Old 01-07-2024, 11:46 AM #106
Originally Posted by Y0TA406 View Post
Bringing back an old thread. I read through the entire thread and trying to decipher what the best setting for my rig would be. It appears the coilovers come set higher than I'd like. Anyone have the Coilover 2.0 and the load leveling 250( or medium) springs combined? What is your setting for the front and rears?
Vehicle: 2023 T4R ORP with KDSS
Objective: I want to get a mild lift with minimum to none rubbing with 285/70/17.
Sent from my SM-G781V using Tapatalk
lift doesnt affect tire rubbing for IFS. throw your tires on now, if youre running the trd off road/trail wheels you will fit those tires with removing the front mudflaps and some minor trimming on the bumper. if you change wheels or add wheel spacers expect to trim the body mount on the backside of the front tires. either way your suspensions travels the same arc, youre just changing where its starting from (ride height)
Old 01-07-2024, 11:58 PM #107
Y0TA406 Y0TA406 is offline
Y0TA406 is on a distinguished road
I don't have the lift installed yet. Going to have a shop install everything soon. I'm having shoulder surgery soon, so I can't do it. I'm wanting some guidance so I can tell the shop folks where I want it.
Where should I set the coilovers?
Where should I set the rear load leveling?
I have icon rebounds wheels sitting in the garage.
Y0TA406 is offline   Reply With QuoteReply With Quote
Old 02-28-2024, 05:13 PM #108
AbyssRaver AbyssRaver is offline
AbyssRaver is on a distinguished road
First time posting here, trying to achieve the exact same thing as you with mine.
Found this guy and I highly recommend you review how well he breaks it all down:
Tinkerer's Adventure - YouTube
Lift absolutely interferes with what sizes will fit - especially when you throw in a combination of rim offsets and UCA's with it.
Too much caster achieved from the upper control arm will move the wheel center back towards the mud flap, so a proper alignment by a 4x4 specialty shop will probably make the biggest difference in if they require a BMC or not. You want to gain a balance by shifting the LCA forward, with consequence of camber, to get the wheel centered in order to not rub.
I won't be pulling the plug until May or so this year but will be doing the 2R kit first with OEM tires, aligning and measuring, and only then fitting 285/70/17's if those measurements don't require SPC UCA's. If they do, then I'll buy them then.
One hidden takeaway is front and rear height. You can achieve better caster, and therefore front alignment and wheel fitment, by bringing the front/rear level of the vehicle into agreement.
AbyssRaver is offline   Reply With QuoteReply With Quote
5th , coilover , eibachs , height , off-road
OME 883 vs Eibach 620 RCFJ 5th gen T4Rs 8 10-22-2021 06:23 PM
Top of coilover seems off SteelStacks 5th gen T4Rs 3 05-30-2017 12:45 PM
[SOLD] FS: 3" ID Eibach Coilover Coils - Colorado - $75 +S JWaldz For Sale: Suspension/Wheels/Tires 9 12-05-2016 12:49 PM
WTB 4th gen coilover bisonrunner For Sale: Suspension/Wheels/Tires 1 01-26-2015 01:58 AM
FS: Eibach 2.5" 700lb/in coilover springs 12" Length - SF Bay Area - $80 Troymclure For Sale: Suspension/Wheels/Tires 5 07-26-2014 01:15 PM
