09-12-2016, 06:59 PM
Can I power a TV off my rear plug
Can I power a television off my rear outlet or is there not enough juice?
2013 LTD 4x4 Magnetic Gray; Weathertech liners, Airlift1000, Camelback Metal Gear roof rack, Interior LEDs, trail rocker panels, Shrockworks step sliders, TRD Pro wheels, Cooper Discoverer AT3s 255/75R17
09-12-2016, 07:08 PM
Real Name: Matthew
Real Name: Matthew
If your TV is within the wattage of the outlet, you'll be good. The built-in inverter will auto-shutoff if you exceed the wattage.
Maximum available capacity of the power outlet
■ While the vehicle is being driven
The maximum capacity of the power outlet is always 120 V AC/100W.
■ When the vehicle is stationary
The maximum capacity of the power outlet varies depending on
the position of the shift lever.
● The maximum capacity is 120 V AC/100 W when the shift lever
is in any position other than P or N.
● The maximum capacity is 120 V AC/400 W when the shift lever
is in P or N.
The maximum capacity of 400 W can only be restored by turning
the power outlet main switch off and then on again with the shift
lever in P or N.
[2016 TRD Pro 4runner | Super-White | Yakima Cross Bars |Solimar Adventure Co. RTT |King 2.5 F&R Suspension w. Adjusters| Icon Overland Rear HD Springs|Falken Wildpeak M/T 33"| Rigid D2 Amber Fogs | CBI Dual Swing Out Rear Bumper | Double Jerry Can / HiLift ] [ 2018 Toyota Tundra TRD4x4 Off-Road | Cement Grey | Bilstein 2.5" Front Lift | Method NV Wheels] [1967 Toyota FJ40 Landcruiser OME 3" Lift, 327 SBC]
Reason: Updated facts
09-12-2016, 07:12 PM
Yeah, what he said.
09-12-2016, 07:14 PM
A 32 inch LCD uses about 125-150 watts
09-12-2016, 07:25 PM
Sweet. Sounds like it should work then
09-12-2016, 07:26 PM
Does the vehicle have to be on for those wattages?
09-12-2016, 07:37 PM
Banned
Banned
has to be on for the built in outlet, but a standalone inverter that you could wire to the battery for that wattage wouldn't be expensive
you might have a problem with the power supply overheating because its a modified sine wave but i doubt it
11-04-2020, 11:27 AM
You haven't lived unless you've watched a good college football game over the air on a camping trip with some good buddies! Cheers!
Originally Posted by Jacyahoo
Of course, you can, but I would like to ask you what's the reason you've decided to power off your TV this way.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
11-04-2020, 02:14 PM
Real Name: BobH
Real Name: BobH
Is the built in inverter output clean enough for sensitive electronics?
Some inverters output a modified sine wave, not sure how that is for electronics.
11-04-2020, 07:45 PM
Banned
Real Name: Tobias Fünke
Banned
I find the plug to be useless other then charging stuff on the go.
11-04-2020, 08:39 PM
They also make 12 volt TV's that plug into your cigarette lighter socket.
We have one in our camper.
