Old 10-30-2020, 06:06 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Is my coolant leaking?
I opened up my hood today and upon closing it, noticed the dried pink fluid around the coolant area.
It is 2020 with ~11,500km on it. I know nothing about this stuff, but surely didn't expect to see it there!
Is my coolant leaking?-pxl_20201030_215425644-jpg
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 06:08 PM #2
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Check to see if the cap is fully on!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 07:45 PM #3
ScottR ScottR is offline
ScottR is on a distinguished road
Pretty common, had the same happen on my 2014. If the reservoir is within margin and cap is tight I wouldn't worry about it.
2014 Super White TEP, Dobinsons 2"/1" lift, Firestone Destination AT2 265/70‑17, OEM led headlights 81070-35600/ 81140-35610
ScottR is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 07:55 PM #4
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Dealer probably overfilled it. My res used to burp fluid if I filled to the “F” line then would settle about midway between the marks. I no longer add fluid and it’s never gone lower than the “L” when at room temp.
Is my coolant leaking?-1f5e7f2c-be10-4819-859a-9dc6fac4a871-jpg
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 08:18 PM #5
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Yep. If the cold level is at the FULL mark you may see it expand some out the top. I set mine so that it's at the FULL mark when fully warmed up.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 08:41 PM #6
Ah, yeah mine is fairly close to the FULL line.
I imagine it spilling out is... not problematic?
Old 11-02-2020, 10:29 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
No worries, mine does this and doesn't lose coolant. I believe its just evaporation around the cap. Hose it off and make sure the reservoir is at correct level when you check the oil, etc.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 07:12 PM #8
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Had my 11 FJC burp a bunch of coolant when in the middle of nowhere Canyon of the Ancients. Greatly concerned me at the time considering the location. I'm assuming the reservoir was a little too full and the coolant got a little hot crawling in 4low. Same drivetrain as the 4R.
Only time it ever happened in 100,000+ miles.
As others said check the coolant level, clean it off and see if it comes back.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 08:45 PM #9
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
I bet that did get your attention out there though!
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 10-26-2023, 06:36 PM #10
Rocko9999 Rocko9999 is offline
Rocko9999 will become famous soon enough
Same thing happening. Need a rubber gasket on the cap. Strange there isn't one.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 09:50 AM #11
4RL75 4RL75 is offline
4RL75 is on a distinguished road
Same thing with my 2023, it´s overfilled. When truck is cold the level is a little over the full mark. I´m going to take some out and leave about 2 fingers from the full line and check if that does the trick.
4RL75 is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 02:59 PM #12
Common issue with the gasket on the overflow cap. It dries out and stops making a good seal. You can flip it over and try that or buy a new cap. Also can make a gasket out of a piece of rubber innertube from a bike.
coolant , expect , stuff , surely , ~11
Leaking coolant from....? TrexRunnerGirl 3rd gen T4Rs 3 12-27-2019 06:48 PM
coolant leaking somewhere zoombyu86 3rd gen T4Rs 3 07-28-2016 10:14 AM
06 SR5 V6 Leaking Coolant peroxide 4th Gen T4Rs 10 07-01-2015 11:59 PM
BIG Coolant Leaking [HELP] mistersnowman97 Classic T4Rs 5 02-27-2013 02:49 PM
Leaking Coolant JRR Classic T4Rs 6 08-16-2012 10:02 AM
