11-07-2020, 04:10 PM
#31
Location: Stuck in an electric mountain trap in the Pyrenees or Mars, or Spokane WA.
Real Name: Dark Lord Xenu
Originally Posted by jrandom
While maybe exaggerating a bit the only thing I would consider getting with a SC is an older 3VZ-FE 3rd gen
50k for the "PRO" the OP's looking at, noway, so many other things, like mentioned a LX or an LC easily had for that price, and for one why did someone sell the PRO to begin with?
Not arguing per se, just curious, where are people finding a low mile LX or LC for $49k or less? Sure, the LX pre 2016 refresh maybe, but you are probably looking at closer to $60k for a 2016+ LX or Land Cruiser at under 50k miles. As others have seen on Mud, I have access to auction listing data, and even the low mile auction cruisers aren't selling for under $50k unless you are super lucky, or they need repairs, but there are very few cruisers as it is. I will say I did get lucky with the purchase of my 30k mile 16 cruiser last year at $53k, and if you can find a similar one, go for it. I was able to knock the seller down partially because he was a retired NBA player and didn't care (received a free car with his new job or he would have just traded in) and partially because one rear entertainment screen was broken and the Toyota list price is $7k so I talked him down(got one from a Mud member for $200 thankfully). I couldn't find another sold listing that cheap in over a year of looking nationwide unless it had been wrecked or was super rusty, both non-starters for me. I only pulled the trigger because of the price, as my 2011 Land Cruiser didn't need to be upgraded.
Dollar for dollar, a 4Runner will hold its value better than a Cruiser. I own both, and both are great vehicles. I always lean Cruiser, and own 3, but you have to pay a premium for one.
The other thing to keep in mind, as well built as Cruisers are, they have a few common failure points that the 4Runner does not seem to have. Pre 18 Cruisers all have the radiators fail around 100k miles, the water pump and starter (PITA to change) are close behind. Then there is the valley coolant leak as well as the cam tower leak (more prevalent on Alabama built Tundra motors than the Japanese counterpart put in the Cruiser, but it still happens). I've personally owned two 200 series Cruisers and two 5th Gen 4Runners. The 2012 4Runner had one lock actuator go bad, and no other issues other than the damn airbag, and Toyota did not take care of me well on that, but that is a whole other story. The 2011 Land Cruiser had the water pump and radiator replaced. The 2020 4Runner is new so no issues, the Cruiser had a idle pully go bad at 33k miles. Other than that no issues, but I know the radiator will have to be replaced at some point due to a faulty design that causes the top of the radiator to crack.
For general use, especially on road with no armor, I'd say the 4Runner is actually more reliable. Getting off-road, the Cruiser is definitely stronger and less prone to off-road caused mechanical failures and the motor will do better with armor than the 4R.
Greg's mother wishes she had aborted him.
11-07-2020, 07:22 PM
#32
Real Name: Luke
Real Name: Luke
Take into consideration your needs and what you did and didn't like about the 4Runner before it met its untimely end. Did you feel like you needed more power? Was the acceleration sluggish? Did you ever go read the SC threads on here before or after the SC Pro was an option? Do you tow on hot days in terrain?
Sure you can consider longevity, but how long are you going to keep your next vehicle (SC Pro, LC, GX, whatever) before you think about moving on? Is there anything you decided you'd want instead of the 4Runner? Are such vehicles available and within your budget? All of these need answered before you even get to the question of price, value of modifications, and whether or not the SC Pro is truly an option.
Yes, adding a SC is a lot of money. The Magnuson kit is more mild than the URD/Whipple kit and didn't require replacing any of the fuel system. It also required flashing the ECU instead of using a piggy-back ECU. For long term reliability I'd put the Magnuson kit ahead of the URD/Whipple, yet it's the URD/Whipple kit that I have on my truck. IIRC the Magnuson will also run on regular fuel instead of "the highest octane available" for the URD/Whipple (mine gets fed BP's 93).
While I decided the SC was a viable option for me, it was an easier pill to swallow than starting over on payments and modifications. OP has the option to choose a different vehicle with 8 cylinders and/or more gears in the tranny. These are things I was very interested in, but at the time were not significantly different enough to create a fuel mileage gap to make the switch appealing. $50k is no small amount, and at that price point very few are willing to make sacrifices for what they want.
Have you test driven a 20+ T4R with all the electronic gadgets and nanny "features"? Are they things you consider features or additional systems which are going to increase the long term ownership cost with issues and repairs which would not be required on a pre-20? Personally I'm not a fan, but I drive my vehicle not my phone while on the road. I also enjoyed the more simple rough & rugged appeal of the 4Runner, where even the Limited models were too much gadgetry. Each of these are things that OP should consider, and it's a personal choice. I hope he's the more typical 4Runner driver on the forums who may be distracted by shiny, but not swayed by it. OP, I also wouldn't let anyone rush the decision. If they sell that SC Pro, then let them. Sure they're not commonplace, but you can at least make one if it's truly what you want. Better to take your time and spend money where it is most important to you, on what you want and need.
