11-03-2020, 03:34 AM
Real Name: Joe
Real Name: Joe
Headlights “blink”
So, curious if anyone has the same issue or a solution. When I am driving with lights on at night I get a “blink” or reduction in light intensity when I apply the brakes. It seems as though the truck does not have quite enough power to give to both the brake lights and headlights at the same time.
I have done the H9 bulb swap, so there is a little more draw from the headlights, but should be negligible right?
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
11-03-2020, 09:42 AM
I had this happen when my battery was really low/ on its last leg. After replacement it seems to have gone away. Check your battery health?
2014 Super White TEP, Dobinsons 2"/1" lift, Firestone Destination AT2 265/70‑17, OEM led headlights 81070-35600/ 81140-35610
11-03-2020, 12:45 PM
Also check the alternator voltage. Should be about 14 volts with the engine running and over 12 volts when the engine is off.
11-03-2020, 10:38 PM
Real Name: Joe
Real Name: Joe
Thanks guys, I will check both. Truck seems to crank and start with no issues, but the battery is the original Panasonic from 2015.
11-03-2020, 11:02 PM
Real Name: Jeff
Real Name: Jeff
Explain to me how you check the voltage output of an alternator with the engine off?
2016 Trail Premium
11-03-2020, 11:18 PM
I was going to say that, but then I figured it would be too snarky.
The OP needs to return his car to stock to see if his problem goes away.
When in trouble - obfuscate
11-03-2020, 11:21 PM
Real Name: Joe
Real Name: Joe
LOL, funny stuff. I know what he was trying to say, alternator with car on, battery with car off.
11-03-2020, 11:31 PM
Real Name: Jeff
Real Name: Jeff
Nah, not trying to be snarky at all. I was just being direct and making sure there wasn't something I was missing.
2016 Trail Premium
11-04-2020, 01:37 AM
I have this exact issue too. I have also done the h9 swap but have a pretty new odyssey group 34r with a voltage booster. So my alternator voltage is plenty high. Voltage doesn’t seem to be the issue.
I don’t remember having this issue with stock configuration but I can’t say for sure it wasn’t an issue. I just may not have noticed.
11-04-2020, 10:08 AM
Same here, thought I was just seeing things with nose dive when braking and shadows playing tricks on me. Also have done the h9 swap, but all other electrical is stock. Original battery, almost three years old now.
11-04-2020, 09:44 PM
Real Name: Joe
Real Name: Joe
So, I am going to temporarily put the H11 bulbs back in and see if the problem persists. Easy way to check to see if the H9 is the culprit.
Will check back later.
