11-25-2020, 01:46 PM
#16
The OP has been updated to include links for the 2020+ covers.
12-06-2020, 02:14 AM
#17
Awesome! Going to be doing this ASAP!! Thank you.!
12-09-2020, 08:21 PM
#18
The 2010-2019 version thingiverse link goes to a 404.
12-09-2020, 09:26 PM
#19
I am not sure what is going on with that. If I am logged in to thingiverse, the link works, but if I log out and try to use the link, it gives me a 404 as well...
There is also a Google Drive link in the OP, that is the same file, and the link should work.
12-11-2020, 02:08 AM
#20
Thingiverse link is working now, but if it ever goes down, the google drive link should still work.
12-11-2020, 03:15 PM
#21
Any chance of a fuse cover for the one under the hood??
12-11-2020, 04:48 PM
#22
An extended cover? One of the issues I would have is getting accurate dimensions so that I could model it since I do not own a 4Runner. Another possible issue is if it is quite a bit bigger, it would cost quite a bit more, and I would have to make sure that it fits on my ABS printer.
12-24-2020, 04:42 PM
#23
Thanks @ihateu
I received my cover today with the label for my 2021.
It was well boxed and looks good.
I made some modifications to it for fitting purposes of my now and future add a circuits. I cut one corner of where it fits next to a plastic support.
I removed the OEM label and placed it on the new cover!
Photos supplied for others to see the quality.
OEM LABEL INSTALLED
COVER INSTALLED!
Best Regards,
Saker
12-24-2020, 11:38 PM
#24
Thanks,
I need to try and buy some glossy labels (if they even make them), to see if they print better. I put these labels on kind of as a bare minimum afterthought since I initially was just trying to give the files away for people to make their own, but then ended up offering to print them for those that do not have a 3d printer or a capable 3d printer. The hardest part is 3d printing them, so I figure if I get them the print, the label would be easy enough to swap if needed or making a higher quality label is within anyone's capability.
I pretty much expect that someone will put their original label on it, but I put these on just in case, as they are still useable.
12-28-2020, 06:16 PM
#25
I found some glossy labels, and printed them out. They look much better than what I was slapping on them. I will start using these.
04-09-2021, 06:45 PM
#26
Just ordered one for a 2015. Thanks!
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
04-10-2021, 09:58 AM
#27
@ ihateu3
can you post when the 2020+ covers are back in stock?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
04-12-2021, 09:38 PM
#28
I would like one for a 2019. Etsy says sold out. Let me know thanks.
Success is not final, failure is not fatal: it is the courage to continue that counts
-Winston Churchill
04-12-2021, 11:08 PM
#29
If you planning on offering these again on Etsy, I'd like one for a 2010 to 2019, please.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
04-20-2021, 01:51 AM
#30
I would like one also 2017. Etsy says sold out.
