Originally Posted by Saker
DRL Disable on 2021 4Runner
New 2021 4Runner TRD Off Road
Looking for the solution to disable the DRL on a 2021.
This is different than the earlier versions and if someone can point me to the proper solution, that would be great!
Maybe some of the gurus can shed some light....
@ rigtec
@ Antman
Pictured are the new fuse locations. I cant find the familiar relay!
I found the relay!
Hi Keith,
Always good hearing from you, and so glad you're: "On the road again"
Lol!
Very recently, I did a mod involving maintaining the
Factory fogs even with the
"High Beams" in operation. The reason I did that was because, I've got GREAT Lighting on the street using powerful LEDs for close range vision on dark streets, but when I need to see a bit further up ahead, why sacrifice the 30 ft advantage close-up, follow(?)!
Okay, so since the
Main Body ECU Compu net removes the
GND to the factory fogs when the High Beams are in use, I didn't wanna tamper with that system, so I approached it another way!
I installed a
30A, 2PDT relay under the hood! The
10A High Beam fuse is energized when you "flash/turn-on" the High Beams; and the fogs become disabled by the MB-ECU at the same time! To get around that, I used an "Add-a-Circuit" in the High Beam fuse slot at the Main fuse-box under the hood!
So when they're on, it energizes the coil circuit (term# 86) for my new relay. I'm using the (no longer used)
"Party-mode" switch as a
GND switch to term# 85 on my relay coil! I have a (
15A) in-line fuse connected directly to the battery...
...which feeds terminal #30 (input), on my rly, and term# 87A (N/O), feeds the Green wire on one of the fog-lights (one wire feeds BOTH fogs); the
WH/BLK GND wire to the factory fogs are already grounded to the chassis! So when I hit the High-Beams, even though the MB-ECU kills the GND to the factory fog relay, my relay feeds the fogs when the High-Beams come on!
I think you can do the same by breaking the
GND or the
HOT wire to your DRL circuit under the hood; but instead of using the
87A terminal on your relay, you use term#
87 (N/C), and the DRL's should turn off with an
AOB switch in the cabin!
That DRL bulb circuit is very likely grounded on the chassis as are the factory fogs; hence the
NEG-Side Switching technology, but the factory relay's GND is controlled by the MB-ECU, so you just kill those lamps with your own relay! Please let me know what-cha think Keith!
'Best to you & yours'
rig, cheers!
