10-23-2020, 11:30 PM
Snow chains for 2020 4runner?
Have 2020 4runner trd off-road and will have falken wildpeak a/t3w which I believe are SLIGHTLY larger than stock, but I guess the same standard 265/70R17 size.
On my previous Audi it specifically recommended no chains so I remember trying to specifically get very low profile ones. Doesn't seem to be an issue on the 4runner, but I saw notes about 5mm diameter for the chain... links? Don't know if that's plenty or on the smaller size. Only other thing I caught was mention to avoid damage to the alloy wheels.
Any recommendations for a chain? I have specific roads where I ABSOLUTELY need them, so no need for comments that they won't be needed
10-24-2020, 11:57 AM
Real Name: BobH
Real Name: BobH
Peerless Z Chains. Easy to install, no tensioner needed.
10-24-2020, 12:30 PM
Wait for it. wait for it. Cutthroatslam will chime in here soon.
signature not available
10-24-2020, 12:54 PM
Might I suggest proper snow tires from Nokian's Hakkapeliitta & Nordman lines? I run the Hakkapeliitta 9 SUV's November through March and have never ever had to use the chains I carry. We have property in the Wallowa Valley in eastern Oregon and frequently drive from Portland to Enterprise through the Columbia River Gorge and over the Blue Mountains east of Pendleton. Get some very serious moisture rich icy weather in those zones. It's not lovely dry champagne snow like Colorado and Utah. BC gets some similar winter conditions. Just a thought...
The chains I do carry are SCC Security Chain's Whitestars. Only test fit them in the garage though.
10-24-2020, 11:30 PM
I agree with StuB -- get some good snow tires. In my long life, I have needed chains on my 4x4 only a couple of times.
10-24-2020, 11:32 PM
Geez guys, I specifically said
I past checkpoints with parks officers - you don't only need to have them, you need to have them ON. no exceptions.
10-25-2020, 01:01 AM
And I specifically also said: "The chains I do carry are SCC Security Chain's Whitestars"
10-25-2020, 01:14 AM
Real Name: BobH
Real Name: BobH
If you need more than the cable chain I posted earlier,
10-25-2020, 11:47 AM
I have the Z chains, but have never needed them. I run Nokian Studded tires on the 4Runner in the winter. The Z Chains are easy to get on. I would recommend a dedicated winter tire if you are on those roads as well as having the chains. The WPs are a good all season, but dont come close to the Nokians.
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
10-25-2020, 12:42 PM
I have a set of Rud chains. Originally bought them for my 4th gen I think but recently found them in the garage.
The few times I used them, they were pretty good.
Tire Chains — RUD Chain USA
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
10-25-2020, 03:23 PM
I have 2 sets I used on my xterra and my 4runner. The diamond-pattern type, and the ladder type.
Even though the diamond pattern is supposed to be easier to install, I find the old-style ladder type much easier. The diamond-type rides much smoother.
I don't know which I would pick for sure, but it would likely be the simple, easy ladder type, unless I knew I would have to drive longer distances or higher speeds. Then the other kind.
10-25-2020, 04:39 PM
We have family in North Van and Kelowna that we travel from Edmonton to see every Christmas season. I've always ran studded Duratracs on my 4r and my wife's xterra (when she had it). No matter what the conditions on hwys 1, 5, 7,3, 97a/b/c/x, or 99, neither of us have ever had issues.
That said, if you figure you need chains, try these guys
I'm curious though, where are you driving?
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
