Old 11-23-2021, 09:19 PM #76
Somnospeed Somnospeed is offline
Somnospeed is on a distinguished road
Originally Posted by Saker View Post
You can contact totalautomotiveperformance to check availability, but I think Eibach is just catching up with current orders.
Mine were ordered since April and I just received them last week!
Since April?? No way I can wait that long. THere's gotta be something decent out there! lol
Somnospeed is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 09:25 PM #77
Saker's Avatar
Saker Saker is offline
Saker's Avatar
You asked about these
I’m just informing you as to how long they took to come from Eibach!
Eibach to distributor to me….
Welcome to todays world!
Another kit……. Maybe dobsons
Best Regards,
Saker
Old 11-30-2021, 12:33 AM #78
norutah's Avatar
norutah norutah is offline
norutah is on a distinguished road
norutah's Avatar
Anyone know where I can pick up this kit from a reputable vendor? I'm reading about sites posting "Current Lead Time 1-2 Weeks" but I'm also reading customers saying it took much longer than that. Any help is appreciated.
10-21 4Runner Eibach 2.0 Front Coilovers (0-2.5")
10 in stock and 15% off
Sent from my HD1925 using Tapatalk
norutah is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 11:25 AM #79
norutah's Avatar
norutah's Avatar
Update, 16 in stock and no longer on sale
Old 12-10-2021, 04:05 PM #80
Kfish Kfish is offline
Kfish is on a distinguished road
I did my Eibach lift over 2 nights. Rear: 1 inch pro lift springs and Pro truck shocks. Front: Pro Coilovers 2.0.
The rear gained almost 1.5 inch with those springs. I had to make about 13 turns or more in the front coilovers to get the nose down to the height I was looking for, there is about 3/4 inch factory rake left to compensate for light boat towing.
Used plenty of silicone lubricant on the collars and threads, using metal pipe for leverage it wasn't that bad using the spanner wrench especially going down releasing spring tension. I bought back up wrench in case it broke but not needed after all. There's about quarter inch left of threads from the bottom on the struts. Kudos to the person who suggested putting a paint mark on the collars to keep track of the turns.
Before on top, bottom is after the lift. Really liking the new stance and handling.
Eibach 5th Gen 2.0 Coilover Kit-pxl_20211210_014254397-jpg  Eibach 5th Gen 2.0 Coilover Kit-pxl_20211210_023939512-jpg  Eibach 5th Gen 2.0 Coilover Kit-pxl_20211209_055455769-jpg  Eibach 5th Gen 2.0 Coilover Kit-photo_2021-12-10_09-04-41_am-jpg
Kfish is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 11:22 PM #81
Saker's Avatar
Saker's Avatar
Looking at the postings above, I’m wondering if I will be able to achieve only a 2” lift with these coilovers.
Looking at the numbers (from previous posts), it appears to get just above a 2” lift, the spring seat collar needs to be lowered by 1” or more.
I just measured my coilovers and from the bottom of the collar to the last thread on the shaft is only 1 1/4”.
I hope I’m wrong on the above information when my install happens next week.
I will take measurements and take photos and document what the end results are.
Only added weight to the front end of my T4R is an added TRD Skid Plate (aluminum) that replaced the OEM stamped plate.
According to Eibach, the setting that they leave the factory is supposed to make our trucks level.
(I wonder if they have actually installed them on a stock T4R 4x4 without any added weight!!!!)
This information comes from my phone calls directly to Eibach. (They stated they tested these heights on 4Runners)
I hope that @mark@eibach and or @Ryan at Eibach will watch this thread as previous members posted with their findings as well. Maybe we can get some input from EIBACH.
Best Regards,
Saker
Old 12-24-2021, 08:53 AM #82
norutah's Avatar
norutah's Avatar
Yes, you will not have an issue. The motion ratio on your suspension is not 1:1. I believe it is roughly .67:1
Old 12-24-2021, 02:42 PM #83
Saker's Avatar
Saker's Avatar
Here is some info for the people at Eibach. They advertise that their 2.0 Coilovers are 0 - 2 1/2”
I, and it seems others have found this information to be incorrect for our applications. EI: 2010 -2021
4Runners 4X4
Maybe @mark@eibach and or @Ryan at Eibach will carry this information forward or reach back out to the community for more information.
They DO NOT leave Eibach at a setting to achieve a level setting with OEM rear coils.
Factory setting from Eibach achieved a 3 1/2” increase in height on my truck after the truck was settled down and lower mount tightened after all the weight was on the coils.
Ground to top of wheel well (OEM) before install was 34 1/2”
Ground to top of wheel well 361/2” high after dropping adjustable collar down by 1”
(The 1” on the collar = 1 1/2” reduction of height.)
