Old 11-01-2020, 11:51 AM #1
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
Problem Removing OEM Rack
Just a heads up for anybody about to remove their stock rack. Here's an issue I ran into yesterday when trying to remove the stock TRD Pro rack/basket.
The bolts are in there tight with red thread locker. Both bolts go through a metal bracket that sits on top of the roof, through the roof itself, and thread into another metal bracket with plastic tubes that floats inside the roof liner itself. Loosen both bolts FIRST and really make sure they are completely broken free from the thread locker and can almost be removed by hand BEFORE you actually remove either bolt. Why?
If you remove one bolt and then go to break the other one free, you risk breaking that floating bracket and it will just spin inside the roof. And you're screwed at that point. This happened on one of my brackets. I was able to stick a screw driver down into the hole and capture the floating bracket again. But by that point the bracket was FUBAR. Plastic tubes sheared off and the bracket had bent.
Toyota was NOT helpful. The service department didn't even want to look at it. I'm going to have to drop the headliner inside the SUV in order to get the bracket out and replace it with a new one.
The part in question is #12:
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 12:16 PM #2
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
my thread has been out there for a while... but only useful if you came across it before you started
2019 Pro Basket Rack - Deleted
niadh0 is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 12:26 PM #3
Yeah, wish I saw that before I tried removing the rack.
Old 07-19-2021, 01:29 PM #4
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
Has anyone tried applying heat via a 1 gallon propane torch briefly to the bolts? Just saw a YouTube video on this. Apparently applying heat to the Torx bolts will soften the crazy Red Loctite they use, making it very easy to remove bolts. Or is this just stupid, guy in video applied it for what looked like just three seconds. Anyways just thought I would throw it out there. Thanks for any input, appreciated.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 01:46 PM #5
cbaty08 cbaty08 is offline
cbaty08 will become famous soon enough
I saw that on Westcott's video, and I can only tell you from my personal experience my 2021 rack's bolts were not hard at all to break free.
Give it a go with a breaker bar, and you should be OK.
2021 Lunar Rock
cbaty08 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 02:05 PM #6
Real Name: Tom
Real Name: Tom
Good to know, mine is a 2019 Pro. Also as there may be a little time between when I remove rack and mount RTT, what can I do to protect that area temporarily? Painters tape to keep junk out of that area? Thanks
Old 07-19-2021, 02:06 PM #7
Real Name: Tom
Real Name: Tom
So careful use of heat, NOT good?
Old 07-19-2021, 02:07 PM #8
Real Name: Tom
Real Name: Tom
Mine is not a DD so if I mess up it will be a PITA but is kept in a garage
Old 07-19-2021, 02:21 PM #9
KpaxFAQ KpaxFAQ is offline
KpaxFAQ is on a distinguished road
Mine snapped free no problem. I personally wouldn’t use heat but definitely loosen equally back and forth until they’re hand loose
2021 4Runner TRD Off-Road Premium with KDSS
KpaxFAQ is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 02:24 PM #10
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I don't think the red stuff is loctite. When I took mine off it appears to just be red silicone sealant just to keep water out of the threads and it broke free easily.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 02:33 PM #11
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
I made the same mistake too. I could never get the threaded clip to snap back on the tab, so I had to pull the headliner partially. (passenger side rear) I was able to then access the area and slip the threaded part onto the metal tab.
The red stuff on mine was definitely hard like loctite and not pliable.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 06:03 PM #12
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Just pop off the interior panel by the pillar and you can gain access to the retaining bracket from the inside of the vehicle. You’re not screwed at all, and the panel just pops back in.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 06:54 PM #13
Thirty4 Thirty4 is offline
Thirty4 is on a distinguished road
I know that a few of you had a good experience removing the factory bolts, but my experience was more like the Westcott’s video. All of the bolts came out OK but one. And that particular bolt was damn near welded in. I am VERY mechanical and very sensitive to pressures and torque. I can assure you I did not just grab a wrench and crank the bolt. I took my time and it still spun and twisted the piece/bracket that’s below the roof and above the headliner. I didn’t get the chance to watch the other video, so I will do that as I may need to go through the drill again on a different 4Runner, but Toyota was ABSOLUTELY helpful of me. They took care of it and it was a pretty cheap repair. Just sharing my story as I personally went through this as well.
2021 4Runner TRD Pro (Magnetic Gray Metallic)
2021 4Runner TRD Pro (Lunar Rock) - Sold
2020 Land Rover Defender 110 HSE - Sold
2016 4Runner SR5 - Sold
2010 FJ Cruiser - Sold
Thirty4 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 09:43 PM #14
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Keep it indoors!
The way it is designed is that anything that gets on the roof will get in the channels, and the channels funnel to the holes for the bolts, and the holes for the bolts will allow water both in the bolt hole and outside the plastic white piece that projects up through the roof. It will be hard to keep water out of all of that.
rageandlove is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 09:57 PM #15
Sully888 Sully888 is offline
Sully888 is on a distinguished road
I would use butyl tape/putty. That is what i used on mine on top of the spacers and below the bolt head ( i used silicon washers between the spacers and top of the 4runner).
Sully888 is offline   Reply With QuoteReply With Quote
bolts , bracket , inside , remove , roof
Problem after removing and replacing rear wheel DMX512 4th Gen T4Rs 4 10-17-2018 04:09 PM
Anyone have a problem removing rear internal bumpstops zoombyu86 3rd gen T4Rs 15 12-05-2016 08:16 PM
PLEASE HELP - Problem removing TE Step Rail to Install Budbuilt sliders bigbillyt 5th gen T4Rs 10 10-24-2013 12:59 PM
Problem with Removing Alternator aznights 4th Gen T4Rs 4 11-09-2012 12:46 PM
Removing roof rack '98 jpofsc 3rd gen T4Rs 2 01-21-2008 12:50 AM