11-08-2020, 01:50 PM
#33
Well deserved criticism for hastily replying
Originally Posted by 02SE
I believe you're thinking of the 5VZ-FE.
Yes that is exactly what engine I was referring too, apart from having a timing belt, my limited experience with them has been really good.
Only clarifying my brain fog post, around these parts there are bunches of late-model Lexus available with low-med mileage, also consider our cost of living is also ~roughly 25% less than where you live, of course understanding that doesn’t mean that used cars are 25% less but they are cheaper, else they don’t sell or get shipped abroad. Land cruisers on the other hand, yes, you are looking at a much older model year for that rate, and as you mentioned, apart from known issues, will run nearly indefinitely. So it is really all a weight of averages.
So my point was only that for that amount of money you can get a stronger engine and reliability, versus god knows what with who built and how was it ran.
Yes, I agree, a new stock/base 4runner is a very cost effective solution by any measure of comparison to other new Lexus or LC lines. The assumption of mine was OP wanted more power, I just think there is a better way to get it, that’s all
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
11-08-2020, 02:10 PM
#34
I wouldn’t wait. In my area I've seen dads walk in and buy their 16 yr old loaded whatever they wanted without even negotiating. Someone will buy it and not even blink an eye. I've not shopped lately but know that pros hold value.
11-08-2020, 04:40 PM
#35
I asked this on another thread, but i think you're right. i have a contact that i can get the pro for $1,000 under MSRP..just trying to figure if i should pull the trigger or wait for redesign..also wonder if the new generation will cause the 5th gen to lose value..or maybe they will still maintain..thoughts ? Thanks
11-08-2020, 08:27 PM
#36
Toyota is pretty tight lipped on what the future holds. What if the redesign turns into a green gutless ride uni-body and lower ground clearance the 5th gen will sky rocket in resale. If the next gen is packed with a V8 and Lexus comforts, history of the 4runner has held value on older gens.
Go with your gut. If you can swing it go for the Pro now, if you have doubts, wait. good luck
11-09-2020, 12:19 AM
#37
Seems like a decent price if you want the SC. IMO, 2019 is a good year, since you get the Fox suspension, but no TSS. Sure, car play would be nice but is that worth more than a SC??
11-09-2020, 01:39 AM
#38
While maybe exaggerating a bit the only thing I would consider getting with a SC is an older 5VZ-FE 3rd gen
I know those are great motors, but I don’t get why so many with 5th gens dislike the Supercharger. Realistically the reliability of the 1GR like that of any other motor will go downhill if you beat on it and don’t maintain it. I’m supercharged and it’s made the experience of going over mountain passes an enjoyable one. I think my next mod will be 4.56 gears, and even with the engine RPM being slightly higher at freeway speeds I doubt anything will down faster than a stock block.
Mods are loading.......
11-09-2020, 10:22 AM
#39
I don’t dislike them at all. The reason I mentioned the 5vz-fe is that you could get one oem (and it was like a third of the price) I am just not big on the 1gr-fe price tag, fuel requirements and this is minor? but what it seemingly takes to get it to calibrate/tuned, you have to add an additional (another expense) ECU? Maybe that isn’t as big a deal as it seems, from the little I have researched on the subject it seems that the way you can tune a Subaru is what you want, you can literally flash through the OBD port. Again, total noob when it comes to tuning/calibration. So please, correct/educate me.
Reliability, I would not feel comfortable buying a late model used truck with one (new off the lot, maybe) simply because of too many unknowns for that kind of price tag, would I by a third gen with one for a few thousand bucks? Sure! A 2019 for $50k nah, pass, unless I knew who owned it, installed it and how it was treated
I’m not opposed to supercharging, it would just be the last thing I did. I would opt to regear first. It’s easier, far less expensive, and you have range of options. You could literally swap out gears when you do a seasonal tire change. I guess you could swap boost pulleys the same way
2013 TE w/ KDSS Nav
11-09-2020, 12:40 PM
#40
The biggest issue I have is that they're $6k plus installation. For what you get - it's a lot of $ that may be better put toward a different vehicle. They were $4k list price when Toyota sold them and you could often get a better deal - like free labor to install - as part of a new car purchase. At $6k+ - at least for me the value proposition isn't there for me when I compare that to trading my '15 for a '15 LC200 that I could do for about $10k.
What the 4R really needs is a new transmission. A better transmission would go a long way toward making the stock 4Runner engine work a lot better. With and without the SC. So I've kinda been sitting waiting on the next gen Tundra to see if that's a good indication of the future of the 4Runner.
11-09-2020, 12:51 PM
#41
They are expensive no doubt. If you look around you can find them cheaper. I got mine for $5400. Also if you can change your own oil, you can install the supercharger. Just take your time.
11-09-2020, 01:06 PM
#42
have a urd supercharger. Great so far. asides from added maintenance. My seals on the drive shaft of the supercharger leaked and i needed to get that fixed.
Supercharger does add a good amount of driveability to the 4runner.
49k for a used 2019 isn't worth it. you will probably pay a bit more for a new one and supercharge it.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
