's (for now) do you think that is feasible with this set?
My 2 cents.
Short answer IMHO is yes, its feasible.
These are 2" shocks with a 3" coil, fully adjustable, range 0 - 2 1/2". (that's the reason for my choice so they can be tweaked on the T4R)
The 6112's were a 2.5" shock with a 4" coil if I remember and mine were at 2" height and I never had any issues with a stock UCA.
Best Regards,
Saker
10-26-2021, 06:34 PM
#62
I asked Eibach about their pro-truck lift kits for the 4Runner and they said you could run your stock UCAs, on stage 1 & 2 kits.
10-27-2021, 10:44 AM
#63
I'm sure you can.. but how much longevity /reliability do you need to compromise?
I read on here that under 2" lift no problem but at around 2.5" and above... UCA is suggested.
11-07-2021, 03:08 PM
#64
Hey guys, new member and new 4Runner owner. Just got a 2021 TRD off-road premium. About to get some KO2 stock size C load. Plan to keep my stock rims. I want to get some new coil overs next. Just plan on doing the fronts. This is my daily driver sine I sold my f250. I don’t do any trails just a lot unpaved rough dirt and gravel roads. A lot of highway driving as well. I want less nose dive on braking and better handling but still a somewhat smooth ride. 1 inch of lift would be max I would go so I can keep stock UCAs. Are these a good option (assuming they come in stock anytime soon) is there a better option? TIA
11-07-2021, 04:54 PM
#65
These would be a good option for your needs. Last I heard, Eibach is saying they're shooting to have these out before Christmas...
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
11-22-2021, 09:51 PM
#67
Not a 4 runner, but I am planning to run the Eibach 2.0 on my GX460. Eibach was great on my Jeep and I am excited to get it installed. I am glad to hear others have had a great experience as well.
Sold; 98 4Runner Limited, OME 883's w/Bilstein 5100, Downey 3" rear springs w/Doetch Tech & Daystar 1.25" spacer, Cornfed 1" diff drop, Tundra 231mm brake upgrade, Tundra wheels/tires, Tinted windows, more goodies being added. Not quite to 200,000 miles club yet!
11-22-2021, 11:44 PM
#68
Just wanted to share how I got my hands on the eibach 2.0 coilovers. I am not happy with the vendor because they list them as confirmed fitment for 2022. Dave at Eibach said this is not true, and they have not even had a 22 in their shop yet. But, to help out anyone that's looking. I went to Bilsteinlifts.com and registered my email to be notified when they are in stock. I got an email a few weeks ago and clicked the link within a few minutes. When I got to the product page there was 1 in stock. I purchased the kit with rear shocks.
I can confirm fitment in a 2022 KDSS ORP, with a caveat. I lowered the front spring seat by 1 full inch to get the advertised height. This came out to 2 3/16 inches between the bottom of the spring seat and the top of the shock eye. There are roughly 2-3 threads showing.
I am not saying Eibach will not address this with a different preset height and part number, I'm just telling my story.
Vehicle is 13" front wheel arch to wheel top and 13.25 rear. It rides incredible and has zero lean. I'm waiting for the rear load levelers to be delivered. I'll post back after install. If you're spanner breaks like mine, I adjusted them with two 1/4" pin punches placed opposite one another.
Sent from my HD1925 using Tapatalk
11-23-2021, 02:48 PM
#69
Did you get an overall measurement of the OEM shock and the new Eibach?
Measurement between both from lower mounting point to bottom of coil prior to any adjustment on the Eibach?
Also, did you set the vehicle down before you pulled up and then tighten the lower mounting point to torque specs?
Best Regards,
Saker
11-23-2021, 05:35 PM
#70
this.x2
11-23-2021, 06:28 PM
#71
Yes, the center to center bolt measurements were the same. In the photo they were not aligned right so it looks a little deceiving.
Second question, yes. I marked all of the assignment cams, so I could at least get back to stock settings. I lowered the vehicle and rolled it back and forth a bit, then I torqued everything. I drove it 100 miles and checked torque. Nothing moved but I'll check after another 400
11-23-2021, 06:51 PM
#72
Ok, just thought I would ask!
Best Regards,
Saker
11-23-2021, 08:26 PM
#73
Good question for sure
11-23-2021, 08:38 PM
#74
Anyone know where I can pick up this kit from a reputable vendor? I'm reading about sites posting "Current Lead Time 1-2 Weeks" but I'm also reading customers saying it took much longer than that. Any help is appreciated.
11-23-2021, 09:00 PM
#75
You can contact totalautomotiveperformance to check availability, but I think Eibach is just catching up with current orders.
Mine were ordered since April and I just received them last week!
Best Regards,
Saker
