Old 11-15-2020, 08:23 PM #46
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
Originally Posted by TheJokingExplorer View Post
When you grease your bushings do you do it until it pushes grease out? My passenger side grease pushes out after a few shots. Nothing comes out on the drivers side after the recommended 3-5 shots.
The very first time I greased the bushings I did it until the grease pushed put. After the initial time, I just add 3-5 shots in each zerk each time I grease and dont worry about the grease pushing out. Never had a problem doing it that way. You should always loosen the UCA bolt (the super long one) before you grease each side, then torque it back down to spec! This let's the grease squeeze out when the bushing is full and it wont make the bushing swell and damage it. Make sure you always tighten the bolt with the weight of the truck on it (with your truck on the ground). Just thought I would mention that if you ever had it in the air and felt like doing the UCA greasing.
Sent from my SM-G950U using Tapatalk
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 10:07 PM #47
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
Yeah I figured it should be on the ground. Thanks for the info!
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 07:27 PM #48
ferrisDJB's Avatar
ferrisDJB ferrisDJB is offline
ferrisDJB has a little shameless behaviour in the past
ferrisDJB's Avatar
lousy workmanship
It's amazing how shops like the one 'The JokingExplorer' found exist. There're plenty of them out there. I always thought the real crooks were service shops at dealerships, but they've drastically improved from the days I worked at there. Some of these backdoor shops dare you to complain. A coworker friend of mine had to get the police to grab his car because they charged the moon on his project. When he went to get it, in a hostile visit they locked their doors. Everytime he said he would come buy, either the shop was closed, nobody answered or all employee cars were gone. What a sleeze ball operation that was.
JokingExplorer, stay in touch with your bank and call them once ev ery two weeks, talk to same operator. The more you converse with them the more they tend to lean in your direction. Stay on'm
ferrisDJB is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 04:57 PM #49
Can anybody tell me what this wire is? I just got back from Sedona the vehicle was fine. I went to visually check everything out and noticed this wire sticking out? It’s hard metal? Is this from improper install?
Old 12-01-2020, 06:06 PM #50
meltdown meltdown is offline
meltdown will become famous soon enough
Don’t know what it is, but it shouldn’t be there.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 06:18 PM #51
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Have you tried pulling the wire out? Hopefully, it's just a loose piece of wire kicked up by the tire that some how happened to land in that spot. If so, that's great, otherwise ...
I'm guessing the installer used a length of wire to help hold up (or in) the coil over assembly, and forgot to remove it when he tightened up the bolts and decided to just clip off the ends. Your photo shows the upper end of the wire. Can you see the other end of the wire? Is it wrapped around something? The answer to these questions will help determine if this is an issue that must be resolved as soon as possible.
It appears to me the wire is embedded between two hard surfaces where the lower surface is the top hat and the upper surface is the frame mount. Verify the three bolts are still properly tightened. I'm strongly leaning towards having the shop remove the wire because the fit between housing and top hat is not what it should be with the wire between them.
If you decide to have the shop fix this, then I think they should loosen and re-torque the lower shock mount bolts with your vehicle lowered onto the ground or driven onto an alignment rack (so they can easily get under it). I think they torqued those bolts with the vehicle on a lift and the wheel assemblies were unweighted as described in a previous post.
DougR is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 06:28 PM #52
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Threads like theses remind me not to moan when I'm doing all my own labor.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 07:17 PM #53
Literally the one time I decide not to do something myself.
Old 12-01-2020, 07:24 PM #54
Banned
Banned
Life is poetry
Old 12-01-2020, 09:23 PM #55
DougR's Avatar
DougR's Avatar
Life is poetry
"All the gods, all the heavens, all the hells, are within you.” ~Joseph Campbell
Old 12-01-2020, 10:43 PM #56
I attempted to remove the wire but it doesn't want to go anywhere. I can't imagine its interfering with anything and I have no clue what its doing there. As bad as it sounds I might just leave it until I absolutely have to do something about it.
Old 12-01-2020, 11:09 PM #57
Banned
Banned
You will prob be ight. I wouldn't sweat it.
Old 12-02-2020, 12:12 AM #58
salsanacho salsanacho is offline
salsanacho will become famous soon enough
Yeah agreed. That said, given the nightmare you've been through, not surprised there's some paranoia about it.
salsanacho is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 12:44 AM #59
No kidding. I just can't comprehend how someone could mess up what seems to be such a straight forward project.
Old 12-02-2020, 05:28 PM #60
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
Ain't that the truth. Every time I do it myself I'm busy cursing and bleeding, but every time I take any of my cars somewhere, I have an issue
ragin_cajun is offline   Reply With QuoteReply With Quote
hardware , i’m , jba , kit , shop
How many inches of jack stand lift do I need to install lift spacer/bushings? 4Runner4Runner4 4th Gen T4Rs 3 03-21-2020 07:37 PM
Worst Nightmare jahdai42 3rd gen T4Rs 6 10-11-2014 08:59 PM
Nightmare Brake Job KrazedJD 4th Gen T4Rs 10 03-22-2011 11:07 PM
Why NOT to install a body lift or use inferior lift products Sac State 4th Gen T4Rs 6 05-05-2005 03:23 PM
