Old 10-29-2020, 11:40 AM #1
JasonXP JasonXP is offline
JasonXP is on a distinguished road
What coils to use with Bilstein 5100s?
I ordered a set of Bilstein 5100s but I searched the forum and couldn't get a straight answer. What kind of coils should get to pair with the Bilstein to achieve a 2.5" lift in the front and 1.5" lift in the rear.
I was thinking about using the OME 884 springs in the front and a 1.5" daystar spacer in the back. However, some website said the 884 will give you a 2.5-3" lift and other said the 884 will give you a 2" lift. Also, are there any springs that gives you no more than 1.5" lift in the rear. Seems like a lot of people got more than advertised.
The goal is to lift and fit 285s and hopefully not have to replace the UCA or do a BMC. I use the car as a daily 90% of the time btw.
JasonXP is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 11:59 AM #2
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
People say anything over 2" on the front then you need new UCA.
I went Dobinsons since they have a lot of spring choices
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 12:11 PM #3
How long have you had your 5100/Dobinson combo and you like it?
I could do the 302/599 springs.
Old 10-29-2020, 12:15 PM #4
4 months and I like it. No complaints on the ride quality.
Sounds like the eibach kit might fit your needs.
Eibach Pro-truck lift
Old 10-29-2020, 12:44 PM #5
Actually, I might look into the Eibachs
Old 10-29-2020, 01:30 PM #6
power818 power818 is offline
power818 is on a distinguished road
This was not the case for me. I am at 2.5/1.5 with the Bilstein 5100 setup and had no issues getting proper alignment.
2019 Midnight Black SR5 4Runner - Black TRD Sema Wheels, Predator Tube Steps, Bilstein 5100 Shocks front and rear, 1.5" Daystar Rear Spacer with 2.5" of front lift, 285/70/17 BF Goodrich KO2's, Blackout Emblem Kit, Black Vinyl Wrapped Roof Rack, Black Chrome TRD Exhaust Tip, Lock'er Down Console Safe.
power818 is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 01:38 PM #7
I installed Bilstein 5100's all the way around with stock coils. I set the front shock to 2.5", and in the rear, I went with the 1.5" daystar spacer. I did a full write up on it if you are interested. Bilstein 5100 2.5" Front and Daystar 1.5" Rear Spacer Write-up
I personally felt like this lift improved my ride quality significantly and only cost me around $450 out the door. The suspension is a little more stiff when breaking and turning, but I felt this helped the body roll and nose dive significantly. I definitely wouldn't say it rides rough now, just a little more stiff when it needs it.
I also did not add new UCA's with this setup, and I had no issue getting proper alignment. I am running the TRD Pro wheels and stock tires, but I am looking to upgrade to 285's soon. My personal recommendation would be to run it with your stock coils. In the future, I might upgrade my suspension again by setting the front Bilstein back to base height and adding lift springs all the way around. I would probably go with Toytec's 3/2 lift kit if I did that, but I would probably have to get new UCA's then.
Old 10-29-2020, 02:08 PM #8
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Stay away from OME springs. You will absolutely find that they'll bag out within months.
Since this is a mild lift, you can run the stock coils with a spacer in the back then adjust the preload on the 5100's to achieve your ride height goals. This set up won't perform amazing offroad, but you would have selected something other than an entry level coilover if that was your goal, right?
As for the question of uca's, you will need to upgrade if you're having problems getting your alignment back in spec, or require the extra caster to clear 285 or larger tires. If you plan to stay at 2", or with the 265's you should not need uca's
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 08:38 PM #9
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Eibach and bilstein both have springs rated for 1.5”. If you get the 4th gen Eibach front springs they’ll give you 2.25 to 2.5 lift.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 10:58 PM #10
cruf665 cruf665 is offline
cruf665 is on a distinguished road
Did you ever come to a solution regarding your issue?
Im Looking to use 5100's but as an light off-road vehicle. A lot of desert moving and forest roads. And have been struggling to pin down exactly what Spring I should run regarding this? Generally hauling a full trunk of gear and 4 passengers. My 4runner is entirely stock at the moment so no added weight in terms of bumpers or winches.
Any help here would be awesome.
cruf665 is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 08:30 AM #11
meltdown meltdown is offline
meltdown will become famous soon enough
I’m using Dobinsons for the front. Stock spring with corn feed spacer in the rear. No complaints. They have plenty of lift options to choose from and are affordable. They also have a good reputation for quality.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
bilstein , coils , lift , rear , springs
Bilstein 5100s with eibach coils 4runnerAzGuy 4th Gen T4Rs 12 07-21-2020 09:28 AM
Bilstein 5100s with 99 tall rear coils? yotadawgjr 3rd gen T4Rs 4 03-20-2017 03:04 PM
Advice on RAS swap to coils/Bilstein 5100s theory6 4th Gen T4Rs 8 03-30-2015 12:21 PM
WTB: 4th gen rear coils & Bilstein 5100s cjhall For Sale: Suspension/Wheels/Tires 2 08-17-2014 10:18 AM
Finally Installed FJ Coils/Bilstein 5100s :D Brian757 3rd gen T4Rs 12 07-21-2012 08:06 PM
