Old 11-02-2020, 11:30 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Yep, another roof rack question!
I started off here:
5th Gen 4Runner Roof Racks - Full-Length, 3/4 Length & Basket Racks
And then subsequently read a bunch of one-off of racks, then thought about keeping stock rails and getting those newer generation of aftermarket crossbars a bunch are offering, but I think I've pretty much settled on upgrading from OEM setup, and going for a full OR 7/8 (I feel like there's no practical difference? But 3/4 seems a bit short)
The ones that keep popping up to me are:
- Prinsu - seems people really like the style of this one
- LFD - I am not exactly positive on, but they keep popping up on my radar! Have a lot of length + material options which is nice
- Sherpa - seems a newer player in the game, and uses a different (innovative?) approach to covering/using the stock mounting holes
- Frontrunner - Cool... so damn expensive? A little proprietary too?
I'm Canadian, and I've heard of a few other canadian options, which seem like cheaper options? Seem much less popular, so hard to compare:
4Runner Aluminum Full Length Roof Rack System — GREENLANE OFF-ROAD
03-09 4Runner Modular Roof Rack | Element By RA Motorsports
Some of my desires/thoughts on roof rack:
- Like a flatter (multiple crossbars) roof rack for if I need to strap random large items to it (lumber or otherwise)
- Reducing wind noise is pretty high up there in importance
- Still plan to use a cargo box (not full time)
- Care much less about how it looks/makes the 4runner look vs functionality
Unfortunately (and perhaps obviously!) there is no good side-by-side reviews, and these aren't $50 options when you can just try things out. I've heard of horror stories about roof leaks, often times without user awareness... this scares me a ton! Is sherpa's new approach better? Time tested?
Any guidance on selecting a roof rack? Most of these I don't have any option to check out in person either, so a big big purchase to make blind. How did you select a rack? Any really viable racks I've possibly overlooked?
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 11:49 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by kaitlyn2004 View Post
I started off here:
If you use the 8 factory mounting points, all you need do is use plenty of sealant around the bolts where they screw into the roof(some use silicone and others use butyl rubber) and you won't have leaks. There is plenty of info on this on other roof rack chains.
The factory uses a foam washer at those places which leaves a lot to be desired
fkheath is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 12:02 AM #3
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
I just installed the LFD 7/8 rack on my 2020 and it was quite a bit nicer than my expectations honestly. I'm very pleased with it so far and would definitely recommend it.
I had two of their crossbars with my stock rails prior to purchasing the rack and added two more and the fairing when I did the rack. They have been great to work with and make a quality product.
I have no experience with the others you mentioned but there are tons of people with different racks on the forum.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 02:24 AM #4
I've got 2020 as well - would love to hear more about your insights on the rack - install and noise and quality and whatnot
What made you decide on the LFD?
Old 11-03-2020, 04:34 AM #5
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
A positive for the LFD is that you can start with the cross bars on the factory rack and then eventually upgrade by getting the other LFD rack components when you want the full rack. I think the 7/8s has different crossbars so check with LFD. Thats what I was planning to do but ended up settling with just the crossbars as it worked perfectly for my situation.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 10:35 AM #6
Elite130 Elite130 is offline
Elite130 is on a distinguished road
It is crazy how many rack options there are out there. I nearly drove myself crazy analyzing racks. After months of research, I pulled the trigger on a Rhino Rack. I purchased the 4Runner Backbone with the 84"x49" Pioneer platform. I chose this because I wanted a flat surface that was throughout the rack. I didn't like the large spaces between the crossmembers of all the other aluminum racks (i.e. Prinsu, Sherpa, LFD, etc). I have had mine for 8 months-ish and I have used it to haul plywood, mattresses, bikes, and camping gear. My boys and I even sat on it to watch 4th of July Fireworks. The rack has very little wind noise. If I have the sunroof shade open, there is a bit of wind noise, but if the shade is closed, I can't hear it. I really like the Rhino Rack. Well worth the money. I'd highly suggest it.
The major item about the Prinsu, Sherpa, LFD racks are the mounting feet and brackets. Not where the rack mounts to the factory mounting points specifically, but the metal between the roof and the rack itself. IIRC, Prinsu welds the mounting tabs to the rack and bends the metal for the mounts, so there is no adjustment at all if needed. Sherpa and LFD's mounts bolt the rack to the mounting feet, so there is some ability to make adjustments to alignment. Personally, I would have bought the Sherpa if I didn't go Rhino Rack.
Good luck!
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
Elite130 is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 11:17 AM #7
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I have a Sherpa rack.
