Originally Posted by llDemonll
A car in neutral can be pushed if the brakes are not applied. Even a semi truck might be able to be pushed by one person.
You won't be able to push your 4Runner though if reverse or drive can't move the car. Brakes are seized, you'll either need to take the wheels off and use a hammer / force to free them, or put it in gear and use more gas. Don't hit anything when it breaks free.
Thats what I would do, take the rear wheels off and bang the rear brake rotors with a hammer until the emergency brake shoes inside the center rear rotor/drums shakes loose enough to hand spin the rotors. Most likely rust and crud is built up causing them to seize.
If you can barely spin them, try to line up the adjustment hole so you can adjust the emergency brakes with a tool to loosen up the rotors.
Then have the brakes inspected and maintained properly.
