Old 10-23-2020, 08:24 PM #1
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
4wd shifter - remove dial install lever?
So have & love the SR5, but MUCH prefer the Trail/TRD manual 4wd shifter to the dial.
Wondering is anyone has, or knows about, changing the shifter?
Just started cogitating about it...figure it would require removal of the electronics & actuator and purchase and install of the mechanical parts. But it might be a lot more complicated than that if say the computer is involved somehow.
Thoughts/comments if you please.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 09:06 PM #2
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
Probably more trouble then its worth. Sell the SR5 and get a TRD OR
Daikon is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 11:02 PM #3
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
There is a big difference internal to the transfer case -- the shift rails and forks are different. Thus you would have to rebuild the transfer case, so it is really not possible. You can see what I mean by looking at the factory repair manual where they break down both types of transfer cases:
TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
fkheath is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 10:20 AM #4
Yikes, a LOT more involved than it seems on the surface. Thanks for the reference.
Looks like I'll be using the dial....no sense spending $12k to change the shifter.
Between outfits.
Old 10-24-2020, 10:35 AM #5
ScoMey's Avatar
ScoMey ScoMey is offline
ScoMey is on a distinguished road
ScoMey's Avatar
... if you're worried about it being 'reliable'... you're probably pretty safe. While I'm sure somebody will jump in and say otherwise, there doesn't seem to be a lot of owners here who have had trouble with the dial shifter not working as it should, even with a lot of miles and use. You're not likely to have a problem with it IMHO.
Good luck.
2023 Lexus GX 460 Premium
Sold - 2014 LE Barcelona Red
ScoMey is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 11:04 AM #6
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I use my "dial" regularly. That may be one reason I haven't had any problems with it.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 11:18 AM #7
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Of all the drive by wire things on the 4R, I wouldn't worry about it.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 12:10 PM #8
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Even the manual lever models still have the same electronic actuators to engage the front diff so it’s not an entirely mechanical system anyway.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 03:40 PM #9
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Used low mileage used TC is less than 1k.
It still tempts me.
delloro is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 06:14 PM #10
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
It should be possible, the easiest way would be to get salvaged parts (transfer case, selector lever, any connection parts etc from a trail/pro).
As others have mentioned not really worth it but I don't think in the grand scheme it would be that hard to do.
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 07:31 PM #11
I wonder what kind of electronic control module differences there are. You might need some different control modules potentially.
1998 BMW M3/4/5
4wd , dial , install , parts , shifter
remove shifter housing to re-attach shift cable? amheck 4th Gen T4Rs 11 03-26-2023 08:18 PM
How to remove 5th gen 4WD selector dial? n2advnture 5th gen T4Rs 10 10-02-2018 07:54 PM
Remove shifter cover/bezel? Mvm 4th Gen T4Rs 1 08-14-2018 11:21 PM
Loose AutoTrans Shifter Lever octanejunkie 3rd gen T4Rs 12 03-17-2018 04:51 PM
Lever shifter to engage 4wd... BeastSlayer 5th gen T4Rs 19 09-15-2013 08:01 PM
