Old 10-26-2020, 10:38 PM #1
jmc8387's Avatar
jmc8387 jmc8387 is offline
jmc8387 is an unknown quantity at this point
jmc8387's Avatar
I cannot seem to dim the navigation screen on our 2021 4Runner
Hello everyone, we purchased a 2021 4Runner TRD Off-Road Premium last week. I have one issue I cannot seem to figure out. The navigation screen is incredibly bright at night.
Every other car we have with a navigation system, the screen will automatically dim, go into night mode when the headlights are on. Our 21 4Runner, remains insanely bright, to the point where it is a distraction when driving at night.
I have looked through the owners manual and messed around in various screen settings without coming up with any function to turn on automatic dimming when the headlights are turned on.
For those with a 20-21 4Runner, do these vehicles have an automatically dimming multi-media system screen? If so, where is the setting located?
I greatly appreciate any input and direction.
1995 Toyota 4Runner SR5 V6 4WD
1999 Toyota 4Runner 4WD Limited
2021 Toyota 4Runner TRD Off-Road Premium
jmc8387 is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 11:46 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Seems to me I had the same problem with my Toyota RAV4. The trick is to adjust the instrument light control below max brightness (or vice versa).
fkheath is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 11:52 PM #3
jizzle jizzle is offline
jizzle is on a distinguished road
Originally Posted by fkheath View Post
Seems to me I had the same problem with my Toyota RV4. The trick is to adjust the instrument light control below max brightness (or vice versa).
This is the correct answer. instrument cluster dial set to 1 click below max and it will automatically dim the nav.
jizzle is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 12:11 PM #4
eriktp eriktp is offline
eriktp is on a distinguished road
I was also getting blinded by it when I picked up my 2020 TRD OR. There is a brightness and contrast setting in there in the main menu. I dont remember exactly where it is but I did find it and turn them down to their lowest setting and its a lot better.
2020 White TRD OR Black TRD Wheels/Ko2s
eriktp is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 12:55 PM #5
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
To be able to auto dim the dashboard lights, you need to have this ~$10 mounted (Fit for Toyota Camry 89121-50020 Automatic Ambient Light Lamp Control Sensor New | eBay). Never mind it's for Camry, it will fit. For non-premium models, it does not exist but the harness is there.
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 02:39 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
If you want it to dim with darkness automatically yes, but as others have said it will dim when you turn on the headlights if the dimmer control is below its maximum “notch”.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 02:49 PM #7
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
yep, that's what I said, for auto dim
2018 TRD OR
Old 10-27-2020, 02:57 PM #8
I mean it “automatically dims” when you turn on the headlights too...which is what the OP asked about.
1998 BMW M3/4/5
Old 10-27-2020, 10:13 PM #9
"Harness is there"? Please be more specific, especially with install instructions for 5th gen 4Runner.
Old 10-28-2020, 02:01 AM #10
Area52 Area52 is offline
Area52 is on a distinguished road
Does this one work on 20+? I thought I read somewhere Toyota changed the plug so the sensor everyone was using on 19s and previous no longer works.
Area52 is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 05:50 AM #11
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
That part number does not work for 2020 and later
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 05:58 AM #12
You just need to turn the dash lights brightness switch below the max- brightness click and they will dim when you turn on the head lights
You dont NEED to replace the dummy sensor with a functioning sensor but if you decide you want the infotainment to dim on its own then you can replace it with a functioning one.
See my post #316 in this thread for the correct part number.
https://www.toyota-4runner.org/5th-gen-t4rs/274513-my-$5-mod-5-mins-22.html
Sunroof
Old 10-28-2020, 07:36 AM #13
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Page 89 of your owners manual, Section 2-> Instrument Panel Light Control
"■The brightness of the instrument panel lights
When the headlight switch is turned to on, the brightness will be reduced
slightly unless the control dial is turned fully upward."
jhguth is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 08:17 AM #14
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
I followed RichinRidgewood instructions here: https://www.toyota-4runner.org/5th-gen-t4rs/274513-my-$5-mod-5-mins-22.html
For me (2018 TRD OR) the space to use the trim tool was not sufficient so I used a paint can opener like this Hyde Tools 46455 Paint Can Opener - Hyde Tools but I got it from Home Depot.
One more thing, protect the dashboard with some paper when using either tool to take out the dummy plug. The dash can be scratched very easy.
2018 TRD OR
Old 10-28-2020, 08:18 AM #15
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
Good catch, I did not know.
2018 TRD OR
4runner , headlights , navigation , night , screen
2020 4Runner Navigation Update (8 in screen with CarPlay)--Is everyone happy with it? arouth 5th gen T4Rs 40 05-13-2022 11:55 AM
Customize the Splash screen EnTune navigation screen PCRIDE4RUNNERORG 5th gen T4Rs 19 02-29-2020 11:21 PM
My 2011 4Runner Navigation Screen frozen Garcia9876 5th gen T4Rs 0 02-06-2019 10:14 PM
Navigation LCD screen Mark_W 5th gen T4Rs 4 09-22-2015 12:24 PM
Navigation screen out??? phishtaco Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-12-2009 11:02 AM
