10-29-2020, 02:00 PM
#16
WD40 is NOT a lubricant.
10-29-2020, 11:22 PM
#17
Thank you guys, I got so many useful suggestions. I think I will try to take off wheel and access to rotor to see if I can break it loose. One question, this is full-time 4WD system. Can I actually push or spin the rear wheel in neutral?
10-30-2020, 01:55 PM
#18
You may have a tough time pulling the rear rotors if the emergency brake pads are stuck to the rotors. Make sure you try to turn the adjuster with a screwdriver through the hole in the rotor. I believe you will want to spin the adjuster in the downward motion to release tension. Also, use a bolt in the threaded rotor hole to push it off the hub.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
10-30-2020, 02:43 PM
#19
I don't see a stuck parking brake causing this. Its just two small drums. I like the try in 4low idea. If its just the stuck parking break drum that should break it free. As Jivewalker said. Getting he rear disk off will be a challenge if it is stuck. turn star adjuster down to loosen, tap with hammer, heat it up with heat gun/hairdryer.
The engine has power right? It revs and the truck tries to move?
My third gen had the rear drum stick due to a leaking rear oil seal. It was worse when cold outside. but still, it would break loose with a little throttle. And that was a 3.4, lol
What a terrible surprise. sorry for your trouble.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
10-30-2020, 03:25 PM
#20
Mine does this every so often, because I also don't drive a lot. Especially bad if it's put away wet. My solution has always been what others have said, put it in 4 Lo and drive until it snaps free. The same should work with the all-wheel-drive system, I would lock the diff and just give her hell.
Opinions vary though.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
10-30-2020, 08:46 PM
#21
I’ve had similar experience to Meefsah, where the rotors stick if it’s been parked wet. Even overnight after washing will seize mine up. I put in low and apply accelerator until it breaks loose, usually with a bang. Most of the time I remember to go for a short drive after washing it and that avoids the problem.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
11-03-2020, 02:14 PM
#22
Well, were you able to move it?
I am fragile.
Not like a flower.
But like a bomb.
