Old 05-23-2021, 12:38 PM #1
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Skid Plate Bolts - anti-seize, thread-locker, nothing?
I was taking off my gas tank skid yesterday before getting my gas pump recall fixed this week (I don't trust the dealer not to strip skid bolts etc.) and noticed one of the bolts in my RCI transmission skid had fallen out in the last few weeks.
When I put them on, I believe I used some anti-seize but it was several years ago and can't remember.
What's the consensus on that - is it best to use anti-seize or do people use thread lock instead?
Bonus points - is there a torque spec? The RCI instructions just say "tighten."
rageandlove is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 12:49 PM #2
glwood54 glwood54 is offline
glwood54 is on a distinguished road
Anti-seize is never a bad idea on bolts that will periodically be removed. It does affect the torque values, however, and you have to account for that. Plus, as you mentioned, they could work loose, so a periodic check is a must.
2019 MGM OR, KDSS. Eibach struts @ .84, shocks. RSG flat sliders w/grip plate. 265 Falken Wildpeak.
glwood54 is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 12:54 PM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
As stated, antisieze is good on your application.
Make sure you have lock washers on your bolts. Stainless is probably best or zinc.
Best Regards,
Saker
Old 05-23-2021, 01:20 PM #4
LeekT4R's Avatar
LeekT4R LeekT4R is offline
LeekT4R will become famous soon enough
LeekT4R's Avatar
242 loctite
LeekT4R is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 02:55 PM #5
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
I do antiseize on all my RCI skids bolts, everything I've found on those bolts says 22-23 ft pounds...
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 04:49 PM #6
Metalsaber Metalsaber is offline
Metalsaber is on a distinguished road
Anti seize. Threadlocker is best for stuff that you have no intention of removing.
I've seen anywhere from 25-30 ft/lbs
Metalsaber is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 06:24 PM #7
Gstick Gstick is offline
Gstick will become famous soon enough
Been using anti-seize on the stainless steel bolts that hold up my RCI skid plate. Every oil change (10,000 miles) I drop the powder coated skid plate down, do the oil change, then put fresh anti-seize back on the 4 bolts. Easy peasy.
Best $300 that I've ever spent was for the RCI skidplate.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 11:15 PM #8
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Anti-seize for skid plates. You never know when you need to take them off to clean when they get caked in mud or dirt and to change diffs, t-case fluid.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
anti-seize , bolts , gas , rci , skid
Anti-Seize AE1M 4th Gen T4Rs 15 04-29-2020 09:02 PM
PSA: Anti-Seize Your Lower Shock Mounts JSparky 5th gen T4Rs 5 01-31-2019 01:12 PM
Anti-Seize... Worth it? hamburglar210 5th gen T4Rs 26 01-02-2019 06:49 PM
Loctite blue or anti-seize paste for skid bolts? Tallman 5th gen T4Rs 16 12-19-2018 04:47 PM
Used Dielectric Grease instead of Anti Seize...help! dilip4runner1 3rd gen T4Rs 4 05-26-2014 11:20 AM
