Old 11-03-2020, 04:41 PM #1
Erock75 Erock75 is offline
Erock75 is on a distinguished road
Dobinsons 2.5” or Eibach pro stage 1. Need help.
I have a 21 ORP coming soon and am searching for a lift. I want to run 285 70s on the factory ORP wheels. It will be on road more than off but I want to make the right choice on a lift. I’ve been through pages of lift info on the forum here and it’s a tough choice. If anyone with real world experience with either lift can steer me in the right direction that would be great. And I’m aware that the wait time for getting the lift could be up too a couple months due to demand right now. Thanks in advance.
Erock75 is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 02:01 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
For only a 2.5" lift (front I assume) all you need are spacers which are inexpensive. I went with the Rough Country front and rear leveling kit. They advertised 2" front and 1" rear, but it ended up a bit more on the front. Just be sure to do a wheel alignment when you do any lift.
BEWARE: If you have the dealer install any lift, they are required by the factory to defeat the adaptive cruise control since the sensors will no longer be aimed properly.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 02:39 PM #3
rhadam's Avatar
rhadam rhadam is offline
rhadam has a spectacular aura about rhadam has a spectacular aura about
rhadam's Avatar
I have a Dobinson's lift, and I am beyond happy with it. I went 2.5" in the front and 1.5" in the rear. I went with the basic setup for not adding weight to the front or rear (I won't add a steel bumper front or back).
The ride is SO MUCH IMPROVED it's nuts. From the stock suspension to this you have more control and less body roll as well as the off-road functionality. It pretty much make the truck fun to drive with the added control and responsiveness. I have nothing but good things to say about Dobinson's.
Edit: I can't comment on rubbing with the tire size you want to go, i'm running a -12 offset with stock tire size so I rub. When i go up to 275 i'll have to cut.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
rhadam is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 09:28 PM #4
This sounds like what I’m looking for exactly. Which springs did you go with? Did it end up level or do you have some rake yet?
Old 11-04-2020, 11:31 PM #5
rhadam's Avatar
rhadam's Avatar
Front springs: C59-314
Front shocks: GS59-700
Rear coils: C59-505
Rear shocks: GS59-705
2.5" front and 1.5" rear gives you roughly an inch rake which I wanted. I ran it for about 6 months level, but i'm really happy I kept a slight rake with this lift.
Old 11-05-2020, 02:09 AM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
No experience with Eibach but I have Bilstein 5100s front and rear, with Dobinsons 302/505 springs and 285/70r17s and love it.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 03:49 AM #7
TheRoadRunner. TheRoadRunner. is offline
TheRoadRunner. is on a distinguished road
I have the eibach pro lift kit set right now. 40,000 miles on them mostly city and probably 500-800 miles off road. It was self installed, took a full weekend (great learning experience). Honestly, i wish i wouldve went bigger. I probably will add new set before 2021 ends, looking for 3" to add bigger tires on my oem alloy wheels.
TheRoadRunner. is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 12:48 AM #8
redneckj's Avatar
redneckj redneckj is offline
redneckj will become famous soon enough
redneckj's Avatar
I installed the 2.5/1.5 lift from Dobinsons in my 2018 TRDOFP w/KDSS. I also added the thin Top hat spacers from Wheelers To add 5/8” lift to the front. Installed Dobinsons UCA too.
-20644c07-730b-42b9-a5a9-13d473ae3ee7-jpeg
redneckj is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 05:08 PM #9
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
This is definitely the best time of the year to order. Shoot me a PM if anyone has any questions about what parts to use for their lift.
Remember, we can go from stock height up to 3.5" with all sorts of options.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
choice , experience , lift , orp , steer
Toyota 4Runner 2010+ ICON Stage 1 vs Stage 2 TotalAutomotiveLV 5th gen T4Rs 140 02-15-2022 09:39 PM
Eibach Pro-Truck Lift System (Stage 1) with a Toytec 1/4” spacer for driver side lean 4Runnin4Fun 5th gen T4Rs 3 08-16-2020 02:32 PM
Has anyone used the Eibach pro stage 1 kit? Mikeyt 3rd gen T4Rs 15 06-29-2019 07:36 AM
Dobinsons vs Bilstein 6112/5160 (+ Dobinsons ?s) MossJenks 5th gen T4Rs 14 09-19-2017 10:58 PM
