Old 12-15-2020, 02:10 AM #16
very nice. I've been eyeballing that kit for a month or so.
Old 12-15-2020, 10:44 AM #17
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Originally Posted by rayofsi View Post
In progress
Loving the progress pictures! Would be great to know, when it's done and on the road, any issues ran into for the install. I think this is the CORRECT option for people wanting to push 35"s or larger and not have to chop up the firewall etc.
Also will be interesting to hear what you end up getting for alignment specs and if the front end has more or less rubbing with the wheel shift.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 11:54 AM #18
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
will definitely update
The guy that did the install on the FJ told me that the kit had the pivots 1" wider then his FJ is specced for.
I'm not sure if the 4runner is closer to FJ spec or Tacoma Spec
But i guess i will have the issue
His camber was 2-3 on both sides.
They didn't mention much of any issue fitting them, but i guess they will just bill me, shop already asked me if they could make all the small decisions with doing things to make it fit.
The lower arm pivot is mostly done. but i have other things being done as well.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 12:43 PM #19
rayofsi's Avatar
rayofsi's Avatar
Nothing matches hah. Red JBA ucas
JD Fabrication Lower Arm Pivots-screenshot_20201215-113951_quickpic-jpg
Old 12-23-2020, 01:33 PM #20
Bfosmoen Bfosmoen is offline
Bfosmoen is on a distinguished road
Did you receive any feedback as to what needed to be modified? I am looking into doing this as well but the closest reliable shop to me is a Jeep specialist without any real Toyota knowledge and while there work looks to be top notch the more information I can give them the better. I reached out to JD Fabrication to ask if they knew what modifications would be necessary but they did not have any information. I have also searched, to the best of my limited ability, for the specific differences between the Taco and 4R Lca's but cannot find any specific info as to what is different between them.
Bfosmoen is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 04:22 PM #21
rayofsi's Avatar
rayofsi's Avatar
UCAs with heim joints so they can be adjusted. I believe the 4runner like the FJ has the pivot points a bit more narrow then the tacoma. The guy with the kit on the FJ needed it the heim joint in the UCAS. I went with new UCAS with Heims to be on the safe side.
They also needed to relocated my swaybar even further up so that the sway bar links can be in the proper place. Not an issue for those removing the sway bar..
My shop specializes in raptors.. the 2 locating tabs in the rear of the LCA seemed to match up in the pictures they sent me. Just a lot of tedious work, it wasn't a hard install.
Old 12-23-2020, 06:43 PM #22
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
This is really cool, I look forward to seeing how this comes out. A bit more extreme than I would do for my daily driver but I love stuff like this.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 01:51 PM #23
Any updates on how this all came together? Handling, caster, and clearance? Looks like the only real change is needing to use the Heim joint UCA's for adjustability?
Truck is looking great @rayofsi
Old 01-06-2021, 01:53 PM #24
rayofsi's Avatar
rayofsi's Avatar
they are closed for 2 weeks... i think everyone knows what 2 weeks means by now
they are all done asides from a custom skid plate that goes from bumper to the back. will talk to them again when they reopen
Old 01-06-2021, 02:03 PM #25
Bummer on the closure, pretty awesome they are close to all wrapped up! Quite the build you've got going.
Old 01-18-2021, 01:16 AM #26
rayofsi's Avatar
rayofsi's Avatar
Don't forget you will need to relocate your sway bar even further forward. All finished.. but my freshly warranties rcv axles that needed new boots after 6 months, are getting sent back. They sent me defective warranty axles...
JD Fabrication Lower Arm Pivots-20210116_103358~01-jpg  JD Fabrication Lower Arm Pivots-20210116_103249~01-jpg
Old 01-18-2021, 10:19 AM #27
wcslv wcslv is offline
wcslv is on a distinguished road
How’s it drive?
2019 T4R TRD PRO
wcslv is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 10:26 AM #28
Also, could you take a picture from the side of the vehicle to show how much space between the tire and the body?
2019 T4R TRD PRO
Old 01-18-2021, 01:01 PM #29
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
They sent you axles which had been returned to them for warranty?
delloro is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 01:24 PM #30
rayofsi's Avatar
rayofsi's Avatar
I bought a set new in the end of 2019. installed june 2020, sent back for warranty 12/2020, leaking boots so i bought new ones, and also something broke inside, installed again 1/2021, makes a noise when in 4hi/4lo, so they are sending them back again.
arm , arms , control , lower , stock
FS: Total Chaos Fabrication Lower Link Skids. $90 shipped, Chicago IL tajemniczy For Sale: T4R Items 3 04-22-2017 02:38 AM
C4 Fabrication NZDZRT Group Buys 23 05-13-2016 10:49 AM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
3rd gen fabrication kev7706 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 05-08-2007 10:51 PM
