Old 11-10-2020, 10:02 PM #1
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
best way to temp mount shovel to Pro rack?
Need a shovel on some ventures, but don't want it full time. Anyone have a good solution to mount a dirty shovel to the Pro rack? Thanks.
pointman is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 10:49 PM #2
edgesalon's Avatar
edgesalon edgesalon is offline
edgesalon is on a distinguished road
edgesalon's Avatar
i have seen some on FJ they have the same tubes as the Pro rack
here are two different ways to go
DIY FJ Cruiser Roof Rack Axe, Shovel and Tool Mount | by J&J Kniv Supply Co. | Overland Expeditions and Journal | Medium
4x4 Roof Racks for Sale | Off Road Roof Racks
18 FunRunner
edgesalon is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 11:34 PM #3
Banned
Banned
Originally Posted by edgesalon View Post
Hey! Thanks for those links! I like the monkey fist idea. Wish it was completely ready to go out the box. I might give that a go. Thanks again!
Old 11-11-2020, 12:37 AM #4
cutty01 cutty01 is offline
cutty01 will become famous soon enough
I built something like this for my Gobi rack. It should work for the Pro rack. I made two of them which you can mount in series depending on the length handles of your axe/shovels.
Here's the write-up DIY Axe Shovel Mount | Toyota FJ Cruiser Forum
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
cutty01 is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 02:57 AM #5
????? ????? is offline
????? will become famous soon enough
I've found these mounts to work well
TOOL MOUNTS - GZila Designs
????? is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 10:17 PM #6
Banned
Banned
Thanks for the link! I am going to check it out. That looks awesome!
Old 11-11-2020, 10:17 PM #7
Banned
Banned
Sweet! THANKS!!
Old 11-12-2020, 10:48 AM #8
The dual mount clip for $100 is almost the same as the DIY I posted. I like how they've mounted the Quick Fists on either side of the clamp that mounts to the rack. Less levered torque on the clamp. Easy to do the same thing on the DIY too. To give you more information to compare build vs. buy, I spent about 1 hour making my own and it cost about $30 in parts. I guess it's a question of how much your time is worth :-).
My next project is to do the same kind of mounting clamp with a longer aluminum bar to mount my traction boards on the other side of the rack.
Old 11-12-2020, 12:04 PM #9
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
How is the left quick fist mounted to the plate? I see the nut hanging below on the right one. Did you counter sink something?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 12:30 AM #10
I drilled about 1/4" into the roll cage mount and used a 10-24 tap into the hole on both the aluminum bar and the roll cage mount.
Old 11-14-2020, 10:38 AM #11
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Fourtreks, Axia Alloys and Wilco have a number of solutions for any just about any size bar:
Modular Shovel Mount
Large All Purpose Mount 1″- 2″ – Axia Alloys
QUICK FIST(R) TUBE MOUNT | WilcoOffroad.com
comtn4x4 is offline   Reply With QuoteReply With Quote
full , mount , pro , rack , shovel
5th GEN Bajarack Flat Utility Rack w/ axe & shovel mount & crossbars (6mnths old) cbniles25 For Sale: T4R Items 1 03-19-2020 02:07 PM
FS rola roof rack with 30" hanma LED light bar / custom axe shovel mount Mesa az $200 ddnww For Sale: Non-T4R Items 3 02-17-2018 12:51 AM
Roof rack shovel mount: Quick and easy teotwaki Off-Roading 16 01-10-2017 07:27 PM
ARB roof rack shovel/axe mount Derek G 4th Gen T4Rs 3 12-18-2013 09:07 PM
