11-04-2018, 01:39 PM
Are You On The Fence About The AJT Keyfob?
Do yourself a favor and just buy it.
I couldn't decide whether or not I wanted to risk destroying my transponder, so I went back and forth for a couple weeks about whether or not I wanted to buy it. Eventually I decided to go for it, thinking I'd just use my valet key and keep this on the keyring like a normal fob instead of the all-in-one style. I had it like that for about 2.43 seconds before I realized it was much too bulky. I didn't feel like going out to the garage to get my heat gun, so I used my wiffe's hairdryer. I took my time and repeated the "heat and scrape" routine until the transponder just fell right out of it's little pocket. Honestly I had more trouble separating the key from the fob than I did getting the transponder out.
11-04-2018, 02:48 PM
Real Name: Chris
Real Name: Chris
My biggest concern has been the transponder chips as well
11-04-2018, 03:25 PM
I think if one of my keys got banged-up this would be a great option rather than buy a blank on eBay and getting the blade cut at the dealership, etc...
Cool, innovative little products.
11-04-2018, 04:03 PM
11-04-2018, 04:36 PM
Guess I'll be the one to say it. I'm not spending $30+ on something that doesn't look any better than the OEM one nor has any advantages over it.
11-04-2018, 04:40 PM
They make sense if you break the plastic housing on an OEM key as a method of repair, but I agree, not a mod I'd seek out if I didn't have a broken key.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
11-04-2018, 10:52 PM
Real Name: Ryan
Real Name: Ryan
I really like mine as well. I had two keys so I figured, why not? If I destroyed one, I would still have one transponder key and the valet key. In the end, it was simple to take it apart. I used a cigar lighter, razor blade, and a small pliers. Took maybe 3 minutes. I went with a black fob, grey buttons, and red screws. The ordering experience was nice as well. I might even buy another one just to have.
2014 T4R SR5P. Level 8 MK6 -10 offset wheels. 265/70/17 BF Goodrich KO2's. Bilstein 5100's set at 1.75” up front + cornfed 1” rear spacer. AJT Key Fob. 20% window tint. AVS bug/ rock deflector. Gobi stealth rack. Pedal Commander.
11-04-2018, 11:09 PM
So for those who destroyed the transponder on your first attempt... here's a SUPER easy solution...
All of you need to do is spend a few bucks and buy some blank G keys on eBay (I think I got two blanks for $14 shipped), these generic keys have transponders that aren't glued in and nearly fall right out after two simple cuts. Then either find someone local with Techstream or spend $30 and buy it and the cable yourself, and spend another 3 minutes programming the new transponder... Boom, working key!
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
11-05-2018, 02:01 AM
Real Name: Neal
Real Name: Neal
They do not wear well.
I've had mine since middle of March. Looked cool, not worth $35, but looked cool.
Also mine is starting to crack.
Not looking forward to spending another $35 to fix it after less than 1 year. If you going to do it you might as well buy enough to last however long you own the truck.
Here's what it looks like after 8 months of normal use. Red arrow is pointing to where the crack is starting. Not good.
Note: Contacted seller and they replaced them under warranty
Reason: updated info
11-05-2018, 02:04 AM
I like my AJT keyfob. Install was super easy, I didn't have any issues with removing the transponder chip.
11-05-2018, 02:31 AM
Real Name: Neal
Real Name: Neal
Actually just looked at the AJT website again and it looks like they have 1 year warranty. I might be in luck!
11-05-2018, 08:16 AM
i noticed that mine has a hairline crack in exactly the same spot...
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
11-05-2018, 10:13 AM
Did you ever contact him? I had same issue and he sent me replacements for free in like 2 days. On top of that he said the design has improved since first release. His CS is spot on.
2014 SR5 / C4Fab Slimline Bumper w/winch / Extreme LED 30" Lightbar / C4Fab Rock Sliders / Bilstien 5100's / OME 885s Front Springs / Icon 2" rear Springs / TRD Intake / TRD Skid Plate / TRD Wheels / Rally Armor Mud Flaps / General Grabber AT2s / Prinsu Roof Rack / CREE LEDs / Custom Livery
11-05-2018, 10:14 AM
My old OEM Lexus keys on my IS would crack at that exact same spot. Lexus replaced them but the dealer told me the trick to avoiding cracks is to hold the key at that spot when turning instead of at the back of the key. I never cracked another key in the 9 years I owned that car. Turn the 4runner key the same way and no issues.
2017 MGM TRD Off Road Premium
11-05-2018, 10:45 AM
Real Name: Micah
Real Name: Micah
Of all the vain things people do to their 4Rs, $30 for a new key (so long as you don't destroy the device and require a new $300 key), is small potatoes
