Old 11-10-2020, 12:07 AM #1
T4R416 T4R416 is offline
T4R416 will become famous soon enough
17x 8 4in. Backspace and -12mm offset.. WILL IT FIT??
As title states.. does this even make sense?? Will it even fit!?!?! 17x8 wheels with 4in back space and -12 offset... what problems will I run into... I can get them fkr a really good price .. they are vision 8 Steelies and yes I know they are super heavy but the deal
Is pretty good.. if I can run them I think I will!! Anyone have expertise or experience with these size or similar. ?? any input appreciated!!
T4R416 is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 12:39 AM #2
Other Choice are eagle alloys with same rough specs but -4 offsets and more than double the price
Old 11-10-2020, 01:20 AM #3
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Backspace sounds OK, but will it clear the brake caliper?
I bought one (different brand) like that for a spare, it does not clear the front caliper.
delloro is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 11:17 AM #4
Unhappy
Doesn’t clear front calipers??? That doesn’t make sense, these wheels are pushed out away further making more backspace no? Can anyone else chime i. Before I jump on these and possibly make a mistake ...
Old 11-10-2020, 09:17 PM #5
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I have 17x9, 4.5 and -12 and fits fine. The 4'' backspace is the question.
83Mule is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 10:37 PM #6
delloro's Avatar
delloro's Avatar
It's not the backspacing, its the shape of the center disc. A flat transition from the hub to the rim does not work.
The calipers protrude outboard past the wheel-mounting surface of the hub enough to hit the wheel if the wheel is not a bit convex, like the inside part of a donut (a torus).
The ones linked in my response hit the caliper. If your wheels are shaped like those, they will not work.
Make sure you get a return policy before you buy those.
Old 11-11-2020, 05:36 PM #7
Don’t they All have to have a flat part on hub? To make constant contact where they bolt on no?
Old 11-12-2020, 12:50 AM #8
delloro's Avatar
delloro's Avatar
Yes, but the part of the wheel between that area and the rim has to be convex in profile, or it will interfere with the caliper.
Caliper in red, hub light blue, wheel yellow (and dk blue). Crudely drawn in from the side perspective of a wheel.
17x 8 4in. Backspace and -12mm offset.. WILL IT FIT??-img_1215-jpg  17x 8 4in. Backspace and -12mm offset.. WILL IT FIT??-notes_201112_001401-jpg
Old 11-12-2020, 03:14 AM #9
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
I've ran 17"x8" wheels before.
Mine had 4.5" backspacing and +0mm offset.
Your wheels would be the same as mine, but sticking out further. Being that both wheels are the same width, we can simply conclude that it should fit (if they were the same design as mine), but yours having more "poke".
You'll have 12mm more "poke", and thus, 12mm less backspace.. or in this case, about 0.5" less of backspace. Your wheel moves "outward". The important aspect is really the design of the spokes.
Anyway, I'm on 17"x9" now and I have even less backspacing lol
17x 8 4in. Backspace and -12mm offset.. WILL IT FIT??-2020-11-11_23-12-00-png
perf0rmance is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 08:43 PM #10
PICASSO himself couldn’t have drawn it better!🙏🏽
Old 11-12-2020, 08:43 PM #11
Sounds really good!
Old 11-20-2020, 09:24 PM #12
Small update: as a few of you have said.. the wheels did not fit , but I had a spare 1.25” spacer and they definitely did fit!! Was just a test fit... will be installing my Eibach lift in a couple weeks and then throwing these wheels on!!! Then off to some trails I go!!! Pics will be coming soon .!
Old 11-20-2020, 10:14 PM #13
delloro's Avatar
delloro's Avatar
You are going to rub with that setup.
4in , fit , good , offset , run
Will This Work? 285/70/17 on 17x9 -12mm Offset Southpaw07 4th Gen T4Rs 0 08-29-2020 12:35 AM
-12mm Offset Wheel Pics SAC-CA-Runner 4th Gen T4Rs 7 10-10-2018 10:59 PM
16x7 4.5"BS 12mm offset will this fit? powderKing Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-27-2017 05:45 PM
18 x 9 wheels -- +12mm or -6mm offset? rjfowler 5th gen T4Rs 5 05-26-2014 11:22 AM
17 x 8 4.5 backspace 0mm offset silversx 5th gen T4Rs 14 07-08-2011 06:10 PM
