01-18-2021, 01:29 PM
#31
Real Name: Ron
Real Name: Ron
Originally Posted by rayofsi
I bought a set new in the end of 2019. installed june 2020, sent back for warranty 12/2020, leaking boots so i bought new ones, and also something broke inside, installed again 1/2021, makes a noise when in 4hi/4lo, so they are sending them back again.
I'll take them off my list for replacement axle suppliers, don't need that kind of service.
01-18-2021, 02:00 PM
#32
the JD Fabrication 934 cv's look nice
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
01-18-2021, 05:30 PM
#33
Gotcha. The replacement axles sent to you under warranty, turned out to also be defective themselves.
01-18-2021, 09:52 PM
#34
Real Name: Kevin
Real Name: Kevin
I have to ask. What did the install cost you?
01-19-2021, 01:05 AM
#35
too much. The guy that makes and sells the kit says it takes him 16+ hours install and he's done many. This was a custom fit job to the 4runner. I also had secondary shock hoops installed as well as rear weld on hydraulic bumps. so it was a lot of labor hours.
01-19-2021, 04:18 AM
#36
Real Name: Justin
Real Name: Justin
Subbed
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
01-24-2021, 10:28 AM
#37
I need a bumper chop lol, will probably get that done next time i'm in the shop. I think my shop convinced King that i needed King shocks, so those are in order soon.
01-24-2021, 12:07 PM
#38
baller build, mid travel with all the goodies. that kit would be amazing with a 3.5" long travel kit too.
the rear weld on bump stop kit isn't hard, i hope they didn't charge you a bunch for that. I did it in my driveway lol.
01-24-2021, 12:10 PM
#39
mines is actually a standard travel setup.. lol baller for sure.
01-24-2021, 12:15 PM
#40
i do have some sort of unsafe feeling driving this.
I dont know if they set my caster too high while my wheels are already pushed forward 1 inch? possibly my steering rods? will jack up later and check out in this 20f weather
I feel unsafe on the highway going 60+, seems like the steering is very very sensitive now . I've been driving my raptor for the past 2 months though, and its track width is roughly 4" more then a stock raptor.
10-17-2021, 10:38 PM
#41
Did you ever figure out what caused you to feel uneasy driving? And how is it all performing now?
10-18-2021, 08:53 AM
#42
hi, yes it was my rear sway bar endlinks, they somehow went bad on some new under 3k mile end links..
11-21-2021, 10:19 PM
#43
Glad to hear that it wasn’t anything more, my kit arrived in the next week and I’m stoked to see how the install will go. Anything needed other than upper control arms? I wouldn’t assume since it’s just moving everything forward but I thought I’d ask before I’m mid install and need parts.
11-22-2021, 10:06 AM
#44
just upper arms as far as i know! good luck! and hope to hear how many hours it takes you hah.
01-23-2022, 03:44 PM
#45
We’ll install is not going so we’ll since I ordered a 16+ tacoma kit. It appears to be the same as the 2nd gen kit you have which makes me wonder why it doesn’t work right now. Do you mind sending some photos all around of where it’s bolted and welded?
