11-10-2020, 07:40 AM
JD Fabrication Lower Arm Pivots
Anyone done this yet or plan on it? I think I'll take a stab at it next year for 35" tires on my 4Runner. Simple enough to do and can use stock lower control arms. Just cut off your lower control arm mounts and weld these in, allows for up to an inch movement forward.
Here is a bit of an update. JD Fab now makes a specific kit for the 4runners and FJ Cruiser to relocate the lower pivot mounts.
JD Fab Lower Control Arm Mount Relocation
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
11-10-2020, 03:04 PM
Real Name: Ron
Real Name: Ron
Very cool! I love the trick items that people come up with to solve various problems. If I had unlimited funds I would put most on "just because!"
11-10-2020, 03:19 PM
This would fit the 4runner?
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
11-10-2020, 03:44 PM
This is very interesting. Solves a couple issues. I think you could do the same with modified control arms instead, but the price on this kit is pretty decent. Cheaper than LCAs and it appears to be pretty easy to install too.
11-10-2020, 10:45 PM
I don't see why it wouldn't. They have the same front frame section. The only tricky bit will be if you have KDSS like me. But I'm going to push that all forward as well equal to what I move the lower bit forward. They have a upper control arm to go with the lower pivot kit as well to really dial in the caster. But yeah, I'm definitely going to give this a go next year once I'm finished my Tacoma build.
Upper control arm.
Tacoma 05-15 Upper Arm
– JD Fabrication
IG @schultzy507
11-13-2020, 06:07 PM
i ordered a set. will keep this thread posted.
11-13-2020, 06:25 PM
@ canadian bum
and I are talking with a guy that modified the kit to fit an FJ. Its possible from what it sounds like, just some minor differences apparently.
11-13-2020, 06:33 PM
Originally Posted by Inv4drZm
@ canadian bum
good to hear!
my shop does a lot of custom fabrications and welding. i'm sure they'll figure it out. i get mots of my 4runner work and all my raptor work with them.
i'm already running 285/75r17 with only a bit of noise in full lock reverse. this should give me more breathing room.
11-13-2020, 11:08 PM
good to hear!
Looking forward to seeing how everything works out. I want to fit 35s without cutting the tub or anything plus fix caster. I'm definitely not shy of fab mods and custom. Just would like to keep it to a minimum and maintain road driving.
IG @schultzy507
11-14-2020, 01:56 AM
i already have a bmc and pinchwelds hammered in. but want to see what this Lower arm pivot can do.
12-10-2020, 05:18 PM
Point of no return
12-10-2020, 07:26 PM
Point of no return
Awesome!!! Looking forward to seeing how it turns out.
IG @schultzy507
12-14-2020, 11:59 PM
In progress
12-15-2020, 12:06 AM
Banned
Real Name: Tobias Fünke
Banned
In progress
What’s gonna be the story with skid plates? Looks great.
12-15-2020, 01:34 AM
they will probably to either make me a filler plate or chop my original heftyfab plates to fit. the jdfab comes with its own plate