Easy install, no sealant required, high quality, very well-thought-out line of accessories, no noise, and absolutely superb customer support. I'd buy it again in a second.
I think the first question you should ask yourself is sealant vs. no sealant.
If you spend some time reading forums, I think you will see a lot of chatter about how 99% of sealants need attention - silicone shrinks for example - so you will need to maintain that over time.
Many of the racks you list are similar, so the other thing I'd think about is customer support. I have a bunch of stuff on my truck now, and there are a lot of vendors that stop caring once your order is placed. Sherpa and Green Lane are the two I've used that are exceptional. Several other big and small the opposite ... damaged good received and emails not returned, etc.
Good luck.
PS one other thing about Sherpa - the bars they use allow other products to mount easily too, so you aren't locked into just their accessories.
rageandlove is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 02:15 PM #8
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
You are on the right track figuring out what your needs are. Also consider what accessories you might want to mount if any (lights, canopy, tent, etc) along with the cargo box.
Gobi Stealth is what I have that meets my needs. The wait time is long, but I’ve used their products before and was happy with everything all around.
If you are not going to have anything on the roof most of the time maybe Baja flat rack will fill your need.
Agree that there are a lot of options. Good luck
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 02:45 PM #9
From photos they look like "Standard" 8020 aluminium crossbars which is good and bad I guess. Good because so much potential without being proprietary, but bad because I'm pretty sure I'm paying quite the premium simply for them to ship precut ones to me... (whereas the Niserack posted here basically tells you to buy the bars separately cause it'll be cheaper)
You've found the sealant style on the sherpa to be good and lasting? I worry/wonder why nobody else has done their style and almost all of them are using the silicone-style sealants... and nobody else seems to have changed.
$1100 USD + $185 shipping to canada... my wallet is crying
Old 11-03-2020, 04:13 PM #10
ARB and Toyota OEM :-) use the same approach/principles as Sherpa. I think they studied what Toyota did as a starting point.
I don't know for sure, but my guess is that it requires a bit more precise engineering. Send them an email - they are super responsive.
The said on their thread somewhere else in the forum that there's a Thanksgiving sale coming if that helps.
Green Lane is on the Island if you can get there - I got some stuff from there and took the ferry over to avoid shipping etc.
PS None of this stuff is cheap - every few months I add something to my build, and it adds up ...
Old 11-03-2020, 06:10 PM #11
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
The different crossbars come into play with the full length rack from LFD; the reason being is that the full length rack is ~5" wider than the 3/4 or 7/8 (and thus factory rack as well)
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 11:47 PM #12
OutsideInCA OutsideInCA is offline
OutsideInCA is on a distinguished road
Anyone using non-Rhino brand accessory bars on a Rhino Pioneer rack? Specifically looking for more clearance (ie the standard clearance that roof rack cross bars give you, 1-2") as opposed to the only options offered by Rhino-compatible cross bars, which are all flush with the rack. I'm mainly looking to strap surfboards and snowboards/skis to my Pioneer roof rack. The additional height on the accessory cross bars allows me to strap standard surfboard pads to the bars. Very much appreciate any advice!
OutsideInCA is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 04:19 PM #13
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
How important are adding plug and play accessories to your rack? This is why I went with the Frontrunner 3/4, super functional.
FWIW this was over 4 years ago and was also before Sherpa and Greenlane were marketing and producing racks for 5th Gens.
If I were buying now Sherpa would be near the top of my list although I still love the Frontrunner. The points made about the sealant mentioned in the previous posts are true. I had a wet seatbelt after about 2 years and had to remove and redo the process. Extra sealant in the boltholes that time and haven't had a wet seatbelt in the 2 years since, but it will likely happen again (hopefully not for another couple of years).
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 05:35 PM #14
Isn't greenlane's approach actually better sealed/protected than sherpa's?
Old 12-04-2020, 06:20 PM #15
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Please explain or link to the Greenlane sealing approach.
After reading many threads and some posts about silicone sealant failure I thought the use of butyl rubber was the best material.
full , options , rack , roof , time
Roof Rack Question DanThePhotographer 4th Gen T4Rs 13 08-18-2015 12:42 PM
Roof rack question Igoboe General Discussions 0 06-19-2012 07:42 PM
Roof rack question?? awinter78 3rd gen T4Rs 8 08-14-2011 11:43 AM
Roof Basket, Roof Rack, and Sliders Question andyman32392 4th Gen T4Rs 27 09-20-2010 11:46 PM
To roof rack, or not to roof rack. That is the question. rxshu 3rd gen T4Rs 21 08-07-2008 11:01 PM
