10-23-2020, 05:04 PM
What kit is this?
Does anyone know what kit this is? Is it any good?
10-23-2020, 06:37 PM
"good" is a subjective term when it comes to suspension.
I have no clue who makes them but here's what I can say:
It looks like the kit you have shown is height adjustable. If the springs are typical 2.5" springs, then you can swap in whatever spring rate you'd like.
I see spacers intended for the rear springs - I'd avoid those and get taller springs if you want a lift.
In regards to the shock themselves, I don't know how they're valved which means it could be something custom and can't tell just from the exterior
10-23-2020, 06:39 PM
Looks like a Toytec lift to me. Depending on the year could be a variety of manufacturers
10-23-2020, 11:07 PM
Since they use metal ball joints for the mounts rather than the factory rubber donuts, it will ride very rough -- you won't have the cushion that the rubber provides. My guess if they are for serious racing applications where they don't care about ride.
10-24-2020, 01:55 PM
Thanks for your input. Someone is selling this kit and I wanted to get some input on it. I think I’ll pass on it.
10-24-2020, 05:24 PM
Those rear shocks, at the bottom in the photo on the red cap, should say the brand name right on there. I'd have guessed Toytec too
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
10-24-2020, 06:10 PM
Real Name: Charles
Real Name: Charles
I would have said Walker Evans - I think the more traditionally are red and silver but image they could be bought in black.
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
10-24-2020, 09:10 PM
Looks like toytec
10-25-2020, 01:44 AM
LOL...
I don't have rubber donuts, and my 4runenr rides fine
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
10-25-2020, 02:10 AM
The rear shocks seem to say Toytec.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
10-25-2020, 09:38 AM
Originally Posted by rayofsi
LOL...
same here, infact, mine riders BETTER than stock with the rubber bushings.
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
10-25-2020, 03:04 PM
LOL...
I generally agree. However, I do think without the rubber bushing it will ride differently, especially if paired with a stiffer tire than stock or if you are changing suspension and tires at the same time. For me I noticed this when going from a Toytec setup to Radflo. It manifested itself for me by being a bit harsher going over small bumps like pot holes, manholes, larger seams in concrete etc. If you are looking for a plush ride similar to stock consider a shock/strut with the rubber bushing.
10-26-2020, 04:18 PM
Ride quality comes mainly from springs, shock design and shock tuning
Digressive vs Linear vs Progressive Pistons & Shock Valving | AccuTune Off-Road
Whether you have a oem style rubber bushing or heim joint etc shouldn't have much of an effect on ride quality.
10-26-2020, 05:02 PM
There's a good amount of vibration and small bump compliance you gain from the rubber bushings. Especially the small stuff like road cracks. It's all a tradeoff. With spherical bushings you get more direct control of the suspension from the valving instead of the bushings, but lose some softness. The same is true for swapping to poly bushings for example. It's also similar to changing wheel sizes. 20" wheels ride rougher than 17" wheels with the same diameter tire. And going up in tire size. So going to a 285 tire probably adds some cushion where you might have lost it in the bushings or shock eyes. It all works together.
In favor of those shocks - big valves in higher end shocks tend to have much larger fluid passages and allow you to tune them in such a way that can offer a more plush valve response to account for the more rigid mounting points.
My biggest issue with the spherical bearings on my junk is the 1-2 year life span. If I could choose - I'd rather have rubber. No question overall my fox factory series up front ride better all around than the stock setup. So long as I keep the height around 1.5-2". Higher and it starts degrading.
However if the price is right on those - they're probably a pretty good suspension setup.
10-26-2020, 05:06 PM
I'm not referring to the UCA bushing. I'm referring to the front lower shock mount where it connects to the LCA. In some manufacturers shocks there is a rubber or polyurethane bushing in others (Radflo as a for instance and other race style shocks.) there is not. It does not directly apply to ride quality as it's being presented in the Accutune link you provided. It simply adds a slightly stiffer thunk for lack of a better description on low speed bumps as I described.
I attached a couple images to illustrate. Forgive that they're kind of generic and the sizing
