Old 03-03-2024, 07:54 PM #1
BlueHenT4R's Avatar
BlueHenT4R BlueHenT4R is offline
BlueHenT4R will become famous soon enough
BlueHenT4R's Avatar
TPMS Sensor Part Number
I'm trying to get the correct TPMS sensors for a second set of wheels for my '23 ORP. The Toyota parts website shows the following two parts as "Exact Fit for your 2023 4RUNNER." Does anybody know which is actually correct? And does a 2023 recognize them without programming? I watched Car Care Nut's video on TPMS, and he seemed to indicate that Toyotas built 2018 or newer can recognize and self-acknowledge new sensors.
42607-53020 Tire Pressure Monitoring System Sensor | Part #4260753020 | Toyota Auto Parts
4260702050 Tire Pressure Monitoring System Sensor | Part #4260702050 | Toyota Auto Parts
2023 4Runner TRD Off Road Premium, Magnetic Gray Metallic
2021 Tacoma TRD Pro, Lunar Rock
2006 4Runner SR5 V6, Natural White
BlueHenT4R is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 09:58 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
I believe the difference is in the valve stem. You can get sensors that have the valve stem as part of the sensor, and then there are sensors that plug into a separate valve stem that looks like the old fashioned rubber valve stems. So the answer is both will fit, just pick the one that has the type of valve stem you want.
Not quite sure on the 4Runner, but for my RAV4, as long as replacement wheels have OEM TPMS, there is a setting in the vehicle settings for "change tires". So when you change out your summer tires for winter tires, you select that on the settings, then the car will automatically sense the new TPMS after you drive a few miles. (The tires have to rotate for some time for the TPMS to wake up).
fkheath is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 11:31 PM #3
cheeser cheeser is offline
cheeser is on a distinguished road
I’m doing the same, but purchased a set via Tire Rack…installing next week.
TPMS Sensor Part Number-img_1005-jpg
cheeser is offline   Reply With QuoteReply With Quote
correct , parts , recognize , sensors , tpms
2020 4R TPMS Sensors - Part Number niadh0 5th gen T4Rs 5 11-03-2019 08:21 PM
oxygen sensor part number for 03? nicolachel 4th Gen T4Rs 0 03-08-2017 02:56 PM
TPMS Part Number (42607-33021/06011/33011) myT4R-TE&me 5th gen T4Rs 2 02-22-2015 05:06 AM
looking for temp sensor part number 02running 3rd gen T4Rs 2 02-09-2013 12:32 AM
TPMS part number? adio3x 5th gen T4Rs 4 01-31-2011 03:00 PM
