04-28-2021, 07:36 PM
#46
Originally Posted by f-it
I highly recommend calling Eibach they were very upfront and got my order out quick.
I've been in contact with both TAP and Eibach. Both are telling me this kit is 4+ weeks out. I ordered the total kit (Coils + Rear Leveling + Shocks + Bump Stops) and that may be the hold up.
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
04-30-2021, 11:42 AM
#47
Got the fronts on! Wasn’t that bad with kdss, hardest thing was getting the damn tie rods to drop from the knuckle( I advise renting the tie Rod puller autozone carries, the hammer to knuckle didn’t work for me). I didn’t have to disconnect the KDSS, I jacked up the KDSS piston to do the passenger side then jacked up the passenger lca do to the driver side.
I adjusted one side down from 16 to 4 threads since the height they came with was damn near over 3 inches. As I began the passenger side the spanner wrench pin broke. I tried to weld it back on but after a few turns it broke again and I gave up. Hopefully the alignment place tomorrow has one.
Overall took me about 3 hours and would have been less had I rented the tie Rod puller ahead of time. I’m a ok mechanic and have experience with suspension and chassis work. If you have the tools this is a doable job for most if follow the directions and have a friend helping.
I’ll post pics of the stance once I do the rears. Over all the install was easy aside from the damn spanner wrench breaking. It’s kinda crappy that the damn spanner wrench broke so easily, looing forward to the billet one when they release it.
I also can’t speak on the ride yet until I have the rears installed and the alignment done
2000 4runner Sr5 with Tundra 199 brakes taco wip- Sold
2014 4runner TE premium-EIBACH PRO-TRUCK-COILOVER 2.0 and REAR LOAD-LEVELING-SYSTEM. Front at about 1.5 rear at 2 inches.
04-30-2021, 04:51 PM
#48
Did your 2.0 coilovers come with studs in the top hats or did it come with bolts?
I would contact Eibach and inform them of the broken spanner. They said they have an older one and a new one and it should not fail! (Not the billet, as it’s not available yet)
Best Regards,
Saker
04-30-2021, 11:21 PM
#49
I reached out to them and they are sending a new wrench. I had one of the newer ones which unfortunately still broke. I have bolts on top.
05-03-2021, 02:42 PM
#50
Originally Posted by amelbeabk
I’ve researched plenty into other kits and since these are two of the newest to our market, I wanted to know how they’re holding up and if you still like them? It’s a toss up between the bilstein and ome kit, but I just want to do my due diligence. I know the dobinsons gained traction a while back and was wondering how it held up a few years Tutuapp 9Apps Showbox later?
I just got mine on so I can't say how they are holding up. What is nice about this kit though is the adjustability. Although its hard to get to being able to adjust the rears for weight is pretty cool. Overall I'm happy with it, I got everything for about $1400 out the door with taxes.
05-06-2021, 12:02 AM
#51
Ive had the whole lot (2.0 fronts and adjustable rears) on for about 1k miles and 2 months... Beautiful. Handles my loads (giggity) perfectly. Stiffer when unloaded but never skips over a bump.
Reason: Edit
05-12-2021, 04:40 PM
#52
What mods do you have and what spring rate in the rear?
05-12-2021, 10:48 PM
#53
I have a rack, some sliders, a ladder, heavier wheels, still have 265s. I have 100lbs constant weight in back. I have the fronts set at 1" (2" lift) and rears set at 1" in the back (2"). The rears are the 250# (200# on site I think). The bump stops are top notch.
05-13-2021, 01:45 AM
#54
Can you take a pic of the threads you have showing front and back for reference?
06-02-2021, 03:56 PM
#55
7 month wait! Have been told "it's 4 weeks out" for the past 3 months. Getting really frustrated here....
08-11-2021, 04:30 PM
#56
9 Month wait! Bananas!
08-12-2021, 11:59 AM
#57
The 2.0 Coilover Wait is Real!!
Last update from Eibach has estimated availability by end of month.
We do not have an ETA for the next production run at this time.
_
10-12-2021, 10:10 AM
#58
Do you guys think the 2.0 kit with the leveling 200 system would be better than the TRD Pro Fox suspension?
10-13-2021, 01:30 PM
#59
Generally, aftermarket suspension systems will provide a better comfort and performance.
FOX aftermarket shocks are different than those provided off the lot.
It will be great to see 4Runner owners share their experience once these coilovers are available.
We have our fingers crossed that
@ Saker
will have his order in-hands soon and share his thoughts.
_
10-26-2021, 05:34 PM
#60
I've been highly tempted to go this route as well. Since the kit is adjustable, I'd want to keep it at 2" lift so I don't have to get UCA's (for now) do you think that is feasible with this set?
