Old 10-31-2020, 01:53 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Ideas for mounting REAR dashcam?
I've run all my wires and had my rear dashcam set up for a bit, basically set up something like this:
https://cdn.shopify.com/s/files/1/29...G?v=1558999057
Held on to the ceiling via that headliner clip. I didn't end up liking it for 2 main reasons:
- While fairly low profile, I managed to knock it a bunch with either my head or cargo
- I guess I could have adjusted further, but it sits "back" from the window, so any dirt easily gets in the way plus the heating element lines.
I was thinking I'd actually rather have it mounted to the hatch and to raise up out of the way when the hatch is open.
I'm not really sure HOW to go about this though - with the hatch closed, there is seemingly no gap between the window frame and the car frame/weatherstripping.
Any ideas for how to attach the camera to the hatch door frame rather than the back window?
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 02:05 PM #2
Whippersnapper02's Avatar
How about to the roof:
4th & 5th Gen. 4Runner Rear Dashcam Mount by CasperSPT - Thingiverse
Install BlackVue DR650GW-2CH rear camera in 2015 Toyota 4Runner - YouTube
I printed the mount but haven't mounted it.
Old 10-31-2020, 02:34 PM #3
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
What brand do you have? I have a BlackVue mounted in the same spot and have had no issues as far as visibility out the window. Did hit it a couple times at first, but adjusted quickly.
Just off the top of my head without looking would be running the wires in the same channel as the rear window control/backup cam wires into the hatch. Should be able to come out in the same place as the backup cam, just might have to drill another hole.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 10:00 PM #4
seLect seLect is offline
seLect is on a distinguished road
Imgur: The magic of the Internet
That's how mine is set up.
Obviously for the missing lines, both lines meet at the corner. Same concept as the front right corner except on the other side. A cheap money clip or a clasp-like with a silver plate and insert it in between the head liner and use 3M tape for the camera/clip. No drilling, no tearing needed.
Unless your rear camera is a brick - this should be the perfect solution for you.
2018 4Runner Blizzard Pearl
seLect is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 10:35 PM #5
Yeah yours is very similar to mine, but I guess yours is even more low profile. I also moved it "forward" a bit to be a bit closer to the window, but that also means it doesn't tuck into the roofline as well.
Ideas for mounting REAR dashcam?-dashcam-jpg
Old 08-15-2023, 10:25 PM #6
N8thegreat N8thegreat is offline
N8thegreat is on a distinguished road
I ended up doing this. Drilled a small hole in the mount, cleaned the rubber at top of window very well, stuck it on then reinforced with a self tapper. Checked the window slot, and it didn't pop through to hit window. It's about as high as it can go!
Ideas for mounting REAR dashcam?-pxl_20230816_014833122-jpg  Ideas for mounting REAR dashcam?-pxl_20230816_014828795-jpg  Ideas for mounting REAR dashcam?-pxl_20230816_014821483-jpg
N8thegreat is offline   Reply With QuoteReply With Quote
Old 08-16-2023, 03:41 PM #7
Milo99 Milo99 is offline
Milo99 is on a distinguished road
Plexiglass
I mounted a dash camera to the end of a sheet of plexiglass. I just stick it above the passenger side sun visor so it sticks out the front. I could use a longer piece of plexiglass and mount the rear camera so it looks through the whole cabin toward the back. I know this isn't ideal to get the best rear view video, but it is completely removable without making any holes or sticky tape residue. I use it in rental cars this way. It's pretty universal.
Milo99 is offline   Reply With QuoteReply With Quote
Old 08-16-2023, 06:12 PM #8
Philip.'s Avatar
Philip. Philip. is offline
Philip. is on a distinguished road
Philip.'s Avatar
Mounted mine of the bottom of the window
Drilled a small hole to run the wires for the BlackVue and used 3M tape for the camera on the moulding. Threw a small grommet in the hole for the finishing touches and I have had this set up for a year at least and the rear window is down quite a bit for the dog. No issues with it moving around or the wind blowing it out the back.
Ideas for mounting REAR dashcam?-img_4955-jpg
17' TRD OFF ROAD - White
Haulin Bikes with 1upUSA Heavy Duty
Haulin Weimaraner’s with Variocage Max
Philip. is offline   Reply With QuoteReply With Quote
Old 08-17-2023, 12:26 PM #9
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Wow very clean, love this idea
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
Old 08-18-2023, 10:28 PM #10
Philip.'s Avatar
Philip.'s Avatar
Here is a better pic of the hole and grommet.
Ideas for mounting REAR dashcam?-db854494-e153-4dbe-87b9-50e289e2dd37-jpg
back , frame , hatch , ideas , window
Dashcam install: Mounting + wire+trim advice kaitlyn2004 5th gen T4Rs 11 08-24-2020 11:32 AM
Radio Mic Mounting Ideas FLY_FISHING 5th gen T4Rs 2 01-14-2020 11:06 AM
Cb radio mounting ideas 98yota_guy 3rd gen T4Rs 14 06-02-2014 04:23 PM
winch mounting ideas hurt4x 3rd gen T4Rs 41 07-21-2013 08:56 AM
New ideas for mounting my amp! jrh607 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 05-15-2005 08:57 PM