There is only 1/4” of threads left of adjustment on the shock shaft, hence there is no way I could drop the height to OEM height with the coilovers.
You can see from the photos the differences and what it takes to achieve only a 2" height adjustment:
Eibach & Tokico OAL
Eibach & Tokico bottom of coil to center mount
Eibach & Tokico adjustment collar to top of lower mount collar
Eibach threads under adjustment collar before & after
Now the good part:
As far as the overall performance of the coilovers & shocks in a short period of evaluation time driving over the same areas, these coilovers dampen the harshness of highway bumps and depressions extremely well compared to the Tokico OEM equipment that comes on the 4Runner.
Nose dive is reduced tremendously, cornering feels more controlled with less body roll.
So far I am very pleased.
Best Regards,
Saker
Old 12-24-2021, 03:19 PM #84
Saker's Avatar
Saker's Avatar
Yes I was aware that it was definitely not 1:1 ratio.
I was hoping it was more like .5:1 ratio. I had been informed it was .67:1.
Would have been better if there were more threads on the shock shaft from Eibach.
See above post.
Best Regards,
Saker
Old 12-25-2021, 07:21 PM #85
norutah's Avatar
norutah's Avatar
See above post.
I typed that incorrectly. The motion ratio is 1.67:1. Unrelated but related. I just came in from installing the Eibach load levelers and bumps in the rear.
Very happy with the ride and performance.
Old 01-22-2022, 01:46 PM #86
Saker's Avatar
Saker's Avatar
So, Ive had my shocks installed and in use almost 1 month of daily driving in different conditions.
I’ve had Bilstein 6112’s on my previous T4R so that’s what I can compare to and no other units.
The Eibach Coilover 2.0 seem to be on par with the previous Bilsteins. Cornering at speed, minimum (if any) body roll.
Absorbs pot holes much better than OEM shocks.
Off road, they are firm as they should be to prevent bottoming out.
Nose dive, minimal!
Adjusts from about + 1.7” up to ?
Rear shocks are better valved than the OEMs.
Waiting for Eibach to come out with the Pro-Truck Rear Reservoir Shocks !!!
Best Regards,
Saker
Old 01-25-2022, 11:18 PM #87
4X4T4R 4X4T4R is offline
Real Name: used to be "Zlots"
4X4T4R is on a distinguished road
You catch a peek of their UCA? Hopefully for the 5th gen!
4X4T4R is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 08:31 PM #88
Saker's Avatar
Saker's Avatar
Didn’t notice.
Best Regards,
Saker
Old 01-26-2022, 09:35 PM #89
GearJunkie88's Avatar
GearJunkie88 GearJunkie88 is offline
GearJunkie88 will become famous soon enough GearJunkie88 will become famous soon enough
@Saker - I don’t understand all the math from your earlier post, but from what I gather, you’re saying that these Eibach 2.0 coilovers have a minimum lift of 1.7”. Is that correct? If so, I’m really bummed. I just ordered these and they should arrive on Friday. I really only want a 1” lift to make it level-ish with my stock rear suspension/coils. I want to keep stock wheels and all because of weight, gas mileage, etc... But I’m disheartened now. Should I even bother paying to have these installed? Is there really no way to get a 1” lift from these?
2022 SR5 Premium 4WD
GearJunkie88 is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 12:18 AM #90
Saker's Avatar
Saker's Avatar
Redoing the math, if you lower the adjustment collar all the way down, you may be able to get minimum of 1.625” of height over stock height!
You could possible do 1/2”” or a 3/4” CORNFED spacer in the rear that would adjust your rake close to what you are looking for.
Suggestion: if you are going to lower the adjustment collar all the way down, have someone place them in a coil compressor and turn the collar to desired location to prevent fighting it on the truck under load.
Best Regards,
Saker
5th , coilover , eibachs , height , off-road
OME 883 vs Eibach 620 RCFJ 5th gen T4Rs 8 10-22-2021 06:23 PM
Top of coilover seems off SteelStacks 5th gen T4Rs 3 05-30-2017 12:45 PM
[SOLD] FS: 3" ID Eibach Coilover Coils - Colorado - $75 +S JWaldz For Sale: Suspension/Wheels/Tires 9 12-05-2016 12:49 PM
WTB 4th gen coilover bisonrunner For Sale: Suspension/Wheels/Tires 1 01-26-2015 01:58 AM
FS: Eibach 2.5" 700lb/in coilover springs 12" Length - SF Bay Area - $80 Troymclure For Sale: Suspension/Wheels/Tires 5 07-26-2014 01:15 PM
