Old 04-28-2021, 07:36 PM #46
Endle55_5earch's Avatar
Endle55_5earch Endle55_5earch is offline
Endle55_5earch will become famous soon enough
Originally Posted by f-it View Post
I highly recommend calling Eibach they were very upfront and got my order out quick.
I've been in contact with both TAP and Eibach. Both are telling me this kit is 4+ weeks out. I ordered the total kit (Coils + Rear Leveling + Shocks + Bump Stops) and that may be the hold up.
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
Endle55_5earch is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 11:42 AM #47
f-it f-it is offline
f-it is on a distinguished road
Got the fronts on! Wasn’t that bad with kdss, hardest thing was getting the damn tie rods to drop from the knuckle( I advise renting the tie Rod puller autozone carries, the hammer to knuckle didn’t work for me). I didn’t have to disconnect the KDSS, I jacked up the KDSS piston to do the passenger side then jacked up the passenger lca do to the driver side.
I adjusted one side down from 16 to 4 threads since the height they came with was damn near over 3 inches. As I began the passenger side the spanner wrench pin broke. I tried to weld it back on but after a few turns it broke again and I gave up. Hopefully the alignment place tomorrow has one.
Overall took me about 3 hours and would have been less had I rented the tie Rod puller ahead of time. I’m a ok mechanic and have experience with suspension and chassis work. If you have the tools this is a doable job for most if follow the directions and have a friend helping.
I’ll post pics of the stance once I do the rears. Over all the install was easy aside from the damn spanner wrench breaking. It’s kinda crappy that the damn spanner wrench broke so easily, looing forward to the billet one when they release it.
I also can’t speak on the ride yet until I have the rears installed and the alignment done
Eibach 5th Gen 2.0 Coilover Kit-side-side-jpg  Eibach 5th Gen 2.0 Coilover Kit-coilover-jpg  Eibach 5th Gen 2.0 Coilover Kit-kdss-piston-jpg  Eibach 5th Gen 2.0 Coilover Kit-puller-jpg  Eibach 5th Gen 2.0 Coilover Kit-spanner-wrench-jpg
2000 4runner Sr5 with Tundra 199 brakes taco wip- Sold
2014 4runner TE premium-EIBACH PRO-TRUCK-COILOVER 2.0 and REAR LOAD-LEVELING-SYSTEM. Front at about 1.5 rear at 2 inches.
f-it is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 04:51 PM #48
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Did your 2.0 coilovers come with studs in the top hats or did it come with bolts?
I would contact Eibach and inform them of the broken spanner. They said they have an older one and a new one and it should not fail! (Not the billet, as it’s not available yet)
Best Regards,
Saker
Old 04-30-2021, 11:21 PM #49
I reached out to them and they are sending a new wrench. I had one of the newer ones which unfortunately still broke. I have bolts on top.
Old 05-03-2021, 02:42 PM #50
Originally Posted by amelbeabk View Post
I’ve researched plenty into other kits and since these are two of the newest to our market, I wanted to know how they’re holding up and if you still like them? It’s a toss up between the bilstein and ome kit, but I just want to do my due diligence. I know the dobinsons gained traction a while back and was wondering how it held up a few years Tutuapp 9Apps Showbox later?
I just got mine on so I can't say how they are holding up. What is nice about this kit though is the adjustability. Although its hard to get to being able to adjust the rears for weight is pretty cool. Overall I'm happy with it, I got everything for about $1400 out the door with taxes.
Old 05-06-2021, 12:02 AM #51
icyhotahs icyhotahs is offline
icyhotahs will become famous soon enough
Ive had the whole lot (2.0 fronts and adjustable rears) on for about 1k miles and 2 months... Beautiful. Handles my loads (giggity) perfectly. Stiffer when unloaded but never skips over a bump.
icyhotahs is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 04:40 PM #52
What mods do you have and what spring rate in the rear?
Old 05-12-2021, 10:48 PM #53
I have a rack, some sliders, a ladder, heavier wheels, still have 265s. I have 100lbs constant weight in back. I have the fronts set at 1" (2" lift) and rears set at 1" in the back (2"). The rears are the 250# (200# on site I think). The bump stops are top notch.
Old 05-13-2021, 01:45 AM #54
Can you take a pic of the threads you have showing front and back for reference?
Old 06-02-2021, 03:56 PM #55
7 month wait! Have been told "it's 4 weeks out" for the past 3 months. Getting really frustrated here....
Old 08-11-2021, 04:30 PM #56
9 Month wait! Bananas!
Old 08-12-2021, 11:59 AM #57
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
The 2.0 Coilover Wait is Real!!
Last update from Eibach has estimated availability by end of month.
We do not have an ETA for the next production run at this time.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 10:10 AM #58
GCT4R's Avatar
GCT4R GCT4R is offline
GCT4R is on a distinguished road
GCT4R's Avatar
Do you guys think the 2.0 kit with the leveling 200 system would be better than the TRD Pro Fox suspension?
GCT4R is offline   Reply With QuoteReply With Quote
Old 10-13-2021, 01:30 PM #59
Generally, aftermarket suspension systems will provide a better comfort and performance.
FOX aftermarket shocks are different than those provided off the lot.
It will be great to see 4Runner owners share their experience once these coilovers are available.
We have our fingers crossed that @Saker will have his order in-hands soon and share his thoughts.
_
Old 10-26-2021, 05:34 PM #60
WhiteMudhorn WhiteMudhorn is offline
WhiteMudhorn is on a distinguished road
I've been highly tempted to go this route as well. Since the kit is adjustable, I'd want to keep it at 2" lift so I don't have to get UCA's (for now) do you think that is feasible with this set?
WhiteMudhorn is offline   Reply With QuoteReply With Quote
5th , coilover , eibachs , height , off-road
OME 883 vs Eibach 620 RCFJ 5th gen T4Rs 8 10-22-2021 06:23 PM
Top of coilover seems off SteelStacks 5th gen T4Rs 3 05-30-2017 12:45 PM
[SOLD] FS: 3" ID Eibach Coilover Coils - Colorado - $75 +S JWaldz For Sale: Suspension/Wheels/Tires 9 12-05-2016 12:49 PM
WTB 4th gen coilover bisonrunner For Sale: Suspension/Wheels/Tires 1 01-26-2015 01:58 AM
FS: Eibach 2.5" 700lb/in coilover springs 12" Length - SF Bay Area - $80 Troymclure For Sale: Suspension/Wheels/Tires 5 07-26-2014 01:15 PM
